RV.Net Open Roads Forum: General RVing Issues: What antenna and how to replace
 > What antenna and how to replace
bigred1cav
ohio
Posted: 05/15/18 06:26pm Link  |  Quote  |  Print  |  Notify Moderator
a 2000 Fleetwood Pace Arrow Vision old technology over the air antenna needs repaced on our coach.
What do I need to just take off old roll down and place new tech ant on roof of coach?
I want to be able to switch between direct tv and local stations. If wifi available amazon, netflex and roku?
Dutch_12078
Winters south, summers north
Posted: 05/15/18 06:39pm Link  |  Quote  |  Print  |  Notify Moderator
Your "old technology" antenna doesn't need replacing unless it's broken. Radio waves are radio waves, and that's the same today as it was in Marconi's day. There may be some enhancements available to improve your existing antenna's reception though. Is your existing antenna a Winegard Sensar "batwing" antenna?
Switching between DTV and local, or Amazon Prime, etc., are TV functions that have nothing to do with the antenna used.
Dutch
2001 GBM Landau 34' Class A
jplante4
Cape Cod
Posted: 05/15/18 06:47pm Link  |  Quote  |  Print  |  Notify Moderator
I added a Wingman to my old Winegard batwing and replaced the antenna switch box with a Sensar Pro booster and signal strength meter. I get great HD digital OTA almost everywhere. I even got Houston stations in Galveston.
At the RV parts store where I work part time, we sell a couple dozen "tech" antennas (King Jack) a season all taken out by a low hanging branch.
Jerry & Jeanne
1996 Safari Sahara 3530 - 'White Tiger'
CAT 3126/Allison 6 speed/Magnum Chassis
2014 Equinox AWD / Blue Ox
D.E.Bishop
Eagle Rock, CA
Posted: 05/15/18 06:56pm Link  |  Quote  |  Print  |  Notify Moderator
If you have a winegard, you,re set to go. If you are having problems wit it, replacing the "f" connecters, adding a wingman and the sensar pro, you will really on top of the OTA antenna.
You probably have a B.O.M.B. and that will take care of switching between anything with coax cable.
BluRay will require a HDMI cable and that will connect directly to the TV set. That is accessable from the INPUT function inthe TV.
Not a big deal, really easy. A lot more help here if you need it.
* This post was edited 05/15/18 07:04pm by D.E.Bishop *
"I travel not to go anywhere, but to go. I travel for travel's sake. The great affair is to go". R. L. Stevenson
David Bishop
2002 Winnebago Adventurer 32V
95 Suzuki Sidekick 4X4
Stowmaster 5000
jplante4
Cape Cod
Posted: 05/15/18 07:50pm Link  |  Quote  |  Print  |  Notify Moderator
Another thread running on this right now in the Class A forum.
RV Antenna
bigred1cav
ohio
Posted: 05/16/18 07:29am Link  |  Quote  |  Print  |  Notify Moderator
Do those antenna just replace by taking off old one and attaching new to standard of old one?
Do they work off same handle in coach?
Thanks
jplante4
Cape Cod
Posted: 05/16/18 04:11pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks
You remove 3 rubber plugs from the bottom of the existing batwing, put the Wingman on the bottom of the batwing and put the 3 rubber plugs back in. It takes longer to set up the ladder than it does to add a Wingman. As long as you have clearnace around other appliances on the roof, it goes up and down like the original antenna.
Video
The installation is the last 15 seconds of the video.
Wherever I happen to park
Posted: 05/17/18 08:50am Link  |  Quote  |  Print  |  Notify Moderator
If by "Roll down" you mean a winegard Sensar II or III then there is no need to replace unless broken, if Broken and not fixable (mine is fixed) the Sensar IV is the recommended replacement head. For OVER THE AIR Television.
If not broken a WINGMAN is less than 50 dollars and easily installed, A pair of common slip joint pliars may help. but I did not need 'em.
Also if you have the classic wall plate with the outlet, switch, light and antenna connection replace it with the SENsAR PRO.
IF you have, as I do, a BOX of many buttons.> Well I added the SENSAR pro. Ask and I'll tell you how, about 100 dollars give or take a bit.
For DirecTV. I recommend a tripod mounted DISH. DTV is discontinuing SD broadcasts and there is no dome I know of at this time that does HD. (I'm sure one will come out soon from king Controls, but not yet) And roof mounts suffer from teh "EVIL TREE" syndrom (Trees eat signals) so go with a Tripod mount.
Different systems. SOME Direct TV receivera will receive OTA some will not.
Home is where I park it.
