RV.Net Open Roads Forum: General RVing Issues: Is 20 amp service enough?
 > Is 20 amp service enough?
Mncst
MN
Posted: 03/05/18 05:40pm Link  |  Quote  |  Print  |  Notify Moderator
We are looking at a campground that offers only 20 amp service. Is this enough to safely run our AC, TV and microwave?
Ranger Smith
Wherever the rig is parked
Posted: 03/05/18 05:43pm Link  |  Quote  |  Print  |  Notify Moderator
Maybe not all at the same time. Must be a real old campground
Where we are now
Amateur Radio Operator WW1SS Icom 7610 and Icom 7100
Steve and Joy
2012 Winnebago Tour 42JD . . . 2016 Ram 1500 4x4 Toad
Cooper ... The Doodle,
Baby and Kissie the new Chihuahuas and Lucy the New Biewere Yorkie
Crazy Ray
Monroe,La
Posted: 03/05/18 05:44pm Link  |  Quote  |  Print  |  Notify Moderator
Not all at the same time
RET ARMY 1980,"Tiny" furkid, Class A, 2007 Bounder 35E, Ford V10 w/Steer Safe, 4 6V CROWN,GC235,525W Solar Kyocera, TriStar 45 Controller,Tri-Metric 2020,Yamaha 2400, TOW CRV. Ready Brake. "Living Our Dream" NASCAR #11-18-19-20- LOVE CO,NM,AZ
DrewE
Vermont
Posted: 03/05/18 05:49pm Link  |  Quote  |  Print  |  Notify Moderator
It should be enough to run your AC (and pretty much nothing else) or your microwave (and not much else). I would suggest putting the fridge on propane assuming you have an absorption fridge. It would not be enough to run the AC and the microwave simultaneously, or either one with an electric water heater element or other high-draw appliance.
Televisions these days use not much power at all, so no concerns there...unless it's something unusual like a projector, or a really old TV.
time2roll
Posted: 03/05/18 05:54pm Link  |  Quote  |  Print  |  Notify Moderator
Have something to monitor voltage stays above 105 in the RV.
Put the fridge and water on propane only.
Let the batteries charge for a couple hours before you try anything big.
675w Solar pictures back up
azdryheat
Tucson, AZ
Posted: 03/05/18 05:59pm Link  |  Quote  |  Print  |  Notify Moderator
No. Even 30 amps isn't enough for the AC and microwave in some cases.
2013 Chevy 3500HD CC dually
2014 Voltage 3600 toy hauler
2011 Harley Ultra Limited
Mike LeClair
Wetaskiwin, Alberta
Posted: 03/05/18 06:04pm Link  |  Quote  |  Print  |  Notify Moderator
You certainly wouldn't have much fun as you would be continually stressing about power usage and running outside often to reset the breaker on the shore post. It can be done, however, as we did it in our Cougar 318SAB for a one week period. Again, not much fun. Can you get by w/o using the AC?
Cheers!
Mike
Something Old, Something New
2012 F350 SRW, 6.7l Powerstroke, 3.55's front and rear.
2008 Fleetwood Regal 325RKTS
Mike, Carol and our 4 legged "furry child" Kenzie Shweenie Tod
Isaac-1
SW Louisiana
Posted: 03/05/18 06:09pm Link  |  Quote  |  Print  |  Notify Moderator
As a general rule on 120 volt 20 amp hookup, you can run 1 high draw appliance, along with 1 medium draw appliance, or several small low draw appliances. The Microwave, Air conditioner or electric water heater are all high draw, and draw around 12 amps each while running. The refrigerator is a medium size appliance and draws about 3.5 - 4 amps, battery chargers are medium to high depending on how low your batteries are they will typically draw 4 - 8 amps when charging. LED lights are very low, drawing a small fraction of an amp each, all lights in a typical RV if LED lights will likely add up to under 1 amp. Modern flat panel televisions will draw less than 1/2 an amp, maybe as little as 1/4 amp.
Los Angeles :(
Posted: 03/05/18 06:13pm Link  |  Quote  |  Print  |  Notify Moderator
Who’d want to camp without AC, TV and microwave?
My goodness next you’d be talkin’ about internot.
2015 Winnebago 2101DS TT & Tahoe LTZ, 300 watts WindyNation solar-parallel & MPPT, Trojan T-125s. TALL flagpole for US flag. Prefer USFS, COE, BLM, NPS, TVA, USF&WS, state & county camps. Bicyclist! 14 year Army vet - 11B40 then 11A - old MOS 1542 & 1560.
ScottG
Bothell Wa.
Posted: 03/05/18 06:40pm Link  |  Quote  |  Print  |  Notify Moderator
The problem I see with those kind of places is that the 20A receptacles are just about always worn out. The connection is so bad that they can't even carry their specified load.
Scott, Grace and Wesly
2018 Silver Fox 32A.
H0NDA eu2000i
