RV.Net Open Roads Forum: Fifth-Wheels: Type of lube on fifth wheel pin
 > Type of lube on fifth wheel pin
Curly2001
Tucson, Arizona
Posted: 03/06/18 09:31am Link  |  Quote  |  Print  |  Notify Moderator
What type of lube to you use on your 5th wheel pin? I have a lube plate for the hitch but noticed a little groove on the pin itself. I have a sliding bar Reese hitch and want to make sure the bar stays locked, too.
Thanks in advance.
Curly
2007 Chev. 2500HD, 6.0, 4:10 diffs, six speed auto
2013 Heartland Sundance XLT 265RK
MFL
Midwest
Posted: 03/06/18 09:41am Link  |  Quote  |  Print  |  Notify Moderator
I use teflon trailer ball grease on my pin. Just takes a small amount. Normally the slide bar will wear, before the pin.
Jerry
Old-Biscuit
Verde Valley
Posted: 03/06/18 09:48am Link  |  Quote  |  Print  |  Notify Moderator
I use a small dab of high load bearing grease.
Not so sure it much matters 'what' you use just that you use some type of lube
1Wheeldrive
Centennial CO
Posted: 03/06/18 09:51am Link  |  Quote  |  Print  |  Notify Moderator
I use Bel Ray waterproof wheel bearing grease on my pin. Seems to work fine.
2015 GMC Sierra SLT 3500 CC Long Bed
2012 Voltage 3200
2006 KLR 650
2004 Suzuki Twin Peaks
2002 Suzuki DRZ400e
Curly2001
Tucson, Arizona
Posted: 03/06/18 09:55am Link  |  Quote  |  Print  |  Notify Moderator
Thanks for the help
Helmsey
Knoxville, TN
Posted: 03/06/18 11:16am Link  |  Quote  |  Print  |  Notify Moderator
I generally use "red n tacky" as thats what I have around for the wheel bearings.
KK4PFX
2015 Chevy 3500HD LTZ Dually
2013 Sandpiper 365SAQ
Dan Henry
Caddo Mills, TX
Posted: 03/06/18 03:25pm Link  |  Quote  |  Print  |  Notify Moderator
i use spray can lithium grease. I wipe off the pin just before I am ready to hook up and leave the residue on the pin until I-am ready to tow. Also use a little on the hitch jaws same procedure.
Dan
bpounds
Senile, er I mean
Posted: 03/06/18 04:41pm Link  |  Quote  |  Print  |  Notify Moderator
I also don't think it matters too much what you use. But I want something that will cling as tight as possible, and nothing clings better than motorcycle chain and cable spray. Stays where I put it. And it is designed to penetrate the rollers in chain, so it wicks into tight places nicely.
But I haven't put it on the pin itself in a long time. Your hitch jaws need lube, so I use the chain and cable spray for that and hit the face where the jaws touch the pin while at it. Which transfers to the pin next time I hitch up.
2006 F250 Diesel
2011 Keystone Cougar 278RKSWE Fiver
Jim2007
Greeley, Colorado
Posted: 03/06/18 09:03pm Link  |  Quote  |  Print  |  Notify Moderator
The maker of the hitch suggested thick bearing grease and that is what I use. Seems to work fine.. Jim2007
TV: 2016 Dodge 2500 Diesel
Rig: 2013 Heartland, Sundance, 5th wheel
Road Phantom
pa
Posted: 03/07/18 12:29am Link  |  Quote  |  Print  |  Notify Moderator
lube ring, clean and dry
