RV.Net Open Roads Forum: Travel Trailers: Bolts needed for WDH?
 > Bolts needed for WDH?
crazyro
Rock Hill, SC
Posted: 03/08/18 05:08am Link  |  Quote  |  Print  |  Notify Moderator
We recently bought a new to us trailer and the previous owner included the WDH with it. Should I drill holes and throw in a couple of bolts just in case or leave it be? Our old system was mounted under the frame and required them. This one seems fine since it's strapped on top (it's been on the trailer for years from what I understand). Am I worrying too much? [emoticon]
Here's a pic for reference:
TIA,
E.
SoundGuy
S Ontario
Posted: 03/08/18 05:23am Link  |  Quote  |  Print  |  Notify Moderator
Your choice. My WD system uses the same saddle brackets and I found they'd slip a bit out of position so I did install a couple of small self tapping screws to prevent this.
Lynnmor
Red Lion
Posted: 03/08/18 06:45am Link  |  Quote  |  Print  |  Notify Moderator
I think that most are never bolted. If you want to do a super job, drill and bolt it to a tapped plate on the inside.
downtheroad
Pacific Northwest
Posted: 03/08/18 07:27am Link  |  Quote  |  Print  |  Notify Moderator
Not necessary....
Arctic Fox 25Y
GMC Duramax LBZ
Blue Ox SwayPro
SoundGuy
S Ontario
Posted: 03/08/18 07:41am Link  |  Quote  |  Print  |  Notify Moderator
My trailer is still in winter storage but here's a pic I took the other day which shows how I used a couple of small self tapping screws to prevent the WD saddle brackets from slipping. Nothing more is required.
2014 Coachmen Freedom Express 192RBS
2012 Chevy Silverado CC 5.3L 4x4
SoundGuy
S Ontario
Posted: 03/08/18 07:43am Link  |  Quote  |  Print  |  Notify Moderator
downtheroad wrote:
Not necessary....
Until the bracket does slip. [emoticon]
ScottG
Bothell Wa.
Posted: 03/08/18 07:57am Link  |  Quote  |  Print  |  Notify Moderator
No, your not supposed to put bolts in those holes and it isn't needed.
Scott, Grace and Wesly
2018 Silver Fox 32A - many mods to come!
H0NDA eu2000i
path1
Varies with weather
Posted: 03/08/18 09:10am Link  |  Quote  |  Print  |  Notify Moderator
IMO...If you fall off a cliff and all vertical tension is lost and you didn't screw in the bolt in back...you might need to install those heavy duty size 12 or 14 zinc coated screws. In other words no.
SoundGuy
S Ontario
Posted: 03/08/18 09:51am Link  |  Quote  |  Print  |  Notify Moderator
That's why Reese offers self tapping screws Part #58459 for those who do prefer to bolt their lift up frame brackets to their trailer frame. [emoticon]
As I originally replied to the OP - your choice. [emoticon]
troubledwaters
Potomac
Posted: 03/08/18 10:00am Link  |  Quote  |  Print  |  Notify Moderator
Why is it that you always seem to project the image that "my way is the correct way and no other opinions matter"? Even when the word "optional" shows up in your posted image. And don't even go with the "I told the OP it was his choice" yadda, yadda, yadda. You got 4 out of 8 posts on this topic; you're pretty invested in doing it your way.
* This post was edited 03/08/18 10:36am by troubledwaters *
