RV.Net Open Roads Forum: Tech Issues: Microwave Overloading my 3000W inverter
 > Microwave Overloading my 3000W inverter
time2roll
Posted: 03/08/18 06:12pm Link  |  Quote  |  Print  |  Notify Moderator
Yes very odd. You are certain there are no other loads on before you hit go on the MW?
My GP 2000 SW runs my Dometic MW just fine at about 1700 watts. 4x GC2 no assist unless the sun is shining.
I would be checking actual power draw with a clap-on ammeter. Check both the AC out and the DC in. Also verify DC voltage on the actual inverter terminals.
Has it run the MW previously?
675w Solar pictures back up
WTrippe
Tampa
Posted: 03/08/18 06:18pm Link  |  Quote  |  Print  |  Notify Moderator
GordonThree wrote:
X2 on 2oldman's suggestions.
My humble opinion, 2-0 isn't enough for that size inverter, but I'm a pessimist and wire for worst case and then some.
Manual suggested 4/0 so I stepped it up to 2/0.
WTrippe
Tampa
Posted: 03/08/18 06:21pm Link  |  Quote  |  Print  |  Notify Moderator
Yes it has run the MW before. I remember making popcorn with it when I only had 4 batteries and it would drop the voltage down to below 12V but the output would be around 50% at most. After I got 8 batteries I tried it again and the voltage stayed above 12V with a 50% draw. I didn't use it for a long time I've been using the generator to make coffee and cook with until now.
GordonThree
Northern Michigan
Posted: 03/08/18 06:22pm Link  |  Quote  |  Print  |  Notify Moderator
4/0 is a lot heavier than 2/0
2013 KZ Sportsmen Classic 200, 20 ft TT
2017 Ram 2500 4x4, 6.4 HEMI, 4.10 / Auto
WTrippe
Tampa
Posted: 03/08/18 06:27pm Link  |  Quote  |  Print  |  Notify Moderator
my mistake, I checked my amazon orders.
This is the wire I used.
https://www.amazon.com/gp/product/B00LIB60WW/ref=oh_aui_search_detailpage?ie=UTF8&psc=1
TEMCo WC0342 - 50' (25' Blk, 25' Red) 4/0 Gauge AWG Welding Lead & Car Battery Cable Copper Wire BLACK + RED | MADE IN USA
BFL13
Victoria, BC
Posted: 03/08/18 06:29pm Link  |  Quote  |  Print  |  Notify Moderator
How is the inverter 120v side wired up for what appliances are on what? IE is the MW on a different sub-panel from the other things that work ok? Try plugging in the MW to a receptacle that runs the kettle ok and see if the MW runs ok there.(will need an extension cord )
What is the 3a on standby compared with the 6a water heater? 3a 120v??? Makes no sense. Inverter on standby, no load, would have maybe 1/2 an amp DC although inverter/chargers seem to have more what with their extra "features".
What is the "output" all about? Not following. [emoticon]
Like the others, I have no problem running the MW with a 2000w inverter. But I don't have a remote display and transfer switch and relay etc. I plug the shore power cable into the Inverter and shut off the converter etc manually.
1991 Oakland 28DB Class C
on Ford E350-460-7.5 Gas EFI
SidecarFlip
SE Michigan
Posted: 03/08/18 06:33pm Link  |  Quote  |  Print  |  Notify Moderator
I don't believe your wiring is heavy enough. I use welding cable myself.
2015 Backpack SS1500
1997 Ford 7.3 OBS 4x4 CC LB
BFL13
Victoria, BC
Posted: 03/08/18 07:06pm Link  |  Quote  |  Print  |  Notify Moderator
I have no problem with my MW pulling 120 amps with four feet of #1 AWG (8 ft round trip) staying above the 11 volt alarm with the batts down near 50% SOC. (0.6v drop) He has way fatter wiring than that (don't know how long though).
His readings with the coffee maker are very good, so can't see the inverter-battery wiring as an issue. Something about the complicated installation set -up as to what is wired to what is my guess.
ktmrfs
Portland, Oregon
Posted: 03/08/18 07:17pm Link  |  Quote  |  Print  |  Notify Moderator
sorry 4/0 is much higher capacity than 2/0. 4/0 wire is larger cross section than 2/0.
BTW I use 4/0 with my 1000W sine wave inverter to run my panasonic true inverter microwave. draws about 800VA at 50% power.
and a 1200W microwave refers to the output power of the magnetron. with a 1200W microwave, actual VA draw is likely close to 1600 or even 1800VA. you have the power supply efficiency and the fact it is not a resistive load but an inductive load.
But, with proper wiring and 4 or more 6V batteries, I would expect you should be able to run the microwave.
2011 Keystone Outback 295RE
pianotuna
Regina, SK, Canada
Posted: 03/08/18 07:25pm Link  |  Quote  |  Print  |  Notify Moderator
Hi,
Are the batteries wired in a balanced manner?
Regards, Don
Full Time in a 28 foot Class C, 256 watts solar, 556 amp hours of AGM in two battery banks 12 volt batteries, 3000 watt Magnum hybrid inverter, Sola Basic Autoformer, Microair Easy Start.
