RV.Net Open Roads Forum: Class A Motorhomes: electric slide lock
 > electric slide lock
D&D Wanderers
Brandon, Manitoba, Canada
Posted: 03/08/18 09:22am Link  |  Quote  |  Print  |  Notify Moderator
Have 08 Newmar Kountry Star with electric slide out locking arms.
When extending the bedroom slide, one lock arm released and the other just runs the motor but does not move. Took the inspection plates off. The shaft coming out of the gear box is not turning.
Newmar customer service says likely a broken pin in the drive. But will not say how to remove the unit from the wall for repair.
Would like to go straight to the company that supplies Newmar, maybe they could give advise.
Anybody had experience with this?
D & D
Cummins pushin Newmar
rgatijnet1
Posted: 03/08/18 11:36am Link  |  Quote  |  Print  |  Notify Moderator
It doesn't look like anyone has been able to help. I have a Monaco coach which also has electric slides. I think what they are talking about is a shear pin.IN other words, it is a pin designed to fail before damage is done to the gears.
On my coach the shear pin is not that hard to get to but I have no idea on your Newmar. Look for a pin in the gearbox that has failed. Sorry I can't help with specifics.
MountainAir05
New Mexico
Posted: 03/08/18 11:39am Link  |  Quote  |  Print  |  Notify Moderator
If you do not see attachment points, then it is under the cover. If you are going to do it, then go for it. If not take it in.
The part might be made for Newmar then you can only buy from them. If not you are going to have to find a part number.
I have had my Newmar slide apart looking for a shear pin before. Some I have gotten form them others from other sources.
dougrainer
Carrolton, Texas
Posted: 03/08/18 12:54pm Link  |  Quote  |  Print  |  Notify Moderator
You have to remove all the exterior flange screws on the lock arm plate. I assume you meant the interior cabinet plastic cover that you removed to see the shaft screw drive. There is no external source to get the info you need. Doug
D&D Wanderers
Posted: 03/11/18 10:44am Link  |  Quote  |  Print  |  Notify Moderator
With out any assistance from Newmar customer service, We managed to remove the lock motor. It was a broken gear case that allowed the gears to slip out of alignment. Just need to find a replacement. Slide runs in and out now but only locks on one end. Good till we get back home.
We are in Mexico so this had to be a DIY project. Real disappointed in Newmar for not even attempting to give help and insisting we take it to a dealer.
dougrainer
Carrolton, Texas
Posted: 03/11/18 12:18pm Link  |  Quote  |  Print  |  Notify Moderator
Just call your selling Dealer and get his people to walk you thru it. Doug
