RV.Net Open Roads Forum: Travel Trailers: Water Filling
 > Water Filling
oyarsa
Central Washington
Posted: 03/08/18 11:30am Link  |  Quote  |  Print  |  Notify Moderator
This may be a no-brainer question, but so far I haven't figured it out.
Since I winterized myself (compressed air method), I'd like to test everything out before our first trip. Problem is, I'm not sure how to fill the tanks with potable water. I don't think our outside faucets are drinkable, so I don't want to use those. Even if I used an attachment to a sink, I would have to have miles of hose to reach.
Any suggestions where/how to fill up at home or in town?
RoyF
Fayetteville Arkansas
Posted: 03/08/18 11:39am Link  |  Quote  |  Print  |  Notify Moderator
I would go ahead and use water from your outside faucet. If the water system (pump, etc.) is working ok, then add bleach to disinfect the system. Drain that water and fill up with potable water at the campsite.
oyarsa
Central Washington
Posted: 03/08/18 11:46am Link  |  Quote  |  Print  |  Notify Moderator
Thanks. I'll have to buy an additional hose to reach, but that wouldn't hurt to have on hand, anyway. I think maybe I'm being overly cautious...
path1
Varies with weather
Posted: 03/08/18 11:47am Link  |  Quote  |  Print  |  Notify Moderator
Outside faucets not drinkable because winterized or?
Iraqvet05
Greenwood, MO
Posted: 03/08/18 12:01pm Link  |  Quote  |  Print  |  Notify Moderator
If you just want to ensure there are no leaks in the system, you can always hook up your air compressor, pressurize the system and listen for air leaks. There is a way to hook up a pressure gauge if you want to do a leak down test properly.
You could also get a 5 gallon water container from WalMart and gravity fill your tank, then use the pump to pressurize the system.
2017 Ford F-250 6.2 gas
2001 Chevy Silverado 2500HD (sold)
2013 Jayco Jay Flight 26BH
US Army veteran
ken56
Tennessee
Posted: 03/08/18 12:58pm Link  |  Quote  |  Print  |  Notify Moderator
Here is the rub, you need to flush your system first then sanitize it before you even think of filling it with potable water for you to use. Use the outside faucet of your home to flush system and see if there are any leaks. You shouldn't be using any of the water you flush things out with anyway. Look up how to sanitize your system. When you go camping are you hooked up to campground water supply or do you run off of your tanks a lot of the time? I do think you are obsessing a bit much over it. Its not that complicated.
Mickeyfan0805
SE Wisconsin
Posted: 03/08/18 02:15pm Link  |  Quote  |  Print  |  Notify Moderator
For me, this is the heart of the question. We rarely use water from the tank, and when we do, it is to flush the toilet, wash dishes or (once in a blue moon) shower. We never consume or cook with water from our tanks. So, for us, using the outside faucet at the house is perfectly acceptable.
oyarsa
Central Washington
Posted: 03/08/18 03:13pm Link  |  Quote  |  Print  |  Notify Moderator
Our house has an irrigation supply, so I'm not entirely sure if the faucet is from irrigation water (though in hindsight, it's more than likely not since it has water to it and I believe irrigation is still shut off for the winter).
We do use mostly the campground water supply.
I'll use the outside faucet to test and sanitize. Now I just need to read up on how to sanitize the system.
path1
Varies with weather
Posted: 03/08/18 03:24pm Link  |  Quote  |  Print  |  Notify Moderator
Fill up system with air...uhmmm
Dangerous...
fill up how much? Does OP have regulator on compressor?
PhilipB
MO
Posted: 03/08/18 03:43pm Link  |  Quote  |  Print  |  Notify Moderator
Sanitizing is easy. Use 1/4 cup bleach per 15 gal. of water. Fill fresh water tank full, then run all your faucets until you smell bleach. Let is sit in lines for an hour, then drain.
You can then fill tank and drain again to get rid of bleach smell, or just know that you'll have a little residual smell first tank of water.
We do a lot of dry camping. We cook, shower and drink from the tank. No issues.
2015 Ram 2500
2013 Raptor 310TS
 > Water Filling
