RV.Net Open Roads Forum: Travel Trailers: Mounting Items
Diamondair
Dallas
Posted: 03/06/18 08:43pm Link  |  Quote  |  Print  |  Notify Moderator
Good Evening
I have a 2015 Jayco Jayflight TT and was fishing for some feedback on mounting items. This is our first travel trailer and 3 years owning it.
I have been nervous on mounting items with screws and been using command strips for everything. Most of everything is holding well but I was to add a mounted paper towel holder. This is a metal holder that has a type of spring load to it.
Now we all know those things take a beating from being pulled and yanked. I am looking to mount to the underside of my cabinet. The under side is hollow sounding. Not a solid piece of wood, which I think could be that way for some type of serviceability. I do not think the command strip will last long at all. A screw in m opinion would last but not that long just note enough material to grab on too.
So I ran across using pop rivets in my search on mounting something like this.
I am curious what everyone is doing to mounting things like this and other things. Possibly looking to mount a medicine cabinet in the RR exterior wall as well. Not sure what I could do there or if the rivets would work.
Does anyone have any recommendations on this?
2015 Jayco Jay Flight 28BHBE
2011 Ford F350 4x4
Son of Norway
Denver, Colorado
Posted: 03/06/18 09:23pm Link  |  Quote  |  Print  |  Notify Moderator
Try toggle bolts for mounting to the exterior walls.
Miles and Darcey
1989 Holiday Rambler Crown Imperial
Denver, CO
hussbuss
home
Posted: 03/06/18 09:51pm Link  |  Quote  |  Print  |  Notify Moderator
Use well nuts. Drill mounting hole, insert rubber encased nut. As you tighten the screw the rubber expands. I have used these in blind, hollow walls in my trailer for years. Available at any hardware store.
rbpru
North Central Indiana
Posted: 03/06/18 10:21pm Link  |  Quote  |  Print  |  Notify Moderator
My command strips started pulling the wall paper off the wall. All I had on it were rain coats and jackets. So I just drove a small nail through the command strip.
I had the same thing happen with a small mirror, the wall paper started to pucker under the little command strip, so I push it back and used a small brad nail on that one.
I have concluded the wall paper glue they used creeps when under pressure.
Twenty six foot 2010 Dutchmen Lite pulled with a 2011 EcoBoost F-150 4x4.
Just right for Grandpa, Grandma and the dog.
westend
Shorewood, MN
Posted: 03/07/18 02:40am Link  |  Quote  |  Print  |  Notify Moderator
You could probably through-bolt the towel holder into the bottom of the cabinet. I would use a fastener with a thin head so that cabinet items could be removed and added easily.
FWIW, I have one of those Command Strips, Extra Strength that I use for hanging a framed picture. It hasn't budged in 6 years. I think the Extra Strength Command strips are used for mirrors and towel bars, etc.
'03 F-250 4x4 CC
GrandpaKip
Flat Rock
Posted: 03/07/18 09:42am Link  |  Quote  |  Print  |  Notify Moderator
I have always used SS screws snugged up to hold all kinds of lightweight stuff on the camper walls. The trick is to not spin the screw past the tight stage.
Our paper towel holder is also screwed into the bottom 5mm plywood layer of a wall cabinet. No problem after 2 or so years.
Kip
2015 Skyline Dart 214RB
2018 Silverado Double Cab 4x4
Andersen Hitch
DutchmenSport
Between Anderson, Pendleton, & Lapel, Indiana
Posted: 03/07/18 10:18am Link  |  Quote  |  Print  |  Notify Moderator
If the wall or space behind the intended screw is hallow, then a Molly bolt mount is probably your best bet.
If the wall is styrofoam filled, there's Molly's won't work, neither will expanding bolts, as the styrofoam won't allow the expansion. In that case, glue another board on the surface and use regular screws to hold it in place, or a nail gun with finishing nails. After the glue sets up, then you can mount anything to the additional thickness of wood with a normal wood screw.
If attaching anything to an outside wall, make absolutely sure the screw you are using is shorter than the thickness of your wall.
Attaching a cabinet to the wall, you really need to hit the studs. Although with enough glue (like original Liquid Nails) with a few nail gun finishing nails to hold it in place, will also do the trick pretty well. Just make sure the nails are long enough to go through the cabinet back and the paneling on the wall, but not so long it penetrates the outside wall of the camper.
DutchmenSport
2019 Montana High Country 375FL Fifth Wheel
2014 Chevy Silverado 3500 Duramax Dually
2 Dachshunds, 1 cat, 2 even older folks now, but still lots of love!
And yes, it really does have a door on the opposite side:
GrandpaKip
Flat Rock
Posted: 03/08/18 08:09am Link  |  Quote  |  Print  |  Notify Moderator
I would not try to glue anything to the paneling in a camper. It may stick at first and it may stick forever. Murphy says that either the glue will fail or will end up peeling a section of vinyl/paper covering off the wall, leaving a patch of bare luaun.
seekingsummits
Fishers IN
Posted: 04/20/18 10:53am Link  |  Quote  |  Print  |  Notify Moderator
Im looking at the same idea. Im looking to mount this to
Tv mount to my exterior. https://www.amazon.com/gp/aw/d/B071XDW3LD
Its only going to have a 32in tv and just when we are oarked obviously. Suggestions for best mounting method?
Thanks
Adam
seekingsummits
Fishers IN
Posted: 04/20/18 10:54am Link  |  Quote  |  Print  |  Notify Moderator
Just for some extra info my 2017 outback 325bh has the fiberglass exterior vs the corregated metal panels if that matters.
