RV.Net Open Roads Forum: For anyone wanting a 350 watt pure sine wave Victron
 > For anyone wanting a 350 watt pure sine wave Victron
Page of 5
GordonThree
Northern Michigan
Posted: 02/18/18 09:47am Link  |  Quote  |  Print  |  Notify Moderator
Bumpyroad wrote:
Tom_M wrote:
GordonThree wrote:
Lifestyle Solutions seems to sell furniture and medical support implements.
Here's one slightly cheaper and shipped from "Boats and RV Accessories":
https://www.amazon.com/Victron-Power-Inv........8954482&sr=1-1&refinements=p_4%3AVictron
what is that 1000 watt one for the same price that pops up below this one?
bumpy
The red BESTek unit? I would pass on that unit. I doubt it could really supply 1000 watts continuously. No UL, no FCC, no mention of pure sine wave ... and only 5 lbs? Even if they're using newer high frequency designs, the transformers should still be heavier than that.
For modified sine, I like the advertisement for the orange Ampeak unit that shows up looking at the BESTek ... ETL tested, they're not the UL but better than nothing. Nice sturdy input terminals, volt meter built in, support for a remote, and best of all the advertisement is up front about it being a modified sine unit. On the flipside, only 3.4 pounds??? Sheesh
2013 KZ Sportsmen Classic 200, 20 ft TT
2017 Ram 2500 4x4, 6.4 HEMI, 4.10 / Auto
lawrosa
Horry County
Posted: 02/18/18 10:41am Link  |  Quote  |  Print  |  Notify Moderator
I went with the krieger Mod sin. UL and CSA standard...
1100 watts is really all you should need..
$77 bucks and 3 year warranty...
https://www.amazon.com/KRI%C3%8BGER-Inve........&sr=8-1&keywords=krieger%2Binverter&th=1
Mike L ... N.J.
2006 Silverado ext cab long bed. 3:42 rear. LM7 5.3 motor. 300 hp 350 ft lbs torgue @ 4000 rpms
2018 coachmen Catalina sbx 261bh
pianotuna
Regina, SK, Canada
Posted: 02/18/18 10:58am Link  |  Quote  |  Print  |  Notify Moderator
Hi LittleBill,
You will need to do an adapter of some kind. The Victron comes with #8 wire (or maybe #6) which goes inside the case.
I'm going to try running it on cigarette lighter, too, but will limit my demand to a laptop and heating pad.
I'm concerned about the inrush current.
LittleBill wrote:
i bought one, hope i can adapter a cigarette lighter to it easily, its 88 from boats and rv
Regards, Don
Full Time in a 28 foot Class C, 256 watts solar, 556 amp hours of AGM in two battery banks 12 volt batteries, 3000 watt Magnum hybrid inverter, Sola Basic Autoformer, Microair Easy Start.
LittleBill
Scranton, PA USA
Posted: 02/18/18 11:03am Link  |  Quote  |  Print  |  Notify Moderator
GordonThree wrote:
30amps is a lot to expect from a cigarette lighter socket
who said i planned to run it at full load?
GordonThree
Northern Michigan
Posted: 02/18/18 11:14am Link  |  Quote  |  Print  |  Notify Moderator
Valid point.
My laptop has a 240 watt charger, too much to run through a cigarette lighter. I always assume worst case usage when hooking something up.
time2roll
Posted: 02/18/18 11:17am Link  |  Quote  |  Print  |  Notify Moderator
The 12/180 has a 12v cigar connector.
Can't find a comparable price though.
675w Solar pictures back up
landyacht318
Near a large body of salty water
Posted: 02/18/18 11:18am Link  |  Quote  |  Print  |  Notify Moderator
Heck, 5 amps is too much for most ciggy plug designs.
They make for a detestable electrical connection.
Everything runs better when they are removed from the circuit.
I've been happy with a Wagan elite 400 watt PSW. I've watched it provide 435 watts continuously. Very small size.
It comes with a ciggy plug, but says not for use with more than 120 watts. I'd halve that number.
LittleBill
Scranton, PA USA
Posted: 02/18/18 11:28am Link  |  Quote  |  Print  |  Notify Moderator
GordonThree wrote:
Valid point.
agreed, i usually design the same way, you can get about 100-130 watts off the cigarette.
my MSW vector came with both cables.not sure why i even bought this lol,although i have been looking at that go power for a while
RLS7201
Posted: 02/18/18 03:49pm Link  |  Quote  |  Print  |  Notify Moderator
pianotuna wrote:
Hi folks,
I find this an amazing deal at 90 bucks. I purchased one and it is double the weight of the inverter I was using before.
https://smile.amazon.com/gp/product/B01E........5ZA94/ref=pe_344980_272415450_em_1p_0_ti
Don,
I keep looking but don't see weather the inverter is PSW or modified SW.
Wouldn't this inverter from Harbor Freight, also be of good value?
I've had the 750 from HF on line for 3 or 4 years, with no failure.
Richard
95 Bounder 32H F53
460/528 stroker
Web Master
MWPSchooners.com
GordonThree
Northern Michigan
Posted: 02/18/18 04:01pm Link  |  Quote  |  Print  |  Notify Moderator
RLS7201 wrote:
pianotuna wrote:
Hi folks,
Don,
Richard
Description
Victron 350 Watt 12 Volt Inverter is designed as a compact pure sine wave inverter to give you a nice clean ac output for sensitive electronics.
Page of 5
