RV.Net Open Roads Forum: Class A Motorhomes: Maintenance ?
udidwht
Seattle
Posted: 03/06/18 04:13pm Link  |  Quote  |  Print  |  Notify Moderator
I do not see any abnormality on the cooling hoses anywhere and they feel good. But I intend on replacing them soon (before next trip). Curious should I look at doing the water pump and clutch fan as well? No issues with either currently and the RV now has 56,1XX miles (US).
I purchased the RV (94 Fleetwood Southwind Storm 28ft P30) in Sept 2014 and it was just shy of 45,XXX miles. Now at 56,1XX
This year my plan is to do the rubber hoses Upper/lower, heater hoses, by-pass hose and possibly water pump, clutch fan and cooling senors. You think it's worth changing those items? (water pump, clutch fan and cooling senors)
I see in Rockauto (2) AC Dleco water pumps but do not know the difference between the two.
1.https://www.rockauto.com/en/moreinfo...sn=455&jsn=455
2.https://www.rockauto.com/en/moreinfo...sn=460&jsn=460
What I've done thus far:
1. TPS - Delco (July-2016)
2. Map sensor - Delco (July-2016)
3. IAC valve - Napa Gold (Sept-2016)
4. Idle speed air solenoid actuator - (Aug-2016)
5. PCV valve - Delco (Sept-2016)
6. Spark plugs - Autolite (Sept-2014)
7. Spark plug wires - Napa premium Belden Edge (Sept-2014)
8. TSS sensors (front & Rear) Napa Gold (Sept-2017)
9. Service rear differential (Sept 2014)
10 Serviced trans 4L80E (replace both shift solenoids, wire harnes/connector, force valve turned up 1/2 turn, fluid & filter (Sept-2017)
11. Cooling system flushed/filled, T stat changed (Sept-2014)
12. Air filter Wix (Aug-2014)
13. Generator serviced Onan 4K @ 511hrs (Jan-2016) incl plug and spark arrestor cleaning, air filter
14. Anode rod hot water tank (Oct 2017)
15. Fuel filter chassis - Wix (Aug-2014)
16. Chassis lubed - Valvoline synthetic lube (05-2018)
17 Rebuilt trans axle rod (01-2016) all new U-joints and axle rod support bearers.
18. Engine belts replaced (3) (01-2016)
19. New front rotors (Raybestos), ceramic pads, master cylinder, and rear drums checked and wheel bearings lubed (frt & rear) 2016
20. O2 sensor - Delco (06-2016)
21. Cleaned EGR valve installed new gasket (08-2017)
22. Sanded, rust treated and painted LP tank (09-2017)
23. New Bosch alternator (07-2016)
24. Upper/lower radiator hoses (05/2018)
25. By-pass hose (05/2018)
26. New T-stat (Delco) 195 degree (05/2018)
27. New auxiliary fan motor (05/2018)
28. Micro 4k valve lash adjusted @ 512hrs 05/2018
29. Generator oil @ 511hrs 09/2017
__________________
1994 Southwind Storm 28ft 7.4L TBI P-30
56,114 miles and counting...
VIN#1GBJP37N4R3314754
* This post was last edited 06/09/18 04:35am by udidwht *   View edit history
1994 Fleetwood Southwind Storm
P-30 chassis 7.4L 454 TBI 56,4XX miles and counting....
VIN# 1GBJP37N4R3314754
Los Angeles :(
Posted: 03/06/18 04:22pm Link  |  Quote  |  Print  |  Notify Moderator
IMO hoses yes but pump, sensors and clutch no.
2015 Winnebago 2101DS TT & Tahoe LTZ, 300 watts WindyNation solar-parallel & MPPT, Trojan T-125s. TALL flagpole for US flag. Prefer USFS, COE, BLM, NPS, TVA, USF&WS, state & county camps. Bicyclist! 14 year Army vet - 11B40 then 11A - old MOS 1542 & 1560.
ScottG
Bothell Wa.
Posted: 03/06/18 04:28pm Link  |  Quote  |  Print  |  Notify Moderator
I would be concerned about the rubber fuel lines. Hose from that era doesn't play well with the corn juice they dilute our fuel with and will deteriorate until it leaks. Lots of older vehicle fires caused by this.
Scott, Grace and Wesly
2018 Silver Fox 32A.
H0NDA eu2000i
enblethen
Moses Lake, WA
Posted: 03/06/18 04:53pm Link  |  Quote  |  Print  |  Notify Moderator
I would look up your rig at O'Reilly auto parts. Make it easier to exchange locally.
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
Los Angeles :(
Posted: 03/06/18 05:01pm Link  |  Quote  |  Print  |  Notify Moderator
“Corn juice,” Scott? I demand an apology.
FIRE UP
Lake Havasu City AZ
Posted: 03/06/18 05:03pm Link  |  Quote  |  Print  |  Notify Moderator
udidwht,
Just wondering, is the clutch fan on your coach, the original one? If so, leave it on there as long as possible. The factory clutch fans are the best you can have. 95% of the aftermarket ones, no matter what the brand name is, are CHEAP! normally, the factory ones are considerably more heavy duty than the replacement aftermarket ones. If you must get one, either find out where the local parts house that supplies the dealers with factory equipment or, pay the bucks and get one from the dealer who made your engine, i.e. Ford or Chevy.
Scott
Scott and Karla
SDFD RETIRED
2011 GMC Sierra 1500 Ext Cab 4x4 Toad
2008 Caliente Red LVL II GL 1800 Goldwing
KI60ND
K Charles
Connecticut
Posted: 03/06/18 06:07pm Link  |  Quote  |  Print  |  Notify Moderator
If it ain't broke, don't fix it.
udidwht
Seattle
Posted: 03/06/18 06:16pm Link  |  Quote  |  Print  |  Notify Moderator
Fuel lines from tank to TBI are all steel on this RV.
udidwht
Seattle
Posted: 03/06/18 06:19pm Link  |  Quote  |  Print  |  Notify Moderator
FIRE UP wrote:
udidwht,
Scott
As far I can tell (no paperwork) the clutch fan and water pump are OEM. RV has 56,1XX miles and they are in working order. The clutch fan does have the P-51 roar when in action.
udidwht
Seattle
Posted: 03/06/18 06:20pm Link  |  Quote  |  Print  |  Notify Moderator
Was leaning at that as well aside from replacing the rubber hoses. Was wondering if it was something most of you'd recommend (replacing) given the age of RV.
