RV.Net Open Roads Forum: Fifth-Wheels: Type of lube on fifth wheel pin
 > Type of lube on fifth wheel pin
jerem0621
Tennessee
Posted: 03/07/18 03:45am Link  |  Quote  |  Print  |  Notify Moderator
Road Phantom wrote:
lube ring, clean and dry
This does nothing for your pin and fifth wheel jaws.
2112
Posted: 03/07/18 04:06am Link  |  Quote  |  Print  |  Notify Moderator
Lucas Red and Tacky #2. I use it for everything from door hinges to gun grease. It can be found at Wal-Mart for $5.
2013 KZ Durango 2857
bpounds
Senile, er I mean
Posted: 03/07/18 08:47am Link  |  Quote  |  Print  |  Notify Moderator
Yeah, I would guestimate 95 percent of us use a lube ring. Still needs lube on the moving parts, pin and jaws.
2006 F250 Diesel
2011 Keystone Cougar 278RKSWE Fiver
mtofell1
Oregon
Posted: 03/07/18 08:51pm Link  |  Quote  |  Print  |  Notify Moderator
Whatever you can easily clean out of your shirt when you walk into it at the campground [emoticon] [emoticon]
allen8106
Burrton. KS
Posted: 03/09/18 12:01pm Link  |  Quote  |  Print  |  Notify Moderator
Nothing!!
2010 Eagle Super Lite 315RLDS
2018 GMC Sierra 3500HD 6.6L Duramax
1983 DW (love of my life)
2010 Pit Bull Terrier (Jake)
2010 Nights 45
2011 Nights 70
2012 Nights 144
2013 Nights 46
2014 Nights 49
2015 Nights 57
2016 Nights 73
2017 Nights 40
2018 Nights 56
Bipeflier
Centralia, MO
Posted: 03/09/18 05:37pm Link  |  Quote  |  Print  |  Notify Moderator
I use a spray, dry film, molybdenum lube. No dirt attraction and only needs to be reapplied about twice a summer.
2010 Cruiser CF30SK Patriot
2016 3500 Duramax
1950 Right Hand Seat GPS (she tells me where to go)
Cummins12V98
on the road
Posted: 03/10/18 08:58am Link  |  Quote  |  Print  |  Notify Moderator
One pump of AMZ/OIL grease smeared evenly on kingpin shaft the hitch jaws clamp to. Just happens to be the grease I use on the 9 fittings on my TrailAir TriGlide, fitting on my B&W hitch and wheel bearings on the RV.
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
larry barnhart
wenatchee. wa usa
Posted: 03/10/18 09:07am Link  |  Quote  |  Print  |  Notify Moderator
I have used white grease on ours since 2001. Easy to clean after arriving at home or the winter resort. The reason is I saw many pins with rust on them years ago.
chevman
chevman
2001 35 ft avalon alpenlite RK
prodigy
easyrider/reese airhitch
trailair center point suspension
JT Strong Arm Stabilizers
KSH 55 inbed fuel tank
scanguage II
TD-EOC
Induction Overhaul Kit
TST tire monitors
FMCA # F479110
Cummins12V98
on the road
Posted: 03/10/18 12:22pm Link  |  Quote  |  Print  |  Notify Moderator
First pic with grease and accumulated sand/dust. Second wiped, looks pretty much like the day I bought it.
Fiver Driver
Chandler AZ
Posted: 03/13/18 05:46pm Link  |  Quote  |  Print  |  Notify Moderator
I use wheel bearing grease, then slip a tin can over the pin when not towing to keep the grease clean. Use a 15 oz can and cut the top out with a can opener that cuts the edge of the rim rather than inside the rim.
