RV.Net Open Roads Forum: What do you run Plex Media Server on?
 > What do you run Plex Media Server on?
RSD559
Central California
Posted: 03/10/18 11:35pm Link  |  Quote  |  Print  |  Notify Moderator
I'm looking for a way to keep something plugged in all the time to run Plex Media Server so I don't have to keep a laptop on. It will live in a little cubby above the refrigerator with the router. I've looked at a WD Passport Pro wireless NAS, but it turns the WIFI off whenever you have it charging. That's worthless. I'm looking at using a Raspberry Pi 3, but it's WIFI may be too slow to communicate with the router and the Roku device at the same time. We use Plex to keep up with the few network TV shows we watch anymore (commercial free). Anyone do anything similar to this? Let me know about your setup. Thanks.
2017 Highland Ridge Ultra Lite UT2704bh.Just right ++
Ford F-150 Ecoboost V6. Very happy.
Honda Ruckus scooter - Great fun.
Suzuki Burgman 400 scooter - Greater fun.
Champion 3100 Inverter Generator - (huge grin)!
Chris Bryant
Arden, North Carolina
Posted: 03/11/18 04:38am Link  |  Quote  |  Print  |  Notify Moderator
Just run cat 5 from the pi to the router- it will be plenty fast.
-- Chris Bryant
My RV Service Blog
The RV.net Blog
mgirardo
Brunswick, GA
Posted: 03/11/18 07:56am Link  |  Quote  |  Print  |  Notify Moderator
I have a Netgear NAS that supports up to 8 TB. The NAS has apps that can be installed, including a Plex Media Server app. We take it with us when we camp seasonally and use it to play music and watch movies. We grab the campgrounds wifi and feed it into our own router for internet. The NAS is wired directly to the router. We also have all our photos and home videos on the NAS, so if anything were to happen to our house while we are away, we won't lose our memories.
-Michael
Michael Girardo
2017 Jayco Jayflight Bungalow 40BHQS Destination Trailer
2009 Jayco Greyhawk 31FS Class C Motorhome (previously owned)
2006 Rockwood Roo 233 Hybrid Travel Trailer (previously owned)
1995 Jayco Eagle 12KB pop-up (previously owned)
LittleBill
Scranton, PA USA
Posted: 03/11/18 08:11am Link  |  Quote  |  Print  |  Notify Moderator
lets be careful with some of these devices. if plex decides to transcode, a PI or any other low end device will not have the cpu grunt to keep up with the transcode.
Now if you have ability to convert all your files into a format your player can "Direct play" then yes the server does not do anything but move the media.
Synology makes units that can transcode directly off the NAS and use low power.
Kodi in my opinion can be better in this situation as the client itself does the conversion and simply needs storage tied to it.
punomatic
Pacific Northwest
Posted: 03/11/18 08:12am Link  |  Quote  |  Print  |  Notify Moderator
I run a Pi3 at home for my Plex media server. It works fine. I can stream from it even when I am away from home, as long as the local wi-fi network where I am has adequate bandwidth. My Pi is connected to my home router via ethernet cable, and I stream to several Rokus, an Apple TV and a smart TV.
I also have a Pi in my TT that I use as a local server with all of my movie and music collections on a USB HDD. We are never without electronic entertainment at our beck and call.
I also use the Pi in the TT as a client to stream from my PMS on the Pi at home.
DW me, and Lulu (the Moxie with moxie!)
2016 Riverside White Water Retro 195
2014 Nissan Titan SL Crew Cab
Formerly, I used to work for the department of redundancy department.
Life in Black and Blue
LittleBill
Scranton, PA USA
Posted: 03/11/18 08:33am Link  |  Quote  |  Print  |  Notify Moderator
Does all your stuff direct play? or your saying it can handle the transcoding as well? sd content or hd content as well?
phemens
Montreal, Canada
Posted: 03/11/18 11:14am Link  |  Quote  |  Print  |  Notify Moderator
I have the WD Passport Pro wireless. Just got it, but I believe it only turns off the wireless if connected to a PC, since it uses the USB connection for data transfer. I picked up a 12v to 5v converter to hard wire the charger into the 12v system in the RV, seems to work well.
I use Kodi on a Raspberry Pi and an Nvidia Shield to access the HD. The advantage to the Passport is that I can access the media on any other device - iPad, etc.
2012 Dutchman Denali 324LBS behind a 2006 Ford F-250 V10 out of Montreal
1 DW, 1 DD, 1 DS, 2 HD (Hyper Dogs)
1Kw solar, 630 AH Rolls wet cells, Yamaha EF2000 genny
RSD559
Central California
Posted: 03/11/18 11:29am Link  |  Quote  |  Print  |  Notify Moderator
I checked for WIFI when I plugged the charger in and plugged it into the USB 3.0 port. No WIFI. Tried the USB 2.0 port too. No charge.
And no way to plug it into the Router. I don't believe I will need any transcoding, since we only stream our TV shows to our Roku.
RSD559
Central California
Posted: 03/11/18 11:35am Link  |  Quote  |  Print  |  Notify Moderator
I did order a Raspberry Pi 3 to give it a shot. Should be fun. I've wanted one for a couple of years to play with, but had no excuse to get it. Now I do. I've been programming computers for over 35 years. From mainframes to PCs. So this could be really fun! I found a script for setting up the Pi as a Plex Media Server. We'll see how it goes. The router is up where the PMS will be, so a direct connect to the router is a good idea.
GordonThree
Northern Michigan
Posted: 03/11/18 04:03pm Link  |  Quote  |  Print  |  Notify Moderator
If transcoding is a concern, the Pi has hardware accelerated h.264 encoding and decoding. I believe up to 30hz encoding and 60hz decoding at 1080p. There's newer boards based on more powerful SoC that will transcode h.265 and 4k video if that's your application.
2013 KZ Sportsmen Classic 200, 20 ft TT
2017 Ram 2500 4x4, 6.4 HEMI, 4.10 / Auto
