RV.Net Open Roads Forum: Fifth-Wheels: Titan disc brakes / 2017 GM duramax
 > Titan disc brakes / 2017 GM duramax
djousma
SW Michigan
Posted: 03/02/18 05:16am Link  |  Quote  |  Print  |  Notify Moderator
racer4 wrote:
djousma wrote:
snip ... My brake installer told me that you can even reuse one of the old brake magnets wired inline, and that would also resolve the problem. For Fords, it sounds like the 2017's and up are good.
X2
That is what performancetrailerbraking.com did when he installed mine. The magnet is strapped to the top front of the front storage compartment, near the pin box and hydraulic actuator.
They are the ones that did my upgrade too.
Dave
2016 F350 Lariat 4x4 FX4 SRW CC SB 6.7 Magnetic Metallic
2017 Forest River Cardinal 3850RL
joe puma
DuPage County IL
Posted: 03/07/18 06:56pm Link  |  Quote  |  Print  |  Notify Moderator
my 2011 needed a module.
Wood chip
Nor Cal
Posted: 03/27/18 08:39pm Link  |  Quote  |  Print  |  Notify Moderator
Wood chip wrote:
Does anybody have real life knowledge if the integrated brake controller in a 2017 GM is compatible with Titan brakes electric over hydraulic setup? I have read that im good to go but did see a youtube video of 2016 needing the added module to communicate with the OEM integrated brake controller. Hopefully somebody here has a 2017 GM and has electric over hydraulic disc brakes on their rv.
My Titan Disc brake installation is complete and I can report as others have reported that the EOH adapter is not needed for the 2017. All seems to work fine.
2017 Chevy HD 3500 Dually LTZ D/A combo crew cab / Bilstein 4600's / Ride Rite air bags w remote / 50 gal transfer flow Aux tank / Trailersaver BD5
2015 ORV Glacier Peak 28rks / Titan Disc brakes / MorRide 4000 / Steadyfast stabilizer / Michelin XP Ribs
Wood chip
Nor Cal
Posted: 03/27/18 09:02pm Link  |  Quote  |  Print  |  Notify Moderator
Thought I would share a photo. There were many installations on Youtube showing to install all the calipers the same orientation but later learned they only need to be the same orientation on the same axel. This orientation allows the caliper bolts to be easily accessed and away from the shock mount while doing future brake jobs
* This post was edited 03/27/18 09:08pm by Wood chip *
