RV.Net Open Roads Forum: Tech Issues: Sunlight vents leak, Dicor time
 > Sunlight vents leak, Dicor time
NinerBikes
Somewhere camping
Posted: 03/07/18 08:42pm Link  |  Quote  |  Print  |  Notify Moderator
What is the proper prep for cleaning up and applying Dicor sealant around items on the roof that could leak, once the Dicor starts showing splits?
azdryheat
Tucson, AZ
Posted: 03/07/18 08:59pm Link  |  Quote  |  Print  |  Notify Moderator
Remove the old sealant and put on the new.
2013 Chevy 3500HD CC dually
2014 Voltage 3600 toy hauler
2011 Harley Ultra Limited
ScottG
Bothell Wa.
Posted: 03/07/18 09:01pm Link  |  Quote  |  Print  |  Notify Moderator
Check the tube but IIRC, it says to use mineral spirits.
You might also consider using Eternabond tape.
Scott, Grace and Wesly
2018 Silver Fox 32A - many mods to come!
H0NDA eu2000i
NinerBikes
Somewhere camping
Posted: 03/07/18 09:07pm Link  |  Quote  |  Print  |  Notify Moderator
Sounds like that's a little more permanent. Does that work around raised surfaces above an EDM roof like flanges from sunlights and such?
ScottG
Bothell Wa.
Posted: 03/07/18 09:14pm Link  |  Quote  |  Print  |  Notify Moderator
really either will work fine.
EB tape does a nice job on uneven surfaces. Just make sure you follow the directions exactly and use a roller to finish it off.
The down side is it's more of a challenge to get off it you ever need to replace the skylight.
EB tape is especially nice for caulking joints that want to crack repeatedly.
MDKMDK
Canada
Posted: 03/07/18 10:10pm Link  |  Quote  |  Print  |  Notify Moderator
Dicor LAP Sealant - How To?
Mike.
2018 Navion 24V "Goldilocks" 2016 JKU "Red"
NinerBikes
Somewhere camping
Posted: 03/07/18 10:15pm Link  |  Quote  |  Print  |  Notify Moderator
Thank you!
MDKMDK
Canada
Posted: 03/07/18 10:24pm Link  |  Quote  |  Print  |  Notify Moderator
You're Welcome. Cleaning up the old stuff is always the big question, and I've seen everything from alcohol to turpentine to mineral spirits mentioned as a good cleaner. If you just use some of the Dicor Roof Cleaner used in the video, you can't go wrong?
John&Joey
Summer-North,Winter-South
Posted: 03/08/18 06:00am Link  |  Quote  |  Print  |  Notify Moderator
Your title says "sunlight," be careful with Dicor on this one. Some skylight makers have a special brand they want you to use so as not to dry out the skylight plastic. Look at your owners manual, or call the maker of the skylight to make sure. They do become brittle and crack if you use the wrong product.
bingford
Utah
Posted: 03/08/18 08:40am Link  |  Quote  |  Print  |  Notify Moderator
Remove the Dicor and use Sikaflex 715 urethane.
Watch this video for ideas:
https://youtu.be/SpCmg8BTuFE
