RV.Net Open Roads Forum: Class A Motorhomes: Slide self retracting....
 > Slide self retracting....
Jim@HiTek
Gresham, OR, USA
Posted: 03/04/18 08:05pm Link  |  Quote  |  Print  |  Notify Moderator
I've seen this happen previously with my slides but it's rare...my bedroom slide, the slide on the drivers side that carries the closet, will occasionally retract itself. The LR slide will also do that but it's even rarer. I've discovered it after it has retracting 1/2" to up to 5". It always goes right back out where it belongs when I press the extend switch.
Today, I found it had retracted about 4". Nothing weird going on, no strange noises from the slide or system, the jacks didn't move so the RV is still level, the LR slide didn't retract any. Moderate type winds coming 90 degree angle from the slide but I've not known wind to do that before that I recall.
It's a HWH hydraulic system that also operates the jacks. No leaks that I can detect. Details of the RV in signature.
Any ideas?
Jim@HiTek
Have shop, will travel!
Visit my travel & RV repair blog site. Subscribe for emailed updates.
Winnebago Journey, '02
Cat 330HP Diesel, 36.5', two slides.
MountainAir05
New Mexico
Posted: 03/04/18 08:56pm Link  |  Quote  |  Print  |  Notify Moderator
if you control valve solenoids is leaking I can see it doing that. This is why I say that. My slide HWH system was stuck one time and I was having a hard time to get to the bolt to unlock from shaft. Someone show me how to release the pressure on the system and we just push it in.
smlranger
Virginia
Posted: 03/05/18 04:42am Link  |  Quote  |  Print  |  Notify Moderator
Suspect leaking retract solenoid. HWH sells rebuilt solenoids and R&R on your coach is pretty easy.
2007 Country Coach Allure 470, Cummins ISL 425; 2014 Ford F150 Super Crew toad. SMI Air Force One braking system. Lucy the rescued lab/springer mix; Dixie rescued beagle mix. Glen Allen, VA
dougrainer
Carrolton, Texas
Posted: 03/05/18 05:43am Link  |  Quote  |  Print  |  Notify Moderator
With no external leaks, one of the 2 slide solenoids is leaking internally. Under warranty, HWH replaces both the Extend and Retract. You can also manually open both solenoids and run the pump for about 15 to 20 seconds. Sometimes debris gets stuck in the needle valve and doing this flushes it out. Doug
PS, NOTHING external can move a HWH slide when it is extended or retracted.
GHOST1750
THE GOLDEN STATE My taxes help keep it that way!!
Posted: 03/05/18 10:31pm Link  |  Quote  |  Print  |  Notify Moderator
Did you ever suspect your motor home may be haunted ? Sorry, couldn't resist.
Just Don and a Chiuahua called Dulce
2003 39' Tradewinds LE
2002 Cavalier tow
Korean Veteran, USAF
FMCA F357981
CC4C
GOOD SAM
Life is a journey, not a destination !
Jim@HiTek
Gresham, OR, USA
Posted: 03/06/18 12:57pm Link  |  Quote  |  Print  |  Notify Moderator
Ghosts?? Why yes, I have thought that. Not very long, mind you, but I thought of it.
OK, so everyone thinks it's a leaky valve, or at least a valve with debris in it. Perhaps debris would explain it's intermittent retraction qualities better than assuming an actual failure of a component.
Now I'd like to ask for some advice. Anyone have a link to a description of how you remove these parts?
Will oil spray out under pressure when I remove a valve or does that only happen when the pump motor is running? Should I drain the tank? I have a small car's oil drain pan I can put below the manifold, but is that enough? Should I get a huge pan?
dougrainer
Carrolton, Texas
Posted: 03/06/18 03:39pm Link  |  Quote  |  Print  |  Notify Moderator
Once you release the Extend and Retract solenoids manually, the system will equalize for that room and no oil will squirt out. Just a dribble. They unscrew from the manifold. Doug
https://www.hwhcorp.com/mp849999.pdf
Weldon
Posted: 03/07/18 06:35pm Link  |  Quote  |  Print  |  Notify Moderator
I had a similar situation and it turned out to be a leaking hose for one slide. This was a hose from the pump to the front slide. Unfortunately was not long til I had to replace both lines going to the rear slide which was 23' in length.
Was a expensive repair.
Perhaps Doug's suggestions will work for you.
AlaskaShooter
Twisp, WA
Posted: 03/08/18 12:51am Link  |  Quote  |  Print  |  Notify Moderator
Can the solenoids leak back into the system allowing the slide to retract and not actually be leaking outside the system?
2006 F-550, Crew cab, 4x4 w/factory bed getting 12 mpg @ 50,000 miles
2006 Lance 1191
2006 Wells Cargo 14' Cycle Wagon
2017 Grand Design 5th wheel with EezTire TPMS
2017 F-450 4x4 crew cab King Ranch
dougrainer
Carrolton, Texas
Posted: 03/08/18 05:53am Link  |  Quote  |  Print  |  Notify Moderator
Yes, that is what I told him in my first post. Doug
