RV.Net Open Roads Forum: Class A Motorhomes: 1997 Southwind ignition key
 > 1997 Southwind ignition key
Fletch_03
Walla Walla
Posted: 04/16/18 10:45am Link  |  Quote  |  Print  |  Notify Moderator
I'm looking for some help regarding an ignition key for a 1997 Southwind. My dad recently passed away and all I can find is a door key to unlock the door. The only key that even fits into the ignition is a silver GM style key. Should I be looking for a GM style key? He has accumulated hundreds of keys over the years, so I'm just trying to narrow down my search.
Thank you in advance for any information that you can provide.
donn0128
Pronounced Ore-gun
Posted: 04/16/18 10:55am Link  |  Quote  |  Print  |  Notify Moderator
Chassis will tell you what type of key you need.
MrWizard
Traveling
Posted: 04/16/18 11:13am Link  |  Quote  |  Print  |  Notify Moderator
look at the VIN sticker, under the drivers window
if its GAS, then it is either GM or Ford
if its FORD, it will probably say FORD on the steering wheel
along with ford motor company on the VIN sticker
given that you didn't say anything about seeing 'FORD' anywhere
yes you are most likely looking for a Chevy key
Radiate The Happy
1997 F53 Bounder 36s
Fletch_03
Walla Walla
Posted: 04/16/18 11:18am Link  |  Quote  |  Print  |  Notify Moderator
Sorry, I should have added that it's a Freightliner chassis.
gfs1943
Whitney, Texas
Posted: 04/16/18 11:52am Link  |  Quote  |  Print  |  Notify Moderator
Freightliner chassis usually use a GM ignition switch and key. Likely one of the Chevy-style keys will fit.
gfs1943
USAF, Retired (1962 - 1983)
2006 Monaco Diplomat 40PRQ
2006 Honda CR-V
crasster
Dallas
Posted: 04/16/18 12:50pm Link  |  Quote  |  Print  |  Notify Moderator
It may just be easier to put a new key into it using lock pics to push the cylinder into place? Is it a classic fit key with the small whole to change the cylinder? Often doing so is a 5 minute job.
4 whopping cylinders on Toyota RV's. Talk about great getting good MPG. Also I have a very light foot on the pedal. I followed some MPG advice on Livingpress.com and I now get 22 MPG! Not bad for a home on wheels.
77rollalong
Brighton Ontario
Posted: 04/16/18 02:07pm Link  |  Quote  |  Print  |  Notify Moderator
if you can find the ownership for it, (vin #) you maybe able to go to a dealership for that chassis, and have them cut a key from the vin # alone.
Don's Lock
Clinton On. Canada
Posted: 04/16/18 05:47pm Link  |  Quote  |  Print  |  Notify Moderator
Good luck no codes available for that year .Is it in dah or on the colum .
Let me know and I will give you the centriole what will happen.
Don
2016 Ford Focus
2013 Georgetown 335
RLS7201
Posted: 04/16/18 08:55pm Link  |  Quote  |  Print  |  Notify Moderator
Don't believe Fleetwood made a 1997 Southwind on a diesel Freightliner chassis.
It should be a gas chassis, which would have to be a Ford or Chevrolet.
Richard
95 Bounder 32H F53
460/528 stroker
Web Master
MWPSchooners.com
D.E.Bishop
Eagle Rock, CA
Posted: 04/17/18 12:44am Link  |  Quote  |  Print  |  Notify Moderator
Fletch, I feel that you are over thinking this, if a GMC key fits, take all your dad's keys that look like the GMC key that fits the switch and try them. Probably faster and less hassle is to call a locksmith.
Often locksmiths can cut a key in under 60 seconds and the charge is about $50. If you have or your Dad had roadside service as part of his or your insurance, it won't cost anything.
"I travel not to go anywhere, but to go. I travel for travel's sake. The great affair is to go". R. L. Stevenson
David Bishop
2002 Winnebago Adventurer 32V
95 Suzuki Sidekick 4X4
Stowmaster 5000
