RV.Net Open Roads Forum: Is this a powerful enough Generator for me?
 > Is this a powerful enough Generator for me?
Page of 6
brianosaur
Long Island
Posted: 03/07/18 08:34pm Link  |  Quote  |  Print  |  Notify Moderator
bgum wrote:
We have one and have had no issues. It is quiet but time will tell as to how long it will last. Your money.
THAT'S A YES
dodge guy wrote:
I have a similar 2200W and it will not start my 13.5 AC. I got it for free so I wasn’t out anything. If I were to buy something it would be at least a 3k Watt.
THAT'S A NO
K Charles wrote:
We have a powerhouse that is 2200 serge and 2000 run. It always ran the AC in our TT with other things running.
THAT'S A YES
Lwiddis wrote:
I have this generator. It won't start my AC but should with a soft start kit.
THAT'S A NO and a MAYBE
Boon Docker wrote:
According to the Q&A on that website two people say it will not power a 13.5 AC unit.
THAT'S A NO
Okay, so I guess the answer my op is a "POSSIBLE" but advised to go bigger or go home.
SoundGuy
S Ontario
Posted: 03/08/18 01:25am Link  |  Quote  |  Print  |  Notify Moderator
Depends on what you mean by "bigger" ... as I said on Pg 1 of this discussion - "... the new Honda EU2200 has a 121 cc engine, this Westinghouse has a 79 cc engine - which do you think stands the best chances of successfully starting your A/C?"
Successfully starting any A/C compressor depends on ambient conditions - i.e. temperature & altitude. The hotter it is, the higher the elevation above sea level, the greater will be the load placed on the genset by the A/C compressor. That initial load can be eased substantially by equipping the A/C with a soft starter kit such as the Micro-Air Easy Start but it won't do a thing for A/Cs running amps requirement - only a higher capacity genset will solve that. For those that don't expect to be running A/C at higher elevations or in extreme temperatures the ready availability of these soft starter kits does now make it practical to consider powering a 13.5K BTU A/C with a Honda EU2000i or better still the new Honda EU2200i. Common sense however suggests that any genset with a much smaller 79 cc engine, be it this Westie you're talking about or even a Yamaha EF2000iS, is less likely to be able to cope with the initial surge load than a genset like the new Honda EU2200i which has a 50% larger 121 cc engine. Defined in this manner an EU2200i is "bigger" even though it's still a 2K genset. [emoticon]
Florida Swamp Fox
Posted: 03/08/18 06:04am Link  |  Quote  |  Print  |  Notify Moderator
Back in the late 80s I had a friend that would take his trailer to the Lake at Camp Blanding where there was a campground without electricity. Nice lake but real hot in Florida during the summer. This guy took an open frame contractor generator, put it into a very small utility trailer which he cut a vent into and piped his exhaust to another whole in the wall. He put a fan motor in the roof vent and ran the generator. You could just barely hear it. Not sure how long he got away with it but I saw it working and that loud #%* generator could barely be heard.
2015 Ford F350 CC 6.7 PSD DRW
2017 Arctic Fox 1150 DB (sold)
2018 Jayco North Point 315RLTS
brianosaur
Long Island
Posted: 03/08/18 08:53am Link  |  Quote  |  Print  |  Notify Moderator
Exactamundo!
westend
Shorewood, MN
Posted: 03/08/18 09:01am Link  |  Quote  |  Print  |  Notify Moderator
Exactamundo!
The main problem is not going to be how quiet you can operate the generator but who hears it run and management's adherence to the rules. You know that if you are running the gen set during quiet hours and another genereator owner shut his down,there is going to be bad feelings. Not saying anyone is right or wrong, just pointing out the obvious.
'03 F-250 4x4 CC
JoeTampa
Tampa, FL
Posted: 03/08/18 09:06am Link  |  Quote  |  Print  |  Notify Moderator
Ron3rd wrote:
It will beg for mercy at full throttle. I would not recommend it. Spend a few hundred more and get a Champion 3100
I concur with this. The Champion has a 30A trailer connector and I can indeed say that it will start and run the AC in my rig.
I have a Progressive Industries surge protector, and one of the nice things about it is that it shows your current consumption - so I know how many amps I draw with any desired combination of appliances running. Knowing this is pretty crucial to obtaining a generator that will meet your (rig's) needs. With one AC and everything but the microwave on, I am drawing 24A, which equates to 2640 watts - well within the range of the Champion (3100 starting watts, 2800 running watts). 1800 running and 2200 starting watts would definitely not work for me as the A/C is about 20 of those amps (2200 watts running).
2006 Keystone Cougar 243RKS (First trailer)
2016 Jayco Jay Flight 32BHDS (Traded in)
2016 Jayco Jay Flight 33RBTS (Current)
2006 Chevy Silverado 2500HD 4WD 6.6L Duramax Diesel (LBZ)
Blue Ox Swaypro 1500 WDH
Prodigy P2 BC
Amateur Call AB2M
ktmrfs
Portland, Oregon
Posted: 03/08/18 10:17am Link  |  Quote  |  Print  |  Notify Moderator
Unless they have done a recent upgrade, the current reading on the PI readout is terribly inaccurate. Often reading way more than actual current and on other occasions way less.
After I verified this comparing to a true RMS current probe I called PI and they admitted it is very very inacurate and they added it as a feature only to discover how inaccurate it is.
Good to say Lots of current, or not much current but not much else.
I've had mine read over 40A when actual draw was near 20A. In fact if it really was 40A, the 30A main breaker would have tripped.
2011 Keystone Outback 295RE
Turtle n Peeps
California
Posted: 03/08/18 10:26am Link  |  Quote  |  Print  |  Notify Moderator
Sorry for the jack but Joe can you tell me the model of your PISP.
outside the fire"
"The best way to get a bad law repealed is to enforce it strictly."- Abraham Lincoln
bgum
South Louisiana
Posted: 03/08/18 05:47pm Link  |  Quote  |  Print  |  Notify Moderator
Comments thus far sound just like the comments concerning Champions when they first came out. I guess time will tell is the best statement.
JoeTampa
Tampa, FL
Posted: 03/08/18 06:43pm Link  |  Quote  |  Print  |  Notify Moderator
The older PTC-50: https://www.rvupgradestore.com/Progressive-Industries-EMS-50amp-Inline-p/pt50c.htm
..Which appears to have been replaced.
I don't have anything else to compare it with - but I have compared readings after shutting down appliances of known wattage and calculated the amperage drop, and it seems to be accurate enough for my purposes. YMMV, I suppose. The unit is about 2 years old, maybe 3.
Page of 6
