RV.Net Open Roads Forum: Travel Trailers: My Inverter Install
 > My Inverter Install
thetechie01
Olympia, WA
Posted: 03/05/18 10:06pm Link  |  Quote  |  Print  |  Notify Moderator
So I've been looking and reading on inverters and different installs and such, and I thought I'd share my install!
I decided to get a Pure Sine, and found a great deal on Amazon for a 1500w/3000w peak for $180 and got to work.
I mounted it in my battery box:
Hooked it up and powered it up:
I added a panel mount 120v plug on the side of my battery box to plug in to without having to open the box top:
Plugged in and ready to go!
I decided to go this route rather than getting a hard wired one with all the auto switching, simply because of cost. I just have to make sure I pull the charging fuses in the trailer before hooking up to it. We used it for the first time this weekend at a dry campground and it was awesome. We could go all night with things powered and running and still were at 11.8V in the morning. I then used the inverter generator with a battery charger to charge back up for about an hour, and good to go for the day.
Next up is some solar power so I don't have to take the generator!
* This post was edited 03/05/18 10:17pm by thetechie01 *
2007 Coachmen 31DSB pulled by a 2012 F350
marcsbigfoot20b27
Phx
Posted: 03/05/18 11:12pm Link  |  Quote  |  Print  |  Notify Moderator
It’s great having 110 without the gen running.
I would be cautious about hydrogen gas buildup near the inverter.
Also 11.8 volts is getting into battery damage territory.
SoundGuy
S Ontario
Posted: 03/05/18 11:47pm Link  |  Quote  |  Print  |  Notify Moderator
Hate to be a Debbie Downer but there's no way I'd mount any electrical device, especially in inverter, in the same closed compartment right beside a set of flooded batteries that during normal operation produce potentially explosive hydrogen gas. [emoticon]
Chad Heiser
Santa Rosa
Posted: 03/06/18 12:07am Link  |  Quote  |  Print  |  Notify Moderator
What sound guy said is correct. The inverter should not be in the same box as the flooded batteries. It is an explosion hazard. Your outlet also needs to be covered and protected from weather/etc. It should be a GFCI outlet with proper cover on the exterior like that.
azrving
Quartzsite
Posted: 03/06/18 04:29am Link  |  Quote  |  Print  |  Notify Moderator
11.8 and charged up in an hour? You have some amazing stuff there. Good looking job.
Roadpilot
NH Seacoast
Posted: 03/06/18 05:18am Link  |  Quote  |  Print  |  Notify Moderator
What they said!!
Millennium Prevost 2018
2013 Chevy Avalanche Black Diamond
2013 Chevy Tahoe
HD 2015 Ultra Limited Low (Mine)
HD 2016 Triglide (DW)
Cruiser Caddie motorcycle lift and 24' Stacker
Roadpilot
NH Seacoast
Posted: 03/06/18 05:19am Link  |  Quote  |  Print  |  Notify Moderator
What he said.!!
scrubjaysnest
Big Bend area
Posted: 03/06/18 06:13am Link  |  Quote  |  Print  |  Notify Moderator
Only two thoughts:
That inverter is not intended to be installed in an explosive environment.
Click for the proper way to wire two batteries battery connections
Axis 24.1 class A 500watts solar TS-45CC Trimetric 2-unknown batteries.
Very noisy generator ">
2016 Wrangler JK dinghy
“They who would give up essential Liberty, to purchase a little temporary Safety, deserve neither Liberty nor Safety.” Benjamin Franklin
ScottG
Bothell Wa.
Posted: 03/06/18 08:10am Link  |  Quote  |  Print  |  Notify Moderator
I really appreciate DIY picture posts this time of year but I have to agree with others. You really don't want the inv. in that area and the outlet needs to be weather protected or it's going to fail quick.
Nice clean work though!
Scott, Grace and Wesly
2018 Silver Fox 32A - many mods to come!
H0NDA eu2000i
2oldman
Pahrump
Posted: 03/06/18 08:26am Link  |  Quote  |  Print  |  Notify Moderator
x2. OP might think they're charged, but they're not.
