RV.Net Open Roads Forum: Class C Motorhomes: TPMS
Geeze
Iowa
Posted: 02/21/18 10:01am Link  |  Quote  |  Print  |  Notify Moderator
I'm considering adding a tire pressure monitoring system to our Class C mainly so I can monitor tire pressures on our toad. What system do you use if any and which type of sensor works best on the inside duals, flow through or the more compact theft resistant? One manufacturer did not recommend installing the flow through on the toad due to the added length. Thanks
[/i]"Tired but not Retired"
Note: Due to invalid formatting, all formatting has been ignored.
2oldman
Farmington NM
Posted: 02/21/18 11:08am Link  |  Quote  |  Print  |  Notify Moderator
While awaiting a personal response you can search 'tpms' in the box above. It's a popular topic.
Ava
Vancouver Island. BC Canada
Posted: 02/21/18 12:49pm Link  |  Quote  |  Print  |  Notify Moderator
The system I am looking at is called Tire-SafeGuard. They recommended using the flow throughs on the rv and the caps on the toad.
loggenrock
New Hampshire
Posted: 02/21/18 10:44pm Link  |  Quote  |  Print  |  Notify Moderator
TST model 507 - been using their system for about a decade. 6 on coach, 4 on toad. System has "saved" me about 5-6 times, alerting me to a leak before we had any sort of failure.
Two and a hound in a 2015 Coachmen Prism "B+"...pushed by '09 Suby Forester
First 50 done, working on the second pass! Nunavut - we'll see...!
2005-2015 Roadtrek 190P
1993-2005 Northstar Soft-Side TC
1989-1993 Backpacks & Tents!
1967-1977 Family TT's
JumboJet
Tontitown ARKANSAW
Posted: 02/22/18 06:58am Link  |  Quote  |  Print  |  Notify Moderator
What I use and very good system.
wtmtnhiker
New Hampshire
Posted: 02/22/18 07:05am Link  |  Quote  |  Print  |  Notify Moderator
Me too. Tow my car behind my motorhome. Thought I would need a signal booster for the toad but I don't and system has been very reliable. Had it for 4 years now.
bgbassman(bluegrass bass man)
2005 Holiday Rambler Ambassador DP
2012 Chevy Equinox Toad
Geeze
Iowa
Posted: 02/23/18 01:01pm Link  |  Quote  |  Print  |  Notify Moderator
That's for the replies I've decided to go with the new TST 507 with the color monitor.
luvztheoutdoorz1
Lincoln, NE
Posted: 02/25/18 07:44am Link  |  Quote  |  Print  |  Notify Moderator
The ones that I looked at have "flow-through" and "non-flow through" sensors. Which do you recommend?
Linda
Scout, 10 year old Husky/Shepherd
2011 Jayco Greyhawk 26DS
Ava
Posted: 02/25/18 11:46am Link  |  Quote  |  Print  |  Notify Moderator
I think the flow through sensors look too big and clunky for the toad.
loggenrock
New Hampshire
Posted: 02/26/18 09:50pm Link  |  Quote  |  Print  |  Notify Moderator
They didn't have flow-thru when I originally got the system, so non-flow thru for coach and toad. But in reality, I very seldom have to add air, so really a non issue. TST does say you should have metal valve stems, a must for the flow-thru, suggested for the caps. I do have metal stems on the 6 on the coach, but just standard on the toad, and have not experienced any issues. If you remove the anti-theft caps, the actual sensor is really pretty small. I had asked if I needed to re-balance my wheels after adding the sensors and was told no. Haven't experienced any shake or shimmy with them in place, either. ST
