RV.Net Open Roads Forum: Fifth-Wheels: Fifth Wheel Lube Plate -- Who uses one?
 > Fifth Wheel Lube Plate -- Who uses one?
Halmfamily
Munford, AL
Posted: 03/06/18 04:39am Link  |  Quote  |  Print  |  Notify Moderator
Cummins12V98 wrote:
Halmfamily wrote:
On our second one, killed our first one when it slid down a little and I didn't notice until I nearly bent it in half while hooking uo.
Easy fix if it does not stay up in place. Lay on hard surface. Hit the edges of the hole with a hammer. This will decrease the diamiter and make the plate stay in place.
I didn't even think about that, thanks for the tip.
2008 GMC Sierra 3500 SLT DRW D/A 4x4 (Big All)
2006 Ford F350 PSD SRW King Ranch 4x4 (Henry) (Sold)
B&W Companion, 90 Aux Fuel Tank, Scan Gauge II, Curt f/m hitch, Swagman XC
2015 Forest River Sierra 360 PDEK
DW Diane, DS Michael, FB Draco and Sabian
lmpres
New Hampshire
Posted: 03/06/18 05:04am Link  |  Quote  |  Print  |  Notify Moderator
I always use one, and keep a spare in the cargo area in case it falls off when sitting, or someone decides to swipe it....
2112
Posted: 03/06/18 05:07am Link  |  Quote  |  Print  |  Notify Moderator
I use a lube plate and grease my pin and jaws.
2013 KZ Durango 2857
Likes to tow
Huntington WV
Posted: 03/06/18 05:47am Link  |  Quote  |  Print  |  Notify Moderator
I found it made hitching up harder. The square front plate on the fifth wheel hits the hitch and aligns or cams it to the level position so the pin goes in easity. With the rounded front on lube plate this action never happened and I noticed the pin going in to an unlevel hitch. Took it off, problem went away.
Campinfan
Washtenaw County, Michigan
Posted: 03/06/18 06:10am Link  |  Quote  |  Print  |  Notify Moderator
Add me to the list of users.
______________________
2016 F 350 FX4 4WD,Lariat, 6.7 Diesel
41' 2018 Sandpiper 369 SAQB
Lovely wife and three children
Dave H M
IL
I think in theory the lube plate is a god idea.
In reality I have never seen the need for one.
Seemed like it took forever to even wear thru the black paint.
I usually hit my hitch with a shot of whatever stuff from the aerosol can and go.
There is no end to the aftermarket gizmos .
BTW i hug my DW not my hitch. [emoticon] It stays hanging on the king pin. [emoticon]
* This post was edited 03/06/18 07:19am by Dave H M *
TenOC
On the road -- Full time
Posted: 03/06/18 07:00am Link  |  Quote  |  Print  |  Notify Moderator
I am not sure I understand. Does any one cut off the rounded front of the lub plate so it is square with the front plate?
Please give me enough troubles, uncertainty, problems, obstacles and STRESS so that I do not become arrogant, proud, and smug in my own abilities, and enough blessings and good times that I realize that someone else is in charge of my life.
Travel Photos
NorthernNeck,VA
Montross, Va.
Posted: 03/06/18 08:50am Link  |  Quote  |  Print  |  Notify Moderator
I bought two and keep one as a spare. Never have had to use the spare.
Jimmy & Kathy
Northern Neck, VA.
2013 Landmark San Antonio
2016 F350
2005 Ford F350, DRW, Diesel (SOLD)
2005 King of the Road "Royal Villa" 34BW (SOLD)
"The amateur does it 'til he gets it right. But the expert does it until he can't get it wrong."
Cummins12V98
on the road
Posted: 03/06/18 09:25am Link  |  Quote  |  Print  |  Notify Moderator
May I ask what hitch you are using?
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
Cummins12V98
on the road
Posted: 03/06/18 09:27am Link  |  Quote  |  Print  |  Notify Moderator
If needed cut out the bottom of a 5 gallon bucket.
