RV.Net Open Roads Forum: Tow Vehicles: Aluminum body damage video
Search only in Tow Vehicles
 > Aluminum body damage video
RSD559
Central California
Posted: 03/13/18 05:26pm Link  |  Quote  |  Print  |  Notify Moderator
Here as a link to YouTube where an F250 aluminum body was in a wreck. Pretty interesting. It also stated that GM will be going to aluminum in 2019.
Big Truck Big RV
2017 Highland Ridge Ultra Lite UT2704bh.Just right ++
Ford F-150 Ecoboost V6. Very happy.
Honda Ruckus scooter - Great fun.
Suzuki Burgman 400 scooter - Greater fun.
Champion 3100 Inverter Generator - (huge grin)!
Trackrig
Spent the summer in Conconuly, Wa, MH now in Vanco
Posted: 03/13/18 05:52pm Link  |  Quote  |  Print  |  Notify Moderator
I thought I saw recently GM was going to carbon fiber, for the beds anyways. The article was talking about when they dropped bricks into the bed they had to chain them together because they were bouncing out and almost hitting the observers.
Bill
Nodwell RN110 out moose hunting. 4-53 Detroit, Clark 5 spd, 40" wide tracks, 10:00x20 tires, 16,000# capacity, 22,000# weight. You know the mud is getting deep when it's coming in the doors.
BenK
SF BayArea
Posted: 03/13/18 05:56pm Link  |  Quote  |  Print  |  Notify Moderator
"Sheetmetal" includes any kind of metal...aluminum too... [emoticon]
Military grade is similar in misconception...6061T is used by the military and can be marketed when used in non-military applications as "military grade" aluminum...pure marketing to those not in the know (not educated on the matter)
As said in the initial days of Fords announcement...aluminum is a GREAT material in the proper application, but...IMHO...not for a pickups bed
Why Ford made (according to this video) made the bed thicker than steel 'sheetmetal'... [emoticon]
Tensile strength and hardness/toughness for this application is not up to that task
Anyone have a aluminum shovel used for dirt/gravel/etc...other than one made for snow/horse poop/etc ?
Or a chisel, center punch, hacksaw blade, pocket knife blade, etc ? There is a reason for that...
Carbon fiber is nothing more than fiberglass (think window glass spun into fine fibers), but with a higher tensile strength fiber. The binder resins are better than the stuff in fiberglass, but still a resin Bill thanks for bringing that into this discussion...and wonder if folks believe every word... [emoticon]
Ditto any of the other materials that are *WONDERFUL* for another application, but IMHO, not a good idea for a working pickup bed
-Ben Picture of my rig
rhagfo
Portland, OR
Posted: 03/13/18 06:16pm Link  |  Quote  |  Print  |  Notify Moderator
Maybe we should go back to wood PU bed floors!
hone eagle
essex ontario canada
Posted: 03/13/18 06:21pm Link  |  Quote  |  Print  |  Notify Moderator
Carbon fibre is rayon cooked in a de oxygenated oven (from memory) not fibreglas which is pulled /spun glass ,it can either be E glass -think glass fibre insulation or S glass (structural) which has the properties of carbon but heavier .
2005 Volvo 670 singled freedomline 12 speed
Newmar 34rsks 2008
Hensley trailersaver TSLB2H
directlink brake controller
-when overkill is cheaper-
ScottG
Bothell Wa.
Posted: 03/13/18 07:40pm Link  |  Quote  |  Print  |  Notify Moderator
Sounds and looks like it did a fine job and I think it's a good application for it.
Scott, Grace and Wesly
2018 Silver Fox 32A.
H0NDA eu2000i
FishOnOne
The Great State of Texas
Posted: 03/13/18 08:50pm Link  |  Quote  |  Print  |  Notify Moderator
The new Fords have the best crash performance in the industry and having thicker aluminum panels is much better than very very thin steal panels that have been the trend the last few decades in order to reduce weight.
'12 Ford Super Duty FX4 ELD CC 6.7 PSD 400HP 800ft/lbs
"Built Ford Proud"
'16 Sprinter 319MKS "Wide Body"
valhalla360
No paticular place.
Posted: 03/14/18 02:29am Link  |  Quote  |  Print  |  Notify Moderator
Reality is they usually replace whole panels if there is any significant damage (steel or aluminum), so not a big deal from a repair point of view.
If someone dumps a palette of bricks from 5' up into my steel truck bed, I'm going to be ticked off. 99% will never see that kind of use. Most construction guys if they use the truck bed hard will put a bed liner/mat or a piece of plywood to take the brunt of the hard abuse.
On the other hand, try to find a 8yr old truck in the midwest where the wheel wells aren't rusted out. Aluminum will eliminate this issue.
PS: Fiberglass in common usage reference GRP (Glass Reinforced Plastic). Carbon Fiber is a specialty product used to replace the glass fibers for more strength and in common usage is often still refereed to as Fiberglass. Honestly, it's surprising they don't use more GRP. Love em or hate em, look at the Pontiac Fiero or the Corvette. 30-40yrs old and the bodies still are perfect if they haven't gotten into a crash.
Tammy & Mike
Ford F250 V10
2008 Copper Canyon 5er
Catalac Catamaran 34'
Full Time spliting time between boat and 5er
4x4ord
Alberta
Posted: 03/14/18 04:38am Link  |  Quote  |  Print  |  Notify Moderator
I threw a sheet of osb in the back of my truck when I got it. I like the wood as much aa a spray in liner
2017 F350 SRW Platinum short box 4x4.
B&W Companion
camp-n-family
London, Ontario
Posted: 03/14/18 07:17am Link  |  Quote  |  Print  |  Notify Moderator
Aluminum good or not, I wouldn’t want that truck back.
'17 Ram 2500 Crewcab Laramie CTD
'13 Keystone Bullet Premier 310BHPR
Hitched by Hensley
