RV.Net Open Roads Forum: 93 Brave with Chevy 454 acceleration issuea
 > 93 Brave with Chevy 454 acceleration issuea
Page of 5
psalm10720
Clearwater, FL
Posted: 03/06/18 03:50pm Link  |  Print  |  Notify Moderator
Have a 93 Brave 27RC on a Chevy P30 chasis. 112000 miles. When cold idles well and accelerates well from standing still. Then after warmup when accelerating from a start it falters often. Some refer to it as “falling on its face” or “backfiring” without the loud noise. One of the possible explanations refers to the “accelerator pump” on the carburetor. Another which sounds more plausible is the ECM has a problem because the programming during warmup is different than after the engine is warmed up... Anybody with experience?
ScottG
Bothell Wa.
Posted: 03/06/18 04:24pm Link  |  Print  |  Notify Moderator
No carburetor, it's fuel injected.
I would replace the 02 sensor first. It/they should have been replaced by now and if not, are in desperate need. (They get lazy and slow but work well enough not to throw a code) When eng is cold it isn't a factor.
Also make sure every other service has been done to it.
Scott, Grace and Wesly
2018 Silver Fox 32A.
H0NDA eu2000i
enblethen
Moses Lake, WA
Posted: 03/06/18 04:57pm Link  |  Print  |  Notify Moderator
It could be the IAC(idle air control) It is mounted on the right side of the throttle body assembly. It acts similar to a choke on a carb engine. The passages could be clogged with carbon.
IAC
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
psalm10720
Clearwater, FL
Posted: 03/06/18 05:05pm Link  |  Print  |  Notify Moderator
Mine is carbureted
Lone Pine, CA
Posted: 03/06/18 05:09pm Link  |  Print  |  Notify Moderator
Find an OLD mechanic for the repair of this 25 year old RV.
Winnebago 2101DS TT & 2019 Chevy Silverado LTZ Z71, 300 watts solar-parallel & MPPT, Trojan T-125s. TALL pole for flags. Prefer USFS, COE, BLM, NPS, TVA, USF&WS, state & county camps. Bicyclist! 14 year Army vet - 11B40 then 11A - old MOS 1542 & 1560.
enblethen
Moses Lake, WA
Posted: 03/06/18 06:42pm Link  |  Print  |  Notify Moderator
93 are throttle body injection. The throttle body looks like a two barrel carb.
Verify your vin number, the tenth character would be a "P" for 1993, 1992 would be the letter "N"
Remove air filter and look into the throat, there should be two injectors at the top. They are about 1 inch diameter and two inches long, each have an electrical connector.
If someone changed out motor that could have carb.
Then all bets are off until you find engine vin number.
ScottG
Bothell Wa.
Posted: 03/06/18 06:45pm Link  |  Print  |  Notify Moderator
Pretty sure it's TBI. Carbs just couldn't do emissions by then.
They look like carbs since everything is in one spot.
Strongly suggest replacing the 02 sensor which is dirt cheap and easy to replace yourself.
Also make sure there's no exhaust leaks at the manifold which will mess with sensors.
enblethen
Moses Lake, WA
Posted: 03/06/18 06:57pm Link  |  Print  |  Notify Moderator
My cheap books says all the way back to 1987 7.4 engine had TBI.
keymastr
S.E. Washington
Posted: 03/06/18 07:03pm Link  |  Print  |  Notify Moderator
Mass air flow sensor could cause this also.
Stim
NE Florida
Posted: 03/06/18 07:52pm Link  |  Print  |  Notify Moderator
TBI has a fuel pressure regulator in it and they get weak over time.
They are not hard to change or expensive.
I had to change the one on a 1989 PU back when.
Can be changed on the vehicle if you have good access.
Page of 5
