RV.Net Open Roads Forum: Class A Motorhomes: Catastrophic Bearing Failure
 > Catastrophic Bearing Failure
Old_Spirit
Orlando, Florida
Posted: 03/04/18 11:39am Link  |  Quote  |  Print  |  Notify Moderator
Has anyone experienced catastrophic bearing failure? That is, bearing failure that destroys the bearing without warning. The first evidence that something is wrong a gunshot-like noise and ear piercing squeal.
rgatijnet1
Posted: 03/04/18 11:43am Link  |  Quote  |  Print  |  Notify Moderator
Lots of bearings. Are you talking front wheel bearing? Usually a catastrophic front wheel bearing failure also destroys the spindle.
ScottG
Bothell Wa.
Posted: 03/04/18 11:45am Link  |  Quote  |  Print  |  Notify Moderator
If a wheel bearing, no, not normal.
but with our hearing going as we get older, it probably could make noise we don't notice.
Either that or a long downhill brake application melted the seals.
Or you're talking about a completely different bearing.
Scott, Grace and Wesly
2018 Silver Fox 32A.
H0NDA eu2000i
SidecarFlip
SE Michigan
Posted: 03/04/18 11:56am Link  |  Quote  |  Print  |  Notify Moderator
I make it a habit of feeling all my spindles for excess heat when feeling the tires for excess heat during a trip. As a rule wheel bearings don't just fail right now, they fail gradually accompanied by noise...and excess heat.
Of course making sure the preload is correct and timely service (repack and inspection) always is better than burning one up.
2015 Backpack SS1500
1997 Ford 7.3 OBS 4x4 CC LB
77rollalong
Brighton Ontario
Posted: 03/04/18 12:06pm Link  |  Quote  |  Print  |  Notify Moderator
standard tapered roller bearing i have seen very seldom fail, but I have seen a few so i know it does happen, most time it has messed up the spindle, but have replaced 100's of hub asmb. over the years, and have seen quite a few of those fail completely as well on customers cars and trucks..
path1
Varies with weather
Posted: 03/04/18 12:16pm Link  |  Quote  |  Print  |  Notify Moderator
I think heat would be first sign.
gbopp
The Keystone State
Posted: 03/04/18 03:24pm Link  |  Quote  |  Print  |  Notify Moderator
path1 wrote:
I think heat would be first siugn.
I agree but, I don't check my bearings for heat very often. I had a wheel bearing go out on my car years ago. The first indicator that something was wrong was a rumbling sound.
The OP didn't specify the type of bearings?
Wherever I happen to park
Posted: 03/04/18 04:23pm Link  |  Quote  |  Print  |  Notify Moderator
Only once, on a bicycle, the symptom was head over handlebars as the bike flipped forward.. OUCH.. Thankfully I was much younger then.
NOW I Lubricate Lubricate, Lubricate to excess.
Home is where I park it.
rgatijnet1
Posted: 03/04/18 04:26pm Link  |  Quote  |  Print  |  Notify Moderator
That is why I love the wet bearings I have on my coach. A quick glance and I can tell if the oil level is OK.
jplante4
Cape Cod
Posted: 03/04/18 05:23pm Link  |  Quote  |  Print  |  Notify Moderator
We get a few (dozen) in the store every year, all boat trailers and all used twice a year - "rode hard and put away wet". No greasing, no maintenance, salt water.
Jerry & Jeanne
1996 Safari Sahara 3530 - 'White Tiger'
CAT 3126/Allison 6 speed/Magnum Chassis
2014 Equinox AWD / Blue Ox
