RV.Net Open Roads Forum: Truck Campers: black seal creep in Bigfoot camper
 > black seal creep in Bigfoot camper
Freeborn530
bothell
Posted: 02/14/18 08:04am Link  |  Quote  |  Print  |  Notify Moderator
I'm looking to buy a used camper. Found a bigfoot looks good except the owner listed this: "The only negative is the camper glass has the black seal creep inside the double pane windows. The windows themselves are sealed and have no leaks. Bigfoot had some years where this was an issue and verified that the window is not prone to leaking with the seal deformed."
What do you think its a 2004 25c9.6
jimh425
Western MT
Posted: 02/14/18 09:09am Link  |  Quote  |  Print  |  Notify Moderator
Get em while they're hot. [emoticon]. Well there aren't that many used Bigfoots for sale from what I understand. If it is a good price, probably worth it.
Photomike
Southern Alberta or where the camper is parked!
Posted: 02/14/18 09:17am Link  |  Quote  |  Print  |  Notify Moderator
Depends on the price. If it is a good price and you can live with the creep and it is not effecting the performance then go for it. If it will bother you then don't.
2011 Majestic 19G
2017 Ford Transit (conversion underway)
EVO Electric bike
Advanced Elements Kayaks
Border Collie Guard Dog
Kayteg1
California > Nevada
Posted: 02/14/18 09:23am Link  |  Quote  |  Print  |  Notify Moderator
Any picture?
Big Foot has lobby of "promoters" on this forum, so take all the replies with big grain of salt.
Not that does not apply to different subjects, but IMHO this is good sample where "Advertisements overcomes common sense"
Good luck camper shopping.
TxGearhead
Posted: 02/14/18 09:36am Link  |  Quote  |  Print  |  Notify Moderator
All of them have promoters. If I wasn't happy with a camper, I wouldn't have it.
Are you saying the black creep is between the glass, around the edges? How much? 1/16" or 1 1/2"?
2018 Ram 3500 CC LB DRW 4X4 Cummins Aisin Laramie Pearl White
2014 Montana High Country 305RL
2008 Bigfoot 25C9.4
2014 NauticStar 21 ShallowBay 150HP Yamaha
2016 GoDevil 18X44 35HP Surface Drive
bigfootgrey
Connecticut
Posted: 02/14/18 10:33am Link  |  Quote  |  Print  |  Notify Moderator
Contact Kent Miller at Sunview Industries, the window manufacturer. He can answer any concerns you may have
Bob
2011 Ford F-350 PSD SC DRW
2008 Bigfoot 25C-10.4E
Firestone airbags - torklift stable-loads,fastguns,tie-downs Rancho rs 9000XL’s. 2015 Lund Alaskan 1600 tiller.
TxGearhead
Posted: 02/14/18 12:23pm Link  |  Quote  |  Print  |  Notify Moderator
^^Please let us know what they say.
Old Plank Road
Posted: 02/14/18 01:34pm Link  |  Quote  |  Print  |  Notify Moderator
The rubber seal between the two panes of glass migrating, or moving out of place is not unique to Bigfoot. Check the forum for Fogging double-paned windows.
There are do it yourself kits available to rebuild the window, the windows must be removed, repaired, resealed and replaced. Not a big chore if you are handy and have a place to work out of the weather.
I had the windows of my 2004 Bigfoot TC repaired last year at the RV Fog Doctor in Searcy, AR. They did quality work, and service all types of RV's, I parked in the shop next to a couple of high-end Class A DPs.
In my case, the seals still functioned without leaks, but I didn't like the look and didn't want to wait to see if a leak developed.
RamblinAnne
California
Posted: 02/14/18 04:48pm Link  |  Quote  |  Print  |  Notify Moderator
yepp- I have a 2004 Bigfoot and one of my windows has the black seal creep issue. I see another window is starting to creep as well. This has not affected the insulating ability nor anything else aside from being cosmetically unappealing. I hope to replace the affected windows some day but because it's only cosmetic and really not that bad, I haven't had the motivation to spend the money and put in the work.
2013 Ford F350 6.7L Powerstroke Diesel DRW Lariat Crew Cab 4x4
2004 Bigfoot 25c10.6e
Full-timer
Freeborn530
bothell
Posted: 02/14/18 06:23pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks for the reply's, I'm buying he camper. Its a 2004 2500 Series M-25-C-9.6, $14000.00. Has the usual plus AC, and some other updates. I have to drive about 350 miles however I've been looking for the last 6 months! Each time one came up for sale it was sold immediately. Thank all of you for the advice!
