RV.Net Open Roads Forum: Tech Issues: Hydraulic Generators
 > Hydraulic Generators
MEXICOWANDERER
las peñas, michoacan, mexico
Posted: 02/21/18 01:20pm Link  |  Quote  |  Print  |  Notify Moderator
I like my own personal natural gas field and 1 Megawatt Worthington natural gas generator to sell power back to the utility. With enough dehumidifiers, I could get structure humidity down to 20% with 22c. Even the garage which houses my Rolls extended chassis and Oshkosh touring rig.
Nice to dream. I was forced to use a hydraulic test bench to test alternator output curves from 500 RPM to 3,000 RPM. The winner was my 50DN Delco that develops 80 amps at 500 ALTERNATOR RPM.
drsteve
Michigan
Posted: 02/21/18 03:27pm Link  |  Quote  |  Print  |  Notify Moderator
DrewE wrote:
If only there were some mechanical method to increase rotational speed and allow high speed devices to be operated by lower speed motors....
I have heard rumors that such technology exists... I'll have to Google it.
* This post was edited 02/21/18 03:57pm by drsteve *
1991 Palomino Filly PUP
MEXICOWANDERER
Posted: 02/21/18 03:49pm Link  |  Quote  |  Print  |  Notify Moderator
10" driver - 2" driven
Pulleys
One will get you five...
SidecarFlip
SE Michigan
Posted: 02/21/18 04:24pm Link  |  Quote  |  Print  |  Notify Moderator
MrWizard wrote:
doesn't need to be governed
IF
they use a pump powered multiphase alternator head and inverter electronics ?
i think this is a case of a solution looking for a problem
like one post suggested "cost is no object, its about bragging rights"
That was me. Now, if someone gave me one (Earth Roamer), I'd be happy to use it as an RV, but buy one, no way. Just a status symbol for the well to do set.
2015 Backpack SS1500
1997 Ford 7.3 OBS 4x4 CC LB
Chum lee
Albuquerque, NM
Posted: 02/22/18 11:31am Link  |  Quote  |  Print  |  Notify Moderator
They're economical, compact, and they can handle high loads. They've been around and used successfully for years. I'll gladly save you the time/trouble googling it. It's called a . . . . planetary gearset. Typically they are used for gear reduction, but they don't have to be.
Chum lee
Horizon170
GA
Posted: 02/22/18 01:44pm Link  |  Quote  |  Print  |  Notify Moderator
theoldwizard1 wrote:
MrWizard wrote:
run the drive engine, to power a hydraulic pump , too spin a generator
something here doesn't make sense to me
1st and 2nd Law of Thermodynamics.
When you convert one form of energy to another, you can't win. You can't even "break even".
Not trying to argue but most train engines are Diesel over Electric I think.
I would NOT want this setup.
Marvin
Marvin
2010 Coachman Freelander 22TB on a
2008 Sprinter/Freightliner chassis
1995 Geo Tracker (Toad)
