RV.Net Open Roads Forum: General RVing Issues: Inverter Charger
 > Inverter Charger
sandstravels
NorCal refugee in South Dakota
Posted: 05/16/18 05:08pm Link  |  Quote  |  Print  |  Notify Moderator
My 12 year old Xantrex Prosine 2.0 has finally bit the dust. I used it in 2 RV's and it has served me well. I learned about the Prosine 2.0 on this forum years ago. It was a 2k watt pure sine inverter/charger. I have 4 135ah 6v batteries. What is the similar latest and greatest product today? Thanks for your help.
2016 GMC Sierra SLT 2500HD, 4x4, CC, D/A
2015 Nash 23d
theoldwizard1
SE MI
Posted: 05/16/18 05:28pm Link  |  Quote  |  Print  |  Notify Moderator
Check out the Samlex EVO-2212 inverter/charger/transfer switch. They may be new to RVers, but this company has been around for awhile.
I really like their design because of the simple installation. All connections are made at the inverter/charger/transfer switch.
time2roll
Posted: 05/16/18 06:14pm Link  |  Quote  |  Print  |  Notify Moderator
Good time to switch to separate components. Then you only diagnose, repair, replace or bypass the piece that failed. I use a stand alone GoPower 2000 watt sine wave inverter.
675w Solar pictures back up
DiskDoctr
PA
Posted: 05/16/18 07:16pm Link  |  Quote  |  Print  |  Notify Moderator
After much discussion and advice last year, I decided to go with a separate ATS (automatic transfer switch), even though my Prosine has a built-in transfer switch with the inverter.
I like this for multiple reasons, one of which is not limiting my shore power load to the amperage of the inverter unit.
I can easily use a smallish or largish inverter and with the 30amp ATS I have...get full 30 amps when plugged into shore power or the generator.
I also like the ability to fully control the inverter state, though I've not had experience with using the in-built version [emoticon]
That being said, I'd agree with the above advice- separate components. Might even find a more frugal unit whose pricing went into "inverter components" instead of ATS components [emoticon]
pianotuna
Regina, SK, Canada
Posted: 05/16/18 10:47pm Link  |  Quote  |  Print  |  Notify Moderator
The only reason for an inverter/charger is if you need the hybrid type. Otherwise stand alone components are more desirable.
Regards, Don
sandstravels
Posted: 05/17/18 05:47am Link  |  Quote  |  Print  |  Notify Moderator
Sounds like good advice, thank you. Now let me re-ask the question, What is the latest and greatest charger/converter and the latest and greatest inverter?
Lantley
Ellicott City, Maryland
Posted: 05/17/18 06:02am Link  |  Quote  |  Print  |  Notify Moderator
While an inverter charger maybe more complex. Are they not easier to wire/install? Is one component cheaper than 2? I'm not very experienced on this subject but I'm learning.
I'm tossing these comments out to the crowd.
2019 Duramax w/hips,12 Open Range,Titan Disc Brake
H-head TPMS,BD3,RV safepower
Ox Bedsaver,RV760 w/BC20,Glow Steps
BakFlip,RVLock,5500 Onan LP,Prog.50A surge,keyless RV Lock
Correct Trax,Splendide
pianotuna
Regina, SK, Canada
Posted: 05/17/18 08:26am Link  |  Quote  |  Print  |  Notify Moderator
Hi Lantley,
The wiring is essentially the same and in some instances may be easier and shared. I.E. Wire inverter to battery bank, and converter to DC input on inverter.
Inverter/chargers are often more expensive than buying separate components.
The more complex a device the more likely it is to fail. With an inverter/charger failure the trip might end. If just an inverter fails it might be a little inconvenient, but it is not a trip ender. If a converter fails, an ordinary battery charger could be used on a temporary basis to allow the trip to continue.
Because I wanted a large pure sine wave inverter, and a load support feature, I did choose an inverter/charger. Due to a design fault (some one not thinking) the cooling fan on the unit is 120 volt. That means IF the inverter is turned off, and has been under a heavy load for some time, no cooling happens. I did not know that, and so the unit caught on fire. To be fair, they did cover replacement under warranty. But what use would that be on a holiday?
Fortunately I did leave the OEM converter in place, and I do have a generator (which I hate), for 120 volt loads.
It would have been a much better design for them to have used 12 volt fans so that cooling could continue with the inverter turned off--just as happens in many cars with electric radiator fans.
I wanted the load support feature because I misunderstood and thought it was voltage support. If allowed to operate "normally" load support does not keep the voltage up. For that, you need an autoformer (which I have).
If I were starting over, I would jump to a 48 volt dc system with a 4400 watt stand alone inverter. Much as I love the load support feature, I would go back to doing "double conversion" instead of the hybrid inverter/charger. It would be cheaper to do so, and more reliable.
I find myself using my small inverter a lot of the time and the big unit only for short term loads.
pianotuna
Regina, SK, Canada
Posted: 05/17/18 08:36am Link  |  Quote  |  Print  |  Notify Moderator
Hi,
Victron is hard to beat. Outback has a good reputation. Magnum may be cheaper and may get the job done.
I now have a 350 watt Victron psw inverter for small loads. It weighs over 8 pounds. It was less than $80. I use my small inverter much more often than the big one.
I can't speak to converters. I can say some inverter/chargers have custom battery settings which means the charging profile can be idealized.
For part time use, a well designed solar charging system blows a converter out of the water as it is a one time cost and can be set up and left alone. Before I was full time, my battery bank was totally full before any trip I took. I added a trick-l-start, so the chassis battery was also maintained.
Wherever I happen to park
Posted: 05/17/18 08:44am Link  |  Quote  |  Print  |  Notify Moderator
There is a man in Quartsite who fixes Prosines... Alas I do not have his ID handy but hopefully he will read this.
I have heard good things about Samulex.
Home is where I park it.
 > Inverter Charger
