RV.Net Open Roads Forum: Fifth-Wheels: Surge Protector
 > Surge Protector
Me Again
Sunbird(Wa)/snowbird(Az)
Posted: 04/12/18 06:00pm Link  |  Quote  |  Print  |  Notify Moderator
With 30amp service a portable one is ok. With 50amp service a hard wired one in much better. If you loose neutral on a 50amp circuit you burn up all the AC items with 240 volts across them. Hard wired just ahead of the circuit panel protects you from problems with the power cord and cord reel if you have one.
PI with remote is the way to go.
Chris
2021 F150 2.7 Ecoboost - Summer Home 2017 Bighorn 3575el. Can Am Spyder RT-L Chrome, Kawasaki KRX1000. Retired and enjoying it! RIP DW 07-05-2021
Dennis M M
Winter in Tucson, AZ; summer on the road
Posted: 04/12/18 06:08pm Link  |  Quote  |  Print  |  Notify Moderator
I have a Progressive Industries EMS-LCHW 50 that is a bit over ten years old. Started acting weird late last summer. Would take 5 to 20 minutes to start scan told him one issue - no receipt! He said OK, plan B, I'll send you a new circuit board! He sent free circuit board, I installed, works fine!
BTW these units are much more than a simple surge guard. They protect against a lot more issues than just a power surge.
'99 Volvo VNL610 - 425 HP Volvo; Super 10 Spd
'13 smart CityFlame on Volvo
'05 Newmar Mountain Aire 35 BLKS
Trailer Saver; Bigfoot; Pressure-Pro.
Our Travel Blog - A New Adventure
StephJohn2010
Black Hills, South Dakota
Posted: 04/12/18 08:29pm Link  |  Quote  |  Print  |  Notify Moderator
Progressive Industries produces a high quality product. I have a build in/hardwired one.
John & Steph
2012 Fleetwood Discovery 40x (35,000 miles)
380 HP Cummins with an Allison Transmission - Freightliner Chassis
2015 Jeep Cherokee Limited Active Drive II
Paul Clancy
BC Canada
Posted: 04/13/18 12:42am Link  |  Quote  |  Print  |  Notify Moderator
I have the pt50x and am happy with it. I feel it is worth the peace of mind.
ACZL
UPstate,NY
Posted: 04/13/18 02:22am Link  |  Quote  |  Print  |  Notify Moderator
Check w/ Tweety's as well for price. Bought the EMS 50 last year (unit still in storage, but think it's same as being mentioned). Very well built unit and really like the features. Also bought a cable lock yo secure it to the power pole. Bit overboard perhaps, but should keep the 300 bucks spent safe.
2017 F350 DRW XLT, CC, 4x4, 6.7
2018 Big Country 3560 SS
"The best part of RVing and Snowmobiling is spending time with family and friends"
"Catin' in the Winter"
pianotuna
Regina, SK, Canada
Posted: 11/30/21 08:31am Link  |  Quote  |  Print  |  Notify Moderator
I always check the voltage under load before I plug in.
Regards, Don
TXiceman
Full Time RVer
Posted: 11/30/21 03:42pm Link  |  Quote  |  Print  |  Notify Moderator
How do you check under load before you plug in Unless you have load cell?
Ken
Amateur Radio Operator.
pianotuna
Regina, SK, Canada
Posted: 12/01/21 02:13pm Link  |  Quote  |  Print  |  Notify Moderator
Ken
Since I am in a 30 amp RV, I made a 30 amp to 20 amp box, with 4 outlets. That allows me to plug in two high draw items. For example a hair drier, or the like. I plug in a kill-o-watt meter set for voltage. in another of the 4 outlets.
Allworth
Orlando, FL
Posted: 12/01/21 02:52pm Link  |  Quote  |  Print  |  Notify Moderator
Progressive Industries.
You can't buy the parts to run all the different tests a PI EMS does for what they cost.
Formerly posting as "littleblackdog"
Martha, Allen, & Blackjack
2006 Chevy 3500 D/A LB SRW, RVND 7710
2008 Titanium 30E35SA; EZ-Lube axles; wet bolts; spring hanger gussetts; BFG Commercial TAs
"Real Jeeps have round headlights"
work2much
On the Road
Posted: 12/01/21 09:25pm Link  |  Quote  |  Print  |  Notify Moderator
I have always used PD units but on the new Rig I went with a Hughes Watchdog. Progressive makes a quality product but Hughes has some advantages.
It has bluetooth app which is handy to alert when it disconnects from shore and also allows me to see where power is being used between legs of power. This is helpful to see what use and voltage is on each leg.
I went hard wired as I don't need to worry about theft or extra moves hooking up as well as extra friction electrical connections. (plugs) that aren't always great electrical connections. I mounted it in with the rest of the equipment.
In the last year it has disconnected power twice due to under and over voltage conditions. Each time giving me an alert on my phone. Each time being an unsafe condition from the parks electrical.
2022 Ram 3500 Laramie CTD DRW Crew 4x4 Aisin 4:10 Air ride.
2020 Grand Design Solitude 2930RL 2520 watts solar. 600ah lithium. Magnum 4000 watt inverter.
 > Surge Protector
