RV.Net Open Roads Forum: Travel Trailers: City water filling fresh tank
 > City water filling fresh tank
augustpilot
Meridian, Idaho
Posted: 02/18/18 06:41pm Link  |  Quote  |  Print  |  Notify Moderator
My trailer fresh tank fills direct on side of trailer. Tank is full. Left for week and turned city water off. Came back today and turned city water on, then while walking outside noticed water coming out the water fill overflow. Water is somehow going under pressure into fresh water tank. The water pump is new. Was working fine until turned off water pressure for week. Help please.
2017 Rockwood 2906WS Ultra Light
2014 Dodge Ram 1500 5.7. 4x4
Firestone Air Lift 1000, Equalizer Hitch
ScottG
Bothell Wa.
Posted: 02/18/18 06:44pm Link  |  Quote  |  Print  |  Notify Moderator
It can only get in the tank through the pump. There is no other avenue from the city water connection to the fresh water tank.
You could:
Replace the pump
Take pump apart and rinse all parts off. This may fix it.
Install another check valve
Install a manual valve
* This post was edited 02/18/18 06:58pm by ScottG *
Scott, Grace and Wesly
2018 Silver Fox 32A - many mods to come!
H0NDA eu2000i
Los Angeles :(
Posted: 02/18/18 06:55pm Link  |  Quote  |  Print  |  Notify Moderator
Using city water only to refill the fresh water tank is the safest method.
2015 Winnebago 2101DS TT & Tahoe LTZ, 300 watts WindyNation solar-parallel & MPPT, Trojan T-125s. TALL flagpole for US flag. Prefer USFS, COE, BLM, NPS, TVA, USF&WS, state & county camps. Bicyclist! 14 year Army vet - 11B40 then 11A - old MOS 1542 & 1560.
Lynnmor
Red Lion
Posted: 02/18/18 07:08pm Link  |  Quote  |  Print  |  Notify Moderator
You may have a valve to pressure fill the tank, if so it needs to be turned off. As above, the check valve in the pump may be faulty.
D.E.Bishop
Eagle Rock, CA
Posted: 02/18/18 07:12pm Link  |  Quote  |  Print  |  Notify Moderator
If the water is trickling out of the overflow, I would direct my attention to the check valve in the pump head. If it is blasting out, your city water fill valve is open.
"I travel not to go anywhere, but to go. I travel for travel's sake. The great affair is to go". R. L. Stevenson
David Bishop
2002 Winnebago Adventurer 32V
95 Suzuki Sidekick 4X4
Stowmaster 5000
Farmboy666
Pisgah Forest, NC
Posted: 02/18/18 08:17pm Link  |  Quote  |  Print  |  Notify Moderator
You could:
Replace the pump
Not true, my tank is filled from city water connection and has nothing to do with the pump, I have to open the tank valve to fill tank or close it to use city pressure.
Artum Snowbird
Campbell River, B.C., Canada
Posted: 02/18/18 09:01pm Link  |  Quote  |  Print  |  Notify Moderator
Take the city water off and run the pump. If flow seems weak and pressure does not build up, you have the valve that others mention. I had one like that. It needs to be in the off position to prevent tank fill, and to allow pump pressure to build up when on pump only. If in the fill position when on pump, water just recirculates back into the tank and out the pump again.
good luck.
Mike and Carole
2012 Winnebago Impulse Silver 26QP
2005 16.6 Double Eagle
2018 Jeep Wrangler JK
previously Snowbird Campers
77rollalong
Brighton Ontario
Posted: 02/19/18 06:38am Link  |  Quote  |  Print  |  Notify Moderator
there should be two check valves, one on the city water between the outside water connection and the main supply lines, and another in the pump itself or between the pump and the main supply lines. sounds like the city water connection is backfeeding through the water pump due to bad check valves in it. which would also give you low pressure when running off the freshwater tank too..
beemerphile1
Ohio
Posted: 02/19/18 09:25am Link  |  Quote  |  Print  |  Notify Moderator
Farmboy666 wrote:
You could:
Replace the pump
Your pump has a check valve, if that check valve fails the tank can fill by flowing backwards thru the pump.
2006 Weekend Warrior FK1900
naturist
Lynchburg, VA
Posted: 02/19/18 10:06am Link  |  Quote  |  Print  |  Notify Moderator
It is also possible that a little bit of rubbish has gotten caught in the check valve on the pump. Since it is a new pump, this is more likely than that the valve is faulty. Try shutting off the city water, turning on the pump, and running a little water out of one of the spigots. A bit o' crud might vacate that check valve and restore normal operation.
