RV.Net Open Roads Forum: Fifth-Wheels: Fifth Wheel Lube Plate -- Who uses one?
 > Fifth Wheel Lube Plate -- Who uses one?
Old-Biscuit
Verde Valley
Posted: 03/05/18 02:22pm Link  |  Quote  |  Print  |  Notify Moderator
TenOC wrote:
I am new to 5th Wheel. How many of you use a Lube Plate on the 5er? I got one and it appears to add too much space (height) for my hitch to lock the kingpin in place without some effort on my part.
Are they necessary?
If not a lube plate what do you do?
Yes .....have since 2005
What brand is your hitch.
Some will NOT work with a plate
Some you will need the 1/8" plate
So what is your hitch?
bama2
alabama
Posted: 03/05/18 02:57pm Link  |  Quote  |  Print  |  Notify Moderator
have used the same plate for 4 years. never had it to buckle or fold up. we have the b & w hitch.
memtb
Wyoming
Posted: 03/05/18 02:59pm Link  |  Quote  |  Print  |  Notify Moderator
Have used them since the early’90’s!
Todd & Marianne
Miniature Schnauzer's - Sundai, Nellie & Maggie Mae
2007 Dodge Ram 3500, 6.7 Cummins, 6 speed manual, 3.73 ratio, 4x4
2004 Teton Grand Freedom, 39'
2007 Bigfoot 30MH26Sl
sbergherr
Posted: 03/05/18 03:22pm Link  |  Quote  |  Print  |  Notify Moderator
We use one as well. Don't really like cleaning grease off my shirt, I do enough of that at work....
Halmfamily
Munford, AL
Posted: 03/05/18 05:32pm Link  |  Quote  |  Print  |  Notify Moderator
On our second one, killed our first one when it slid down a little and I didn't notice until I nearly bent it in half while hooking uo.
2008 GMC Sierra 3500 SLT DRW D/A 4x4 (Big All)
2006 Ford F350 PSD SRW King Ranch 4x4 (Henry) (Sold)
B&W Companion, 90 Aux Fuel Tank, Scan Gauge II, Curt f/m hitch, Swagman XC
2015 Forest River Sierra 360 PDEK
DW Diane, DS Michael, FB Draco and Sabian
Chiefcpo
Huntsville, Alabama
Posted: 03/05/18 05:53pm Link  |  Quote  |  Print  |  Notify Moderator
Some sliders hitches have a catch plate, they are out of luck. Used the same one part timing 10 years
Mike E.
Coquitlam, British Columbia
Posted: 03/05/18 07:20pm Link  |  Quote  |  Print  |  Notify Moderator
I just put one on my 5th.
Going to be using a B&W Patriot - compatible??
Lantley
Ellicott City, Maryland
Posted: 03/05/18 07:33pm Link  |  Quote  |  Print  |  Notify Moderator
wrgrs50s wrote:
The only other option is to gob grease on the 5th wheel which is really messy.
Although I prefer a lube plate as well. I use 1/8" with my Hensley BD3
Slip plate is a very viable option that is not as messy. I keep a can handy.
2019 Duramax w/hips,12 Open Range,Titan Disc Brake
H-head TPMS,BD3,RV safepower
Ox Bedsaver,RV760 w/BC20,Glow Steps
BakFlip,RVLock,5500 Onan LP,Prog.50A surge,keyless RV Lock
Correct Trax,Splendide
Cummins12V98
on the road
Posted: 03/05/18 10:42pm Link  |  Quote  |  Print  |  Notify Moderator
Easy fix if it does not stay up in place. Lay on hard surface. Hit the edges of the hole with a hammer. This will decrease the diamiter and make the plate stay in place.
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
edatlanta
Jennings Ferry Campground-Camp Host, Akron, AL
Posted: 03/06/18 04:33am Link  |  Quote  |  Print  |  Notify Moderator
Durb wrote:
Most lube plates are 1/4" thick. They do make 1/8" thick plates if needed. In my mind they are a lot better than dealing with grease, certainly cleaner.
Yep. Mine has been in service since 2010. They last forever.
Ed
KM4STL
2006 GMC 2500HD CCSB 4x4 Duramax/Allison, Titan 52 gallon fuel tank, Prodigy Controller, B&W Companion Hitch, Progressive Industries EMS-PT50C, TST Systems 507 TPMS
2010 Jayco Designer 35RLTS,Cummins/Onan RV QG 5500 EVAP
Fulltime since 2010
