RV.Net Open Roads Forum: ARRRRRRRGH!! I Can't Put It Back Together! UPDATE!!
 > ARRRRRRRGH!! I Can't Put It Back Together! UPDATE!!
Mike LeClair
Wetaskiwin, Alberta
Posted: 03/07/18 12:47pm Link  |  Quote  |  Print  |  Notify Moderator
SIGH! We Managed to melt half a pound of butter all over the stop top and down onto the catch pan of the stove top. It is a MAYTAG GAS RANGE Model # CLY2220BDB. I had to take the central flash burner tube assembly apart to clean the goop off of the piece and the two spring clips came off before I could see how they were attached.
Could somebody with a similar type stove top take a close up picture of the central flash tube assembly and post it up either here or in a PM so that I can figure this out? I downloaded the manual for this range. However, the schematic was of no help in detailing the assembly of the flash tube unit.
Thanks and Cheers!
Mike
* This post was edited 03/08/18 05:26pm by Mike LeClair *
Something Old, Something New
2012 F350 SRW, 6.7l Powerstroke, 3.55's front and rear.
2008 Fleetwood Regal 325RKTS
Mike, Carol and our 4 legged "furry child" Kenzie Shweenie Tod
K Charles
Connecticut
Posted: 03/07/18 01:08pm Link  |  Quote  |  Print  |  Notify Moderator
Your manual is here it has a parts breakdown.
WNYBob
Tonawanda, NY
Posted: 03/07/18 02:23pm Link  |  Quote  |  Print  |  Notify Moderator
First rule of "inelegant tinkering" is keeping all the parts!
gbopp
The Keystone State
Posted: 03/07/18 02:42pm Link  |  Quote  |  Print  |  Notify Moderator
I take pictures before I take unfamiliar stuff apart.
Mike LeClair
Wetaskiwin, Alberta
Posted: 03/07/18 07:15pm Link  |  Quote  |  Print  |  Notify Moderator
Hi guys! Thanks for your replies! Unfortunately, there is no joy in the kitchen and no nookie in the bedroom if I don't get this fixed! Yes, I already have the manual and the schema that it shows does not give the image that I need! No, I haven't lost any parts, I just can't get them back together properly! I do like your term "inelegant tinkering". Too late now to preach to the choir about taking before pictures. That is my normal practice for engines and other complex things. I guess my overconfidence told me "phhht! how complicated can it be". Well, now I know!
What I really need is a picture of the complete, installed in place unit that shows me where these darned spring clips/hooks attach to.
Thanks again folks!
Mike
MEXICOWANDERER
las peƱas, michoacan, mexico
Posted: 03/07/18 07:58pm Link  |  Quote  |  Print  |  Notify Moderator
I got my butt kicked doing an R&R on a tilt and telescope '76 Corvette steering column. Forever knocked the sass out of me. An entire humble pie right in the kisser
Big Dog2
Alberta
Posted: 03/07/18 08:33pm Link  |  Quote  |  Print  |  Notify Moderator
Mike: I know you have the manual and it does not show you the information you require. I followed the link provided by K Charles and there is a "chat with a pro" button. Perhaps you can request a picture of the burner assembly you require. Just a thought. Good Luck.
I am living proof that you are never too old to do something foolish.
Ski Pro 3
Placerville, CA
Posted: 03/07/18 08:54pm Link  |  Quote  |  Print  |  Notify Moderator
Try this;
Open Google Search
Enter the part # only and enter; CLY2220BDB
Click on the 'image' button at the top of the page.
See if any of those images give you what you need.
This should find a lot of photos including those on any forum others have taken and posted.
2006 Dodge Ram 4x4 crew cab w/diesel and manual tranny.
2012 Lance 855S camper
Mike LeClair
Wetaskiwin, Alberta
Posted: 03/08/18 08:52am Link  |  Quote  |  Print  |  Notify Moderator
Hi everyone!! Well, I followed the preceding helpful suggestions and trolled the infinite world wide web for any kind of picture of the fully assembled flash tube assembly and every road led to pretty much the same exploded view of the assembly that does not show how the spring wires attach to the tubes. Today I will try to follow the "ask a pro" lead and see if that produces a positive reply. I'll keep the thread updated until I get a picture of the assembly.
Cheers!
Mike
Bill.Satellite
Full-timer
Posted: 03/08/18 09:05am Link  |  Quote  |  Print  |  Notify Moderator
Then post a picture of what had you stumped and what you found out to be right so we will all be able to sleep a little better knowing you are getting nookie again!
What I post is my 2 cents and nothing more. Please don't read anything into my post that's not there. If you disagree, that's OK.
Can't we all just get along?
