RV.Net Open Roads Forum: Tech Issues: 30amp to 50amp pigtail
 > 30amp to 50amp pigtail
tealboy
orlando, fl
Posted: 03/07/18 06:09pm Link  |  Quote  |  Print  |  Notify Moderator
As a soon to be or wanna be rv-er, wondering if I should pick up this pigtail I saw on clearance at Walmart for $5. Seems cheap enough and something I will eventually need but not sure. It is 30amp male with 18 inches of cord connected to a 50 amp female.
jkwilson
Indiana
Posted: 03/07/18 06:14pm Link  |  Quote  |  Print  |  Notify Moderator
Are you buying a rig with 50A service?
John & Kathy
2014 Grand Design Reflection 303RLS
2014 F250 SBCC 6.2L 3.73
Ed_Gee
Central Oregon coast - Winter in AZ
Posted: 03/07/18 06:21pm Link  |  Quote  |  Print  |  Notify Moderator
I have stayed in a number of locations that did not provide 50A service and had to use a 30A to 50A adapter. I am assuming the original poster intends to purchase a 50A RV.....
Ed - on the Central Oregon coast
2018 Winnebago Fuse 23A
Scion xA toad
BB_TX
McKinney, Texas
Posted: 03/07/18 06:22pm Link  |  Quote  |  Print  |  Notify Moderator
Can’t go wrong for $5. Whether you ever need it or not.
near La Cuesta Encantada
Posted: 03/07/18 06:24pm Link  |  Quote  |  Print  |  Notify Moderator
“Seems cheap enough and something I will eventually need..” Possible but are you putting the cart before the horse?
2015 Winnebago 2101DS TT & Tahoe LTZ, 300 watts WindyNation solar-parallel & MPPT, Trojan T-125s. TALL flagpole for US flag. Prefer USFS, COE, BLM, NPS, TVA, USF&WS, state & county camps. Bicyclist! 14 year Army vet - 11B40 then 11A - old MOS 1542 & 1560.
Sam Spade
North Central Florida
Posted: 03/07/18 06:35pm Link  |  Quote  |  Print  |  Notify Moderator
Yes. In some situations you will need it.....IF and only IF you get an RV that is equipped for 50 amp service.
Then....you need to understand that "50 amp service" really is TWO 50 amp feeds for a total of 100 AMPS. So if you plug a "50 amp" RV into a 30 amp feed, you likely will NOT be able to use all of your 110 V stuff at the same time. Like only one A/C for instance.
'07 Damon Outlaw 3611
CanAm Spyder in the "trunk"
Tom/Barb
Oak Harbor, Wa
Posted: 03/07/18 08:09pm Link  |  Quote  |  Print  |  Notify Moderator
I have them all, but never have used them. I'm either on 50 amp or gen-set.
our kids are a 30 amp trailer, they often only see a 50 amp service, so they use a 30 to 50 connector
2000 Newmar mountain aire 4081 DP, ISC/350 Allison 6 speed, Wrangler JK toad.
Bobbo
Wherever I park
Posted: 03/07/18 08:25pm Link  |  Quote  |  Print  |  Notify Moderator
If you are buying a 50 amp RV, then yes. If you are buying a 30 amp RV you should get one with 50 amp male and 30 amp female instead. (And a 15 amp male to whichever rig you buy.)
Bobbo, Linda and the furry kid (45 pound rescue)
JoeTampa
Tampa, FL
Posted: 03/07/18 09:13pm Link  |  Quote  |  Print  |  Notify Moderator
I have used both the 50A receptacle to 30A trailer (when I had a 30A trailer) and the opposite - 30A receptacle to 50A trailer. Usually I've needed these when either the needed receptacle wasn't working, but in some cases, it wasn't available. As I can run all but the 2nd AC unit on the 50A and draw only 24A or so, the 30A works pretty well for me when needed.
I have a 30A generator, so the adapter is useful there as well.
I also have a 15A -> 30A adapter; I can charge the mobile house batteries while the rig is parked at the fixed house. [emoticon]
You never know when you'll be in a "situation", so flexibility is a good thing.
2006 Keystone Cougar 243RKS (First trailer)
2016 Jayco Jay Flight 32BHDS (Traded in)
2016 Jayco Jay Flight 33RBTS (Current)
2006 Chevy Silverado 2500HD 4WD 6.6L Duramax Diesel (LBZ)
Blue Ox Swaypro 1500 WDH
Prodigy P2 BC
Amateur Call AB2M
tealboy
orlando, fl
Posted: 03/08/18 05:06am Link  |  Quote  |  Print  |  Notify Moderator
Appreciate the feedback. For 5nucks , I think I will buy it. I am anticipating I will end up with a DP, 3-5 years old in the $175-225 range so 50 amp svc
