RV.Net Open Roads Forum: Egg Poaching And Energy Versus Ease Of Use
 > Egg Poaching And Energy Versus Ease Of Use
Almot
out there
Posted: 03/07/18 01:27pm Link  |  Quote  |  Print  |  Notify Moderator
Naio wrote:
Like, for instance, I wonder how hot water would get in a dark (e.g. anodized) saucepan with a glass lid, in the sun....
In summer, outside water tank gets hot enough to want to enclose it in plywood or cement blocks. I suspect that locals don't have time for showering in daytime, and do this after dark when their (mostly exposed) roof tanks cool down. Or they just take it in stride, que sera sera.
But not hot enough to simmer eggs.
Summer isn't 12 months a year, even in Mexico.
MEXICOWANDERER
las peñas, michoacan, mexico
Posted: 03/07/18 01:40pm Link  |  Quote  |  Print  |  Notify Moderator
allowing cold water tap water to run long enough to avoid scalding is the mark of living in the tropics.
I have a marker: If I leave an air conditioned room and the back of my head (hair) gets sopping wet in under 10-seconds then the weather can be deemed "uncomfortable" in my book.
Fans and kitchen stove cooktop flames hate each other. When a pot of water is allowed to boil and instant sweat stings the eyes then the kitchen environment is uncomfortable. I pressure cook because I can run like hell after turning the stove's knob.
I guess I spend the seventy dollars and get a stove top egg poacher.
Naio
Snug as a bug in a rug
Posted: 03/07/18 02:24pm Link  |  Quote  |  Print  |  Notify Moderator
$70 seems insane! No wonder you are looking for other options [emoticon]
3/4 timing in a DIY van conversion. Backroads, mountains, boondocking, sometimes big cities for a change of pace.
bpounds
Senile, er I mean
Posted: 03/08/18 10:58am Link  |  Quote  |  Print  |  Notify Moderator
MrWizard wrote:
i guess i do it wrong
when i want poached eggs, i use cooking oil in the fry, more oil than for frying
i spoon the oil over the top of the eggs, cook just long enough to make the egg white solid and not cook the yolk
I would call that basted. Usually with bacon grease, but oil works too. I don't think it would work well with water.
This isn't true poaching, but we use something like this. Goes in a pan with a little water, this thing sits in the water, and basically steams the eggs. We've got a few different ones. Works well for us.
https://www.amazon.com/HIC-Non-Stick-3-Egg-Poacher-Insert/dp/B001B18MJ8/ref=sr_1_3?ie=UTF8&qid=1520531545&sr=8-3&keywords=egg+poacher+insert
To get eggs like McDonalds or Jack in the Box, we use rings like this. Also works well on a grill, or of course any pan. Would be easy to make your own, for the ultra budget minded.
https://www.amazon.com/Nonstick-Egg-Ring-Happy-Sales/dp/B0031VXS3Q/ref=sr_1_9?s=kitchen&ie=UTF8&qid=1520531594&sr=1-9&keywords=egg+ring
2006 F250 Diesel
2011 Keystone Cougar 278RKSWE Fiver
MEXICOWANDERER
Posted: 03/08/18 11:44am Link  |  Quote  |  Print  |  Notify Moderator
Even the insane priced poachers have bitter comments about how eggs glue themselves to the cups. Phooey even they have beautiful heavy pans but no easy way to lift the cups out. Putting lifting pivot rings as a bail is beyond their mental capacity
Here Goes...
  • Copper bottom plate for heat conduction
  • Stainless pan with silicone handle
  • Pyrex lid with silicone lift knob
  • Heavy cups with integral lift tabs
  • Heavy cup coating using coating like that speckled stuff on good fry pans
  • Concentric rings on bottom of pan
  • Center ring for one egg, next larger for 2, then a third and a fourth
  • Water measurement
  • Saves energy saves water
Good luck with intelligent design these days. Yes the pan would be pricey. No they do not exist at any price. The idiots insist on having egg cups that overflow with anything larger than a a small egg. Are extra large cups forbidden? Pretty stupid for a seventy dollar poacher
* This post was edited 03/08/18 11:58am by MEXICOWANDERER *
bpounds
Senile, er I mean
Posted: 03/08/18 11:49am Link  |  Quote  |  Print  |  Notify Moderator
Pam.
or
Pamo.
MEXICOWANDERER
Posted: 03/08/18 12:18pm Link  |  Quote  |  Print  |  Notify Moderator
Or less disastrous Kirkland Signature spray. The 70 dollar poacher maker seemingly uses the same coating as the George Foreman griddle -- near junk.
OK -- enough poacher preaching
Almot
out there
Posted: 03/08/18 01:50pm Link  |  Quote  |  Print  |  Notify Moderator
  • Water measurement
Somebody outside China has to make it first.
For the sake of argument, let' say he would. It will be expensive - by Walmart/Amazon standards, and few months later clones will flow in numbers, at 1/4 of the cost. Original guy will go out of business, cheered by m.oronic speeches on globalization, progress etc. But you will have clones. Bottom won't be real copper, handle will be vinyl, some other details might be correct as long as it doesn't cost more then 0.1 yuan per item, and net result will be what you see. What else is new...
MEXICOWANDERER
Posted: 03/08/18 04:18pm Link  |  Quote  |  Print  |  Notify Moderator
Yet they keep selling hideously expensive style over function cookware. The one that gets me is the one-cup cartridge coffee makers. Whopper expensive, crummy tasting charges and yotta see how much power these babies suck overnight just waiting for a fast preparation of a cup of coffee in the morning.
I purchased a pricey heavy-sukkah 10" fry pan with that speckled anti-stick coating I mentioned earlier. Tilt the cooked food and it damned near jumps out of the pan. The prizefighter griddle has humps and berms that make prying cooked food out of it a real test of patience. It did this right out of the box.
The Chinese are giggling
The Big Noses are content buying garbage.
A two quart empty pot weighs three pounds stainless steel. This is intelligent? Hate to tell you what the five quart pot weighs.
These things are the end product of a society that does not have a clue as to what they are doing (for a foreign market). They go home and cook rice and fish in a vessel that has never seen the light of day over here.
"Here ya go, honorable guests! Five Alarm chili and beans, mashed potatoes and hamburger gravy followed by pie a la mode!"
I'd MUCH rather see our kind of stuff built in Mexico than China. Fat chance of having it built inside our borders...Cheap At Any Price...rules.
MrWizard
Traveling
Posted: 03/08/18 05:52pm Link  |  Quote  |  Print  |  Notify Moderator
your right 'basted' not poached, i like using bacon grease
another scrambled 'data sector' in the ole 'organ memory module'
Radiate The Happy
1997 F53 Bounder 36s
