buc1980
houston tx
2 days ago I install the new steps Torqflex revolution on my 5th.What a big difference in the way to walk on them.Before when I step on them it fill soft and unsecured now with the new steps I can jump on them and it don't move at all ,what a improvement.
2017 Ford F350 DRW,2005 Kountry Star 35ft,16750 lb weight on SAILUN tire,6 points LIPPERD Level-up.New Mor/ryde IS suspension install.Full body paint 2022.
RollandB
Albany, Or
We made the same change and love the Torklift steps.
2013 Yukon
2021 Coachmen Spirit 1943RB
fj12ryder
Platte City, MO
A simple drop down support on the OEM steps will work very similarly without a huge expenditure of green stuff.
I changed out my OEM three step to a QuadraStep 4 step. Makes getting in so much easier. These tall trailers need 4 steps as OEM. Peggy didn't think they would make that much difference...until the first time she used them, instant convert.
Howard and Peggy
"Don't Panic"
ford truck guy
Pennsylvania
We just put the Glow Step Revolution on a 15 Jayco Premier.. What an improvement.. I agree, Big Difference..
Me-Her-the kids
2020 Ford F350 SD 6.7
2020 Redwood 3991RD Garnet
Bob Vaughn
Seffner, Fl.
I just installed the 4 step version on a 2011 Heartland Big Country 5th wheel and will never go back to OEM steps.....
Planning
Idaho
Anyone using the MorRyde Step Up?
http://www.morryde.com/products/195-the-step-up?return=%2Fproduct-category%2F12-steps
2016 AF 29-5K; 2016 F350 6.7, 4x4, CCLB DRW
fj12ryder
Platte City, MO
Yeah, I think I'll give that a big pass. One more thing to mess with, and fix when it messes up.
pcm1959
home
I loved it (just kidding but it was funny) when I say a couple at a rest stop with the Mor Ryde solid steps out for a rest break. A moving truck semi came in beside them. They could not put the steps in due to the clearance needed.
I'm passing on those, too.
They should make them with a split in them similar to pull-down attic stairs then tight spots (including storage areas) may not be as problematic. But then I guess they probably would be as stable or light.
2018 GMC Sierra 3500 DRW 4x4 Duramax/Allison
2014 Lifestyle LS36FW
St Augustine, FL
fj12ryder
Platte City, MO
pcm1959 wrote: I loved it (just kidding but it was funny) when I say a couple at a rest stop with the Mor Ryde solid steps out for a rest break. A moving truck semi came in beside them. They could not put the steps in due to the clearance needed.
They should make them with a split in them similar to pull-down attic stairs then tight spots (including storage areas) may not be as problematic. But then I guess they probably would be as stable or light. I've looked at the solid steps at the RV shows and they simply wouldn't work for us when the trailer is in storage. The trailers are close enough there wouldn't be enough room to lower the steps. They look like a good idea, but I'm not sure the execution will work at all times.
Bob Vaughn
Seffner, Fl.
fj12ryder wrote: pcm1959 wrote: I loved it (just kidding but it was funny) when I say a couple at a rest stop with the Mor Ryde solid steps out for a rest break. A moving truck semi came in beside them. They could not put the steps in due to the clearance needed.
I have my 5th wheel in a storage bldg and the More Ryde would not have allowed me to put the steps out while in the bldg. but the Revolution telescopes and gives me access even when I am not centered in the bldg....
