RV.Net Open Roads Forum: Fifth-Wheels: spring axle upgrade or change to Torsion axle
 > spring axle upgrade or change to Torsion axle
dlritter
Columbus, Ohio
Posted: 03/06/18 03:25pm Link  |  Quote  |  Print  |  Notify Moderator
Hi
I have a 2013 Artic Fox 29-5T with spring axles and shocks. The ride is very rough and things inside get bounced around a lot. My last unit had Torsion Axles on it and it ran very smooth. I am thinking of swapping out the spring axles for Dexter Torflex axles. My question is are there any suspension upgrades that would make enough of a difference rather than switching axles? The quote for new axles is $2K
Thanks for your input.....
Dayle1
Spicewood, Tx
Posted: 03/06/18 04:09pm Link  |  Quote  |  Print  |  Notify Moderator
My experience with 4 different leaf spring units is that the ride is very unpredictable. My current unit rides great even with an old fashion solid equalizer. But a previous unit was so bad I had Morryde install their IS system which is comparable to torsion axles. The change was dramatic. Another leaf spring unit did good with a rubber equalizer.
I've had two units with torsion axles and they both rode great. If I ever get another leaf spring unit that doesn't ride well , I will do exactly what you are considering. But I will get disc brakes as well.
Larry Day
Texas Baptist Men-Retiree Builders since '01
'13 Silverado 3500HD LT 2wd CCSB SRW, custom RKI bed
'17 Puma 351THSS
Rig Photos
keymastr
S.E. Washington
Posted: 03/06/18 07:25pm Link  |  Quote  |  Print  |  Notify Moderator
I think axle placement makes a difference as well. Units that have the axles more towards the center of the trailer have more bounce, especially at the rear verses units with the axles more towards the rear of the trailer.
Bounce can also be caused by having axles or tires with a much higher capacity than the current loading. Arctic Foxes usually have a pretty high cargo capacity so maybe you just need more weight.[emoticon]
JTrac
Oklahoma
Posted: 03/07/18 07:38am Link  |  Quote  |  Print  |  Notify Moderator
I don't have any experience with Dexter Torflex but did the change to MorRyde IS last fall. I also changed the Dexter Never Lube hubs and disc brakes to Kodiak stuff. We pulled it 800 miles back home and the difference in ride was pretty significant. My goal for doing this on a 6 year old rv is to make it last as long as possible by giving it the best ride possible over some of our nasty roads. I will never recover my investment but at my age I consider that my kid's problem.
JimT
2013 Excel Winslow 34RKM, 2017 Ford F350 King Ranch, 6.7 PS, 4X4 dually
goducks10
There
Posted: 03/07/18 08:22am Link  |  Quote  |  Print  |  Notify Moderator
You should have shocks on your 29-5T. Maybe replace them with better ones. Also what are you running for tires? If you're running G rated are they maxed out at 110 psi?
And have you posted your question on the NROA forum. There's others their with your 5th wheel that could maybe shed some light on your situation.
http://www.nroa2003.com/forum/forum
TxGearhead
Posted: 03/08/18 07:54am Link  |  Quote  |  Print  |  Notify Moderator
Not an answer to your question but it gives me a chance to spout off.
I don't understand why trailer manufactures don't offer torsion axles as an option. Maybe some do and I'm not aware. I have them on 2 other trailers...dual axle boat trailer and single axle utility trailer. I like them. And while I'm just spouting off, I don't understand why Dexter doesn't offer Vault hubs, they own the company now. Torsion axle, Vault, and disc brakes would end a lot of our troubles.
...as you were...carry on.
2018 Ram 3500 CC LB DRW 4X4 Cummins Aisin Laramie Pearl White
2014 Montana High Country 305RL
2008 Bigfoot 25C9.4
laknox
Arizona
Posted: 03/08/18 08:02am Link  |  Quote  |  Print  |  Notify Moderator
Add that to the long, LONG list of idiocy in the RV industry...
Lyle
2017 KZ Durango 1500 D277RLT
1936 John Deere Model A
International Flying Farmers 60 Year Member
fj12ryder
Platte City, MO
Posted: 03/08/18 09:51am Link  |  Quote  |  Print  |  Notify Moderator
It would mayhap end a lot of our troubles, but at a substantial rise in build costs. Since most trailer owners probably move their trailer relatively few miles overall, these costs may seem unnecessary.
Howard and Peggy
"Don't Panic"
laknox
Arizona
Posted: 03/08/18 10:12am Link  |  Quote  |  Print  |  Notify Moderator
=Options=, FJ, options. Let the user decide how they want to use the trailer and what will fit them best and how much they want to spend. Someone who wants to move 2x a year doesn't need IS; someone who moves weekly, would be a huge benefit. Hell, just look at the issue with 15" and 16" wheels/tires. =Finally=, in just the past 2 years, or so, mfrs are offering options on even lighter weight rigs to get 16" wheels from the factory. Do we =need= them? Not always, but it sure gives an owner a lot more tire options, doesn't it? (I'd've paid for this option were I ordering my FW, but I bought off the lot, so am stuck with the 15's.) Solar. How nice would it be to have even a 100w solar charger? Disk brakes? Again, for the "casual" user, not really necessary, but for an owner that likes to move a lot, or long distances, they'd sure be handy, don't you think? Upgraded multi-stage power converters? The list goes on.
Lyle
