RV.Net Open Roads Forum: Fifth-Wheels: towing mileage of trucks
 > towing mileage of trucks
Page of 6
forkedhorn
Oklahoma
Posted: 03/04/18 10:29am Link  |  Quote  |  Print  |  Notify Moderator
Does anyone have a range of MPG for a F-450 dragging a 18,000- 21,000 5er? is it much different from Ram 3500?
ScottG
Bothell Wa.
Posted: 03/04/18 10:38am Link  |  Quote  |  Print  |  Notify Moderator
They are all so close that it just isn't a factor.
Scott, Grace and Wesly
2018 Silver Fox 32A - many mods to come!
H0NDA eu2000i
forkedhorn
Oklahoma
Posted: 03/04/18 10:42am Link  |  Quote  |  Print  |  Notify Moderator
Thanks Scott, kind of figured that. Thinking about a 44 Santa Fe Mobile Suite or a 42RL Luxe and an f-450 instead of the ram.
Artum Snowbird
Campbell River, B.C., Canada
Posted: 03/04/18 10:43am Link  |  Quote  |  Print  |  Notify Moderator
It would take essentially as much fuel for each truck to do the same load. I would estimate 8-11 MPG depending on the depression of the foot pedal on the right.
Mike and Carole
2012 Winnebago Impulse Silver 26QP
2005 16.6 Double Eagle
2018 Jeep Wrangler JK
previously Snowbird Campers
VoodooMedicineMan
Illinois
Posted: 03/04/18 11:14am Link  |  Quote  |  Print  |  Notify Moderator
38 ft 5th 10 towing
14 not towing
05 F350 manual trans
Bill and Joey the dog
ChuckV1
Rochester WA
Posted: 03/04/18 01:43pm Link  |  Quote  |  Print  |  Notify Moderator
40ft Kz 5th wheel weighting in over 13k towing with 2005 F350 automatic DRW CC LB with a 6.0 engine, chip installed used in tow mode an bullet proofed .
11mpg with trailer avg 65mph
14 to 16 if I keep my foot out of it not towing
Devocamper
West Haven CT
Posted: 03/04/18 02:13pm Link  |  Quote  |  Print  |  Notify Moderator
The 450 will have a heavier curb weight before you hitch anything up to it , if the 3500 has the capacity for the trailer it may get a bit better mpg having a somewhat lighter curb weight I think you will find many 3500 models have larger or equal payload ratings than the 450 and probably better mpg when not towing or hauling, the 450 will have higher tow ratings if you need them . Either way the difference is minimal.
08 NU-WA Hitchhiker Discover America 339 RSB Sold
18 Host Mammoth
07 Chevy 3500HD LT1 EXT Cab LB DRW D/A Sold
18 Ram 3500 SLT Crew Cab DRW 4x2 6.4 4.10's
P3driver
Modesto
Posted: 03/04/18 02:43pm Link  |  Quote  |  Print  |  Notify Moderator
I have a 2017 F350, 6.7. My trailer is a 34’ keystone Laredo. 13k+ towing. My mileage varies mountains about 10, flat about 12. The wind also plays a big factor.
2017 F350, 6.7L.
Keystone Laredo 325RL
JaxDad
Greater Toronto Area
Posted: 03/04/18 03:05pm Link  |  Quote  |  Print  |  Notify Moderator
The gearing in the back end has a big impact on it too.
We have a pair of older Fords with the 7.3 mated to the 6 spd. standard, 1 is an F350, the other is an F550. Both have the same chip and air box setup, and have nearly the same mileage on them.
The 350 has 3.55’s in the rear end, the 550 has 5.13’s in the back. I don’t think I’d care to find out how fast I’d need to go to hit the governor in the 350, I know it’s at 70 mph in the 550, at that speed the 350 is just chugging along.
I suspect the Ram would have 3.73’s and the F450 would have 4.10’s, maybe even a higher ratio.
Cummins12V98
on the road
Posted: 03/04/18 03:47pm Link  |  Quote  |  Print  |  Notify Moderator
Why do you think you need a 450? If you are stuck on Ford a 17 or newer 350 will do just fine!
I tow as much or more than your rig will weigh with my RAM 3500 at 33k combined or 35 if double towing my Motor Cycle trailer with two Cruisers.
Pretty hard to beat a straight 6 for mileage.
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
Page of 6
