RV.Net Open Roads Forum: New Ram 1500 and it's mild hybrid system
Search only in Tow Vehicles
 > New Ram 1500 and it's mild hybrid system
Acei
Toronto
Posted: 04/16/18 03:20pm Link  |  Quote  |  Print  |  Notify Moderator
Actually, this has more to do with it's battery and how it can be used.
Does anyone know if the lithium battery built into this system can power the accessories within the vehicle?
Looks like that battery can store up to 430wh and since there's a separate lead acid battery, I would guess you can completely drain that lithium battery without any worries.
This could be very useful for those who camp a lot if the 48v lithium battery converts to 12v and directly hooks into accessory power ports.
near La Cuesta Encantada
Posted: 04/16/18 04:37pm Link  |  Quote  |  Print  |  Notify Moderator
I have not seen any manufacturer of lithium batteries recommending a user drain their batteries below 20% SOC.
2015 Winnebago 2101DS TT & Tahoe LTZ, 300 watts WindyNation solar-parallel & MPPT, Trojan T-125s. TALL flagpole for US flag. Prefer USFS, COE, BLM, NPS, TVA, USF&WS, state & county camps. Bicyclist! 14 year Army vet - 11B40 then 11A - old MOS 1542 & 1560.
Posted: 04/16/18 04:44pm Link  |  Quote  |  Print  |  Notify Moderator
Techrepulbic, for instance, says:
“4: Avoid completely discharging lithium-ion batteries
If a lithium-ion battery is discharged below 2.5 volts per cell, a safety circuit built into the battery opens and the battery appears to be dead. The original charger will be of no use. Only battery analyzers with the boost function have a chance of recharging the battery.”
Me Again
Sunbird(Wa)/snowbird(Az)
Posted: 04/16/18 04:57pm Link  |  Quote  |  Print  |  Notify Moderator
Lithium batteries do not like to be completely discharged. Chris
Acei
Toronto
Posted: 04/16/18 05:34pm Link  |  Quote  |  Print  |  Notify Moderator
I'm assuming they took the right precautions to make sure it doesn't get discharged too low...
ScottG
Bothell Wa.
Posted: 04/16/18 06:58pm Link  |  Quote  |  Print  |  Notify Moderator
I would let that system age a couple of years before buying.
Scott, Grace and Wesly
2018 Silver Fox 32A.
H0NDA eu2000i
NJRVer
NJ
Posted: 04/16/18 07:04pm Link  |  Quote  |  Print  |  Notify Moderator
Never had a problem discharging all my tool batteries.
time2roll
Posted: 04/16/18 07:16pm Link  |  Quote  |  Print  |  Notify Moderator
I doubt the RAM will have a DC/DC converter to produce 12 volts like a vehicle that runs just on battery power. If the engine runs 100% of the time there will be an alternator that supplies 12 volt power.
Either way there would be a BMS to protect the lithium from over charge or over discharge.
675w Solar pictures back up
ScottG
Bothell Wa.
Posted: 04/16/18 07:21pm Link  |  Quote  |  Print  |  Notify Moderator
The eng wont run all the time, it will have start/stop technology.
rjstractor
Auburn, WA
430 wh is not much power to work with. A run-of-the-mill lead-acid RV battery is about 100 amp/hours which is roughly 1200 wh. From what I saw in this video the system's main purpose is to provide auto start/stop capability and to essentially act as an electronic "flywheel" to capture some braking energy and put it back to the drive wheels when needed. The engineer claimed a 10% increase in fuel economy.
