RV.Net Open Roads Forum: Tech Issues: Microwave Overloading my 3000W inverter
 > Microwave Overloading my 3000W inverter
WTrippe
Tampa
Posted: 03/08/18 04:59pm Link  |  Quote  |  Print  |  Notify Moderator
Hi,
So my generator quit working on me the other day. Until I can find some help to pull it out of my RV and change the starter I've been using my inverter.
I've got a 3000W GoPower pure sine wave inverter. 8x 6v AGM batteries wired as a 12V bank with around 1k AH. Everything is wired with 4/0 gauge wires.
It connects to a transfer switch along with the shore power cord. It also has a relay in there that shuts off the converter when the inverter is on.
It should surely be enough to run my microwave. It's only 800W or 1200W at most. I run the engine to compensate for the voltage drop.
When I try running the microwave the OUTPUT on my remote display maxes out and the inverter shuts off with the overload protection.
Any input is greatly appreciated.
Thanks,
William
* This post was edited 03/08/18 06:39pm by WTrippe *
2oldman
Farmington NM
Posted: 03/08/18 05:02pm Link  |  Quote  |  Print  |  Notify Moderator
The usual suspects are:
- depleted/old batteries
- inadequate wiring. 2/0 should handle it, but you might check for heat buildup
- poor connections
- 12v wiring too long
- something else is on. Water heater? (is this a whole-house install?)
WTrippe
Tampa
Posted: 03/08/18 05:30pm Link  |  Quote  |  Print  |  Notify Moderator
- poor connections
Batteries are less than a year old.
2/0 wires and I believe 10/3 within the transfer switch
Foreman grill, coffee maker, rice cooker all work fine but I think the load displays higher than it should.
whole house? Yes, it connects into my converter so all my outlets have power.
With everything off it takes about 3A on standby according to my remote display. Water heater only uses about 6A but yes it's off.
GordonThree
Northern Michigan
Posted: 03/08/18 05:31pm Link  |  Quote  |  Print  |  Notify Moderator
X2 on 2oldman's suggestions.
My humble opinion, 2-0 isn't enough for that size inverter, but I'm a pessimist and wire for worst case and then some.
2013 KZ Sportsmen Classic 200, 20 ft TT
2017 Ram 2500 4x4, 6.4 HEMI, 4.10 / Auto
GordonThree
Northern Michigan
Posted: 03/08/18 05:33pm Link  |  Quote  |  Print  |  Notify Moderator
Microwave is a heavy inductive load, compared to the other items you listed which are resistive. 1000w could need over 2000 surge to start up.
2oldman
Farmington NM
Posted: 03/08/18 05:34pm Link  |  Quote  |  Print  |  Notify Moderator
WTrippe wrote:
Foreman grill, coffee maker, rice cooker all work fine .
Those are also high draw items, the only difference being MW's have a startup surge. It is possible the 2/0 won't take that.
Try running the air conditioner.
MrWizard
Traveling
Posted: 03/08/18 05:44pm Link  |  Quote  |  Print  |  Notify Moderator
fridge ?
wiring ?
inverter failure ?
MW is on its way out ?
is that 3000 peak watts? or continuous watts
try (2) electric heaters on different circuits
heater and foreman grill
any combo over 2000w and see 'how' it functions
Radiate The Happy
1997 F53 Bounder 36s
Los Angeles :(
Posted: 03/08/18 05:52pm Link  |  Quote  |  Print  |  Notify Moderator
“I run the engine to compensate for the voltage drop.”
So when you...need...to microwave...a real need...you are running your generator AND your TV or MH engine? How about your toad? Kick that engine too. Should be enough.
2015 Winnebago 2101DS TT & Tahoe LTZ, 300 watts WindyNation solar-parallel & MPPT, Trojan T-125s. TALL flagpole for US flag. Prefer USFS, COE, BLM, NPS, TVA, USF&WS, state & county camps. Bicyclist! 14 year Army vet - 11B40 then 11A - old MOS 1542 & 1560.
WTrippe
Tampa
Posted: 03/08/18 06:08pm Link  |  Quote  |  Print  |  Notify Moderator
MrWizard wrote:
fridge ?
wiring ?
inverter failure ?
Fridge runs off the propane.
I started up the coffee maker without the engine running so I could see the draw.
I'm using about 900W, 75A with it running and batteries holding at 12.4 V
remote display on the inverter is showing a 50% output which is too high.
http://gpelectric.com/products/3000-watt-pure-sine-wave-inverter
3000W continuous, 6000W surge.
Mandalay Parr
Phoenix, AZ
Posted: 03/08/18 06:12pm Link  |  Quote  |  Print  |  Notify Moderator
My 2000 watt MSW inverter runs my big microwave just fine.
I agree with all suggestions above.
Jerry Parr
Full-time
2005 Mandalay 40B
Cat C7 350, 4 Slides
Blue Ox, Brake Buddy
2004 CR-V Toad
jrparr@att.net
602-321-8141
K7OU - Amateur Radio
Kenwood Radios
ARRL, W5YI, & LARC VE
SKYWARN Weather Spotter
