RV.Net Open Roads Forum: Class A Motorhomes: Maintenance ?
enblethen
Moses Lake, WA
Posted: 03/06/18 06:45pm Link  |  Quote  |  Print  |  Notify Moderator
Lines are rubber coming out of the tank. About 18-24 inches long. There should be three, one fuel, one fuel return and one for the genset.
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
near La Cuesta Encantada
Corn juice? I’m still upset.
2015 Winnebago 2101DS TT & Tahoe LTZ, 300 watts WindyNation solar-parallel & MPPT, Trojan T-125s. TALL flagpole for US flag. Prefer USFS, COE, BLM, NPS, TVA, USF&WS, state & county camps. Bicyclist! 14 year Army vet - 11B40 then 11A - old MOS 1542 & 1560.
ScottG
Bothell Wa.
Posted: 03/06/18 07:06pm Link  |  Quote  |  Print  |  Notify Moderator
I for one will not wait until something breaks and leaves me on the side of the road with my family in the middle of nowhere.
Far better to keep up with maint. and since I do so, I have never been stranded.
Scott, Grace and Wesly
2018 Silver Fox 32A.
H0NDA eu2000i
udidwht
Seattle
Posted: 03/07/18 01:15am Link  |  Quote  |  Print  |  Notify Moderator
How about for a water pump and clutch fan with less than 60k on them and no issues?
1994 Fleetwood Southwind Storm
P-30 chassis 7.4L 454 TBI 56,4XX miles and counting....
VIN# 1GBJP37N4R3314754
udidwht
Seattle
Posted: 03/07/18 01:18am Link  |  Quote  |  Print  |  Notify Moderator
The generator one I did just about 6mos ago. Used Gates Barricade hose. I'll need to check the other. May need to wait for the tank level to drop it's full now.
Wherever I happen to park
Posted: 03/07/18 06:40am Link  |  Quote  |  Print  |  Notify Moderator
With hoses I believe in preventitave maintenance
With water pumps I'm a firm believer in replacing that which is broke, but if it's not broke don't fix it.
Home is where I park it.
RLS7201
Posted: 03/07/18 11:40am Link  |  Quote  |  Print  |  Notify Moderator
Your engine fuel hoses are designed for E10. If ya can't find the problem, blame E10. I've been using Oreilly thermal fan clutches on my customers and my MH for years with out a problem. There is a Oreilly fan clutch on my 528 stroker MH engine, and it cools properly. Aftermarket fan clutches got a bad rap when DIYs purchased non-thermal clutches to replace their OEM thermal fan clutch.
Richard
95 Bounder 32H F53
460/528 stroker
Web Master
MWPSchooners.com
jplante4
Cape Cod
Posted: 03/07/18 02:39pm Link  |  Quote  |  Print  |  Notify Moderator
I'd be more worried about the brakes than the cooling.
Jerry & Jeanne
1996 Safari Sahara 3530 - 'White Tiger'
CAT 3126/Allison 6 speed/Magnum Chassis
2014 Equinox AWD / Blue Ox
udidwht
Seattle
Posted: 03/07/18 03:36pm Link  |  Quote  |  Print  |  Notify Moderator
Brake work complete already (08-2016).
Replaced front rotors (Raybestos), pads (Centric ceramic), master cylinder (Raybestos). Removed the drums on the rears and clean everything up real well. Linings were still ~95%. Re-packed front & rear bearings as well. System filled flushed and filled with new fluid as well.
shepfly
NW Ohio
Posted: 03/07/18 09:37pm Link  |  Quote  |  Print  |  Notify Moderator
Assuming you have hydraulic brakes all your rubber flex lines are well past their service life and should be replaced and system bled completely. Do you have the auto brake system? That is another can of worms all on its own! Dave
