RV.Net Open Roads Forum: Travel Trailers: ?replace broken glass in framed crank-out window?
 > ?replace broken glass in framed crank-out window?
jomarex
tx
Posted: 03/07/18 02:18pm Link  |  Quote  |  Print  |  Notify Moderator
I have an "older" travel trailer (2001 Layton 250LT)
Ice falling off power lines as I drove down the highway broke the bottom part of the front window, the part that has a frame, and it cranks out.
Before I try to take it all apart and find out I've wasted my time -- is that frame maybe glued together at the top, or how can I get a new piece of glass in there? It's not worth trying to find and pay $$$ for a whole new window....
Web-searching has found nothing.
TIA
beemerphile1
Ohio
Posted: 03/07/18 02:51pm Link  |  Quote  |  Print  |  Notify Moderator
A glass shop should be able to fix it without trouble.
2006 Weekend Warrior FK1900
MFL
Midwest
I would call one of the places that cuts glass/makes windows. They have likely had some experience replacing RV window glass. They could either do it for you, or maybe tell you how to remove the glass, cut it for you, if you'd rather do the work yourself.
Jerry
jomarex
tx
Posted: 03/07/18 03:03pm Link  |  Quote  |  Print  |  Notify Moderator
Small town, doesn't seem to be any glass places anywhere near here...
ndrorder
Southwest
Posted: 03/07/18 04:21pm Link  |  Quote  |  Print  |  Notify Moderator
There are lots of different crank out window styles. Lots of different ways to replace the glass. Posting a photo might help people understand what you have.
Also, in some rural areas, hardware and/or feed stores will sometimes sell glass.
__________________________________________________
Cliff
2011 Four Winds Chateau 23U
jomarex
tx
Posted: 03/07/18 05:00pm Link  |  Quote  |  Print  |  Notify Moderator
jomarex
tx
Posted: 03/07/18 05:03pm Link  |  Quote  |  Print  |  Notify Moderator
http://s1146.photobucket.com/user/jmr1111/library/
i really don't know how to get pics on here, but that address seems to go to my window pics
* This post was edited 03/07/18 05:26pm by jomarex *
Yeti plus
S.W. Ontario
Posted: 03/07/18 05:36pm Link  |  Quote  |  Print  |  Notify Moderator
Home Depot has Lexan sheet that you could cut to fit and hold it in with a good quality caulking compound.
As others have said hardware stores sometimes have ability to cut glass, not sure of the round corners, and it won't be tempered.
A large plastic bag and duct tape might get you to a place large enough to have better access to a permanent repair.
2014 Chevrolet 3500 CC 4X4 Duramax, Tork Lift Tiedowns, TorkLift Fastguns, Superhitch and supertruss
2009 Jayco 213
2008 Bigfoot 25C9.4
IAMICHABOD
Sunny So Cal
Posted: 03/07/18 06:51pm Link  |  Quote  |  Print  |  Notify Moderator
This may work Click here
Former El Monte RV Rental
Buying A Rental Class C
Chevrolet Based Class C
KCFDCapt
At Home
Posted: 03/07/18 07:24pm Link  |  Quote  |  Print  |  Notify Moderator
When I broke the window on my previous 5W, the glass shop had me bring in the frame. He made a cardboard pattern and sent it to his supplier. They cut the glass and then tempered it. I brought the frame back for installation.
You can call around to find a shop who will do the work. If your window is the non moveable section, it will probably require two trips by the shop to complete the installation.
