RV.Net Open Roads Forum: Best method to Repair Rubber Roof Tear???
 > Best method to Repair Rubber Roof Tear???
spoon059
Just north of D.C.
Posted: 03/05/18 07:08pm Link  |  Quote  |  Print  |  Notify Moderator
darleyhavidson wrote:
When you applied the Eternabond tape, did it wrap over the rounded edge of the roof? Would the thickness of tape affect how rain water would drain (or not drain) to the gutters?
I did this on my last trailer and plan to do it to my current trailer. I run a single line of 2" Eternabond from front to rear, over the rounded edge and into the gutter. The tape didn't affect anything about draining into the gutter or draining away from the gutter.
That rounded edge is a pretty delicate part of the roof. If you drag a power wire or hose over it, its the easiest to puncture. That tape is pretty durable though and will seal that hole and help prevent other holes.
I know you don't want to get into it, but I hope you get some sort of remuneration from the delivering dealer!
2015 Ram CTD
2015 Jayco 29QBS
ScottG
Bothell Wa.
Posted: 03/05/18 07:17pm Link  |  Quote  |  Print  |  Notify Moderator
ScottG wrote:
Bad place for Dicor or any other caulk imho.
Eternabond will outlast the roof.
I have never used Dicor before. Is it similar to caulk/sealant?
Yeah, it's a caulk that is specifically designed for rubber roofs.
It's works well for certain applications but on a corner like that the tape is best.
Scott, Grace and Wesly
2018 Silver Fox 32A - many mods to come!
H0NDA eu2000i
gbopp
The Keystone State
Posted: 03/05/18 07:19pm Link  |  Quote  |  Print  |  Notify Moderator
gbopp wrote:
One option is to run a strip of eternabond along the entire edge of the roof, both sides.
I did that on our 96 Southwind to cover some rips and worn areas. I applied it about 1/2 inch onto the rain gutter..
And, I applied Dicor along the edge of the Eternabond.
Yes, I wrapped the E/bond over the curve on the roof. I didn't notice any difference in water running into the rain gutters. Use a roller when applying the Eternabond. I like the steel rollers, I think they do a better job, some like wooden rollers. Yes, I tried both.
Mortimer Brewster
Northern Illinois
Posted: 03/05/18 07:52pm Link  |  Quote  |  Print  |  Notify Moderator
Mortimer Brewster wrote:
I had a very similar tear in our roof. Follow Eternabond’s directions for cleaning the surface. Be sure to use a roller after applying. Scott is correct - it will outlast your roof.
Ok, I will give the Eternabond a shot. I just wish it blended with the roof better. When I apply it, it will stand out like a sore thumb since it is on the edge of the roof.
d1
After a while, the only time you will notice it is when you are inspecting the roof.
wilber1
Abbotsford B.C.
Posted: 03/05/18 08:20pm Link  |  Quote  |  Print  |  Notify Moderator
Eternabond works great. Make sure you prep it according to the directions and you should have a permanent fix.
"Never trust a man who has not a single redeeming vice" WSC
2011 RAM 3500 SRW
2015 Grand Design Reflection 303RLS
darleyhavidson
North Dakota
Posted: 03/05/18 09:07pm Link  |  Quote  |  Print  |  Notify Moderator
With my gutter, I have this rubber/vinyl rail above the gutter which I think helps attach the roof membrane to the camper. In the attached picture it is the piece with the blue arrow pointing at it. Do you see any issue with the Eternabond being placed over it?
The rubber/vinyl trim is not solid and has space behind it, kind of like an air cushion. So, rolling the Eternabond over it to getting it to attach might be a little problematic.
westend
Shorewood, MN
Posted: 03/06/18 03:08am Link  |  Quote  |  Print  |  Notify Moderator
The best solution to this repair is to use Eternabond Webseal Tape. I will conform to any radius surface. The Webseal tape needs to be covered with a sealer or paint. Eternabond Roofseal tape can also be used but the top vinyl layer will tend to interfere with sharp radii. I have both on my trailer roof, the Webseal is installed over the edge trim's vinyl screw cover.
'03 F-250 4x4 CC
darleyhavidson
North Dakota
Posted: 03/06/18 09:03am Link  |  Quote  |  Print  |  Notify Moderator
If I use the Webseal tape, will the sealer/paint, that needs to be applied, be able to withstand being applied to a vertical surface without sagging/dripping? Would you use Webseal into the gutter area or stop short?
spoon059
Just north of D.C.
Posted: 03/06/18 11:03am Link  |  Quote  |  Print  |  Notify Moderator
Yup, looks similar to mine. I kept my tape just barely touching the top edge of that trim. That trim just covers the screws that hold the gutter to the wall, FYI.
darleyhavidson
North Dakota
Posted: 03/06/18 11:51am Link  |  Quote  |  Print  |  Notify Moderator
Ok, thanks for the info. And did you follow up the with Dicor sealant at the seam between the Eternabond and the trim edge? Did you use 2" wide or 4" inch wide Eternabond. The more videos I watch, plus the info on this forum, is giving me more confidence to just do the entire roof perimeter (which should give me piece of mind over the next several years of camper ownership).
