RV.Net Open Roads Forum: Tech Issues: LED Light Conversion Done
 > LED Light Conversion Done
teetah
Moses Lake, WA, US
Posted: 03/06/18 03:22pm Link  |  Quote  |  Print  |  Notify Moderator
All the bulbs have 2 prongs. They don’t fit otherwise.
2002 Rexhall Vision
2014 Ford Focus = toad
Just runnin' footloose and fancy free
tenbear
Northern Vermont, USA
Posted: 03/06/18 03:34pm Link  |  Quote  |  Print  |  Notify Moderator
Another thought, maybe the polarity is reversed on these sockets. Usually this causes the LED lights to just not light, but I would check it anyway.
Class C, 2004/5 Four Winds Dutchman Express 28A, Chevy chassis
2010 Subaru Impreza Sedan
Camped in 45 states, 7 Provinces and 1 Territory
tenbear
Posted: 03/06/18 06:16pm Link  |  Quote  |  Print  |  Notify Moderator
Yet another thought, or thoughts.
1. Measure the voltage at the light sockets, both good and bad.
2. Try one of the lights that worked in the other sockets into the socket that doesn't, see what happens, and vice versa.
3. Do all 3 of the remaining sockets blow the fuse? If so, it's the wiring, not the sockets.
BFL13
Victoria, BC
Posted: 03/06/18 06:39pm Link  |  Quote  |  Print  |  Notify Moderator
You can only get an advantage that matters by going LED if you leave your lights on for a long time. AH has amps and hours in it. So in winter, off grid, with long time darkness, yes you can do better.
In summer with long daylight hours plus all that solar time for the batteries anyway, you will probably get no AH advantage from going LED.
It is all situational. You should do some calculating first. However, with the lower LED prices, this could be less important.
1991 Oakland 28DB Class C
on Ford E350-460-7.5 Gas EFI
teetah
Moses Lake, WA, US
Posted: 03/08/18 03:29pm Link  |  Quote  |  Print  |  Notify Moderator
I put the original bulbs back in all the sockets in the bedroom after one of the new led bulbs did a melt down in the socket. Lights flickered, then I saw smoke coming from the fixture. When I removed the lamp cover the top half of the light fell of onto the bed. Shut the power off and put the old bulbs back in. ??
* This post was edited 03/09/18 01:36pm by teetah *
MEXICOWANDERER
las peñas, michoacan, mexico
Posted: 03/08/18 03:49pm Link  |  Quote  |  Print  |  Notify Moderator
This is a "saner" product, albeit at the negative of having potential radiated noise.
https://www.ebay.com/itm/Auto-RV-Boat-LE........tem4ab0684b80:g:vhgAAMXQfFJROuzP&vxp=mtr
