RV.Net Open Roads Forum: 93 Brave with Chevy 454 acceleration issuea
 > 93 Brave with Chevy 454 acceleration issuea
Page of 5
psalm10720
Clearwater, FL
Posted: 03/07/18 02:25pm Link  |  Print  |  Notify Moderator
Mine is a 1993 with a carburetor
enblethen
Moses Lake, WA
Posted: 03/07/18 03:09pm Link  |  Print  |  Notify Moderator
Someone has changed it out!
Maybe the complete engine!
Look on the front face of the engine block, right side for the engine code.
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
tderonne
Michigan
Posted: 03/07/18 03:57pm Link  |  Print  |  Notify Moderator
1993 Brave Brochure
"454 V-8 Fuel-Injected Gasoline Engine"
Again, not saying it isn't carbureted. Just that it wasn't built that way.
Tim
2004 Winnebago Adventurer 31Y
Ford chassis
psalm10720
Clearwater, FL
Posted: 03/07/18 05:04pm Link  |  Print  |  Notify Moderator
The RV started life in RI, dunno, I bought it in 2014 Hudson, FL. Learned lots of expensive lessons about buying a used RV from a used RV dealer.
D.E.Bishop
Eagle Rock, CA
Posted: 03/07/18 06:05pm Link  |  Print  |  Notify Moderator
My 1990 Bounder had a 1989 454, it had similar problem, the culprate was a relay that provided priming to the carb and shut off while cranking and started again when oil pressure climbed. If you as you stated have a carb, you may have the same relay.
I installed(tempoarily)a fuel pressure guage and found that the pump ran fine until the engine warmed up, then it shut down.
The mechanical fuel piump could supply gas at low speeds but on acceleration the engine would starve out.
Two fuel pumps, one in tank, one on the block.
"I travel not to go anywhere, but to go. I travel for travel's sake. The great affair is to go". R. L. Stevenson
David Bishop
2002 Winnebago Adventurer 32V
95 Suzuki Sidekick 4X4
Stowmaster 5000
psalm10720
Clearwater, FL
Posted: 03/07/18 06:11pm Link  |  Print  |  Notify Moderator
So it came with one in the tank? Model number of block or tank pump?
garry1p
Oklahoma
Posted: 03/07/18 06:22pm Link  |  Print  |  Notify Moderator
Mine is FI but;
I think you will find an inline fuel filter in the fuel line (on mine just behind the steps)on the frame rail I had the same problem and it was the filter.
The carburetor may also have a small filter at the very input to the carburetor.
Garry1p
1990 Holiday Rambler Aluma Lite XL
454 on P-30 Chassis
1999 Jeep Cherokee sport
STBRetired
I-80 and I-55
Posted: 03/07/18 07:17pm Link  |  Print  |  Notify Moderator
Stuck power valve in carb?
1999 Newmar MACA 3796 F53 6.8L
2016 Ford Edge Sport
Roadmaster Sterling A/T with Brake Buddy
enblethen
Moses Lake, WA
Posted: 03/08/18 08:33am Link  |  Print  |  Notify Moderator
Had a thought last night!
If some one changed to carb, it could be that the catalytic converter was overloaded and clogged.
psalm10720
Clearwater, FL
Posted: 03/08/18 11:13am Link  |  Print  |  Notify Moderator
Number one it is someone’s contention it was changed, not mine. There is no evidence it has been changed. One post showed in my model year they used carbs.
Page of 5
