RV.Net Open Roads Forum: Tech Issues: Asking Collective Wisdon Gnawing Plastic Reinforcing Ridges
 > Asking Collective Wisdon Gnawing Plastic Reinforcing Ridges
MEXICOWANDERER
las peñas, michoacan, mexico
Posted: 03/07/18 05:25pm Link  |  Quote  |  Print  |  Notify Moderator
Boing! Light Bulb! I was using the wrong cognitive!
RASP!
It's for plastic
Problem solved. Thanks for the helping hand!
Matt_Colie
Southeast Michigan
Posted: 03/07/18 05:38pm Link  |  Quote  |  Print  |  Notify Moderator
Mex,
If you plan to run that tool in your good drillmotor, be ready to kiss it good bye....
No drillmotor has bearings for that kind of side load.
If you can use the flexshaft tool to do it, that probably has the bearings for it.
Me? I would start with a sharp wood chisel and a hammer until it was mostly gone. That way I could cut nearly flush to the bottom.
Matt
Matt & Mary Colie
A sailor, his bride and their black dogs going to see some dry places that have Geocaches in a coach made the year we married.
MEXICOWANDERER
Posted: 03/07/18 07:06pm Link  |  Quote  |  Print  |  Notify Moderator
Plastic? Ratz. Burr is a quarter -- Dremel is eighth inch shaft
landyacht318
Near a large body of salty water
Posted: 03/07/18 08:02pm Link  |  Quote  |  Print  |  Notify Moderator
Flush cut wire cutters, followed by the dremel with rotary burrs to flatten them out.
Done it, might not even need the rotary burr file.
MrWizard
Traveling
Posted: 03/08/18 12:30am Link  |  Quote  |  Print  |  Notify Moderator
$20 at HF under $30 on Amazon, $24 at walmart
oscilating multi tool
tool with plunge blade, make quick work of that plastic
Radiate The Happy
1997 F53 Bounder 36s
