RV.Net Open Roads Forum: Class A Motorhomes: Quikee Step problem
 > Quikee Step problem
Page of 5
Leeblev
Pinole, CA
Posted: 03/06/18 10:37am Link  |  Quote  |  Print  |  Notify Moderator
I have a 2001 Newmar Kountry Star with Quickee step (2 steps). I have noticed it operating sporadically for some time. At first, I thought it was the sensor on the door, because I could clean the plug on the door and on the wall and the step would operate. But then, it got to the point where cleaning no longer worked. I took the plugs out, cleaned the debris (metal) off of the magnet, and made sure the pickup in the wall was clean. Didn't work. I checked the plug underneath going to the motor device and couldn't find anything wrong. It has 12v going to the motor, but not operating the motor, so electric isn't an issue.
When it was working, I did not detect any sign of hangup, rubbing or any interference with the steps opening.
Has anybody had this issue? What did you do to correct it? Any help appreciated.
Lee
2001 36' Kountry Star DP
PastorCharlie
NC
Posted: 03/06/18 10:56am Link  |  Quote  |  Print  |  Notify Moderator
RV dealer replaced the motor on mine and it works fine.
fischer
livingston, tx
Posted: 03/06/18 11:17am Link  |  Quote  |  Print  |  Notify Moderator
Search the web for Kwickee steps troubleshooting
select flowchart it shows how find your problem
2016 Winnebago 35B v10
2006 Jeep Liberty 4x4
Blue ox Tow Bar
fyrflie
Martinez, CA. USA
Posted: 03/06/18 11:29am Link  |  Quote  |  Print  |  Notify Moderator
Sounds like your step motor is done.
Do a search on this forum or over at IRV2.com and you will find a ton of information.
The step motor is the same as a window lift motor. Mostly from a Ford Taurus.
Very easy to replace.
D.E.Bishop
Eagle Rock, CA
Posted: 03/06/18 11:37am Link  |  Quote  |  Print  |  Notify Moderator
Google "Kwikee Manual #888. Page ten starts the troble shooting procedure. Odds are the motor is bad and following the steps in the manual will give an answer.
The manual is also on Chris Bryant's blog page.
It is simple to check but buying a motor may not be, but that comes after dianossis.
If you have problems. Post asking for help. Don't buy the pigtail. Meter probes will fit in the connector fine.
"I travel not to go anywhere, but to go. I travel for travel's sake. The great affair is to go". R. L. Stevenson
David Bishop
2002 Winnebago Adventurer 32V
95 Suzuki Sidekick 4X4
Stowmaster 5000
Jim@HiTek
Gresham, OR, USA
Posted: 03/06/18 11:43am Link  |  Quote  |  Print  |  Notify Moderator
Some people have said they verified a bad motor by whacking it with rubber mallet when it wasn't working...if that restored operation, it indicated a bad motor.
Jim@HiTek
Have shop, will travel!
Visit my travel & RV repair blog site. Subscribe for emailed updates.
Winnebago Journey, '02
Cat 330HP Diesel, 36.5', two slides.
lj2654
Weeki Wachee, Florida
Posted: 03/06/18 12:15pm Link  |  Quote  |  Print  |  Notify Moderator
gears inside the motor have hard plastic vibration disintegrate. Probably need a new motor. Match it up on Amazon to get a cheaper price.
2001 Beaver Contessa Naples 40
2012 Cadillac Srx
retired AirForce 1979-1992
Gjac
Milford, CT
Posted: 03/06/18 01:30pm Link  |  Quote  |  Print  |  Notify Moderator
After you go through the troubleshooting steps that others previously posted, it will tell you if it is the switch, motor or control board. Post your results here and you will get better advice on how to repair it.
enblethen
Moses Lake, WA
Posted: 03/06/18 05:00pm Link  |  Quote  |  Print  |  Notify Moderator
I would verify that the two grounds are clean under the step.
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
cdc
New Braunfels,TX
Posted: 03/07/18 04:11am Link  |  Quote  |  Print  |  Notify Moderator
Same problem, so I replaced the motor and that didn't solve the problem. A good friend of mine in the RV industry advised that I pull the sensor, strip the wire and touch them together and if the step worked then it was a bad switch. Needless to say, it was a bad switch.
Corky, Gracie, and the Herd
HR Imperial DP
Jeep Liberty
Page of 5
