RV.Net Open Roads Forum: Class A Motorhomes: Water pump
 > Water pump
camp104
La Canada ca
Posted: 06/13/18 08:44pm Link  |  Quote  |  Print  |  Notify Moderator
My water in the rv keeps running when I turn off the water. I have to turn off the switch to stop the pump. No water is leaking out from anywhere so I do not have a leak? Any ideas what might be the problem???
dalenoel
S.E. Michigan
Posted: 06/13/18 08:49pm Link  |  Quote  |  Print  |  Notify Moderator
the check valve at the pump is leaking and pressure in the system is pushing water back into the fresh water tank. Might be able to clean it out or even replace it.
03 Monaco 36PBD DP - 06 Malibu Maxx Toad (SOLD) 18 Focus Toad
08 Jayco Eagle 322FKS (SOLD)
Wife and myself, Lutheran Deacon, Oreo the Malshi, and maybe a grandkid or two
Tracking campgrounds with Ultimate Campground Log
DrewE
Vermont
Posted: 06/13/18 08:56pm Link  |  Quote  |  Print  |  Notify Moderator
Another similar possibility is that the tank fill valve, if you have one, is not shut or is leaking. (This valve allows the tank to be filled from the city water inlet. Some RVs don't have this setup and only have a gravity fill port. Obviously, if you don't have the fill valve, it cannot be leaking or left open!)
Old-Biscuit
Verde Valley
Posted: 06/13/18 10:25pm Link  |  Quote  |  Print  |  Notify Moderator
Third possibility is the city water inlet check valve is leaking
Fourth .....pump pressure switch stuck
MrWizard
Traveling
Posted: 06/13/18 11:05pm Link  |  Quote  |  Print  |  Notify Moderator
what switch ?
water pump switch ? battery disconnect ?
water won't stop ?, do you mean close the faucet, but water keeps running
replace faucet
are you hooked up to city water ?
water pressure might be to high and you need an inline regulator
Radiate The Happy
1997 F53 Bounder 36s
Ralph Cramden
US
Posted: 06/14/18 04:03am Link  |  Quote  |  Print  |  Notify Moderator
If the pump is a Sureflo it may be as simple as the pressure switch setting needs adjusted. A small allen head screw on the front end of the pump.
garyemunson
Reno, Nevada
Posted: 06/14/18 06:02am Link  |  Quote  |  Print  |  Notify Moderator
Over the decades I've had to take my pumps apart to try to see what the problem was. Most times it was a stuck valve in the pump apparently caused by some piece of trash too small to see and once i=I fiddled with the valve and reassembled it, it worked fine. Rarely ever saw what the problem was caused by.
MrWizard
Traveling
Posted: 06/14/18 09:44am Link  |  Quote  |  Print  |  Notify Moderator
OP didn't clarify
Does he man the water pump is running and making noise
Or does he means water won't stop flowing
* This post was edited 06/14/18 03:50pm by MrWizard *
haddy1
Chesterfield, MO
Posted: 06/14/18 03:15pm Link  |  Quote  |  Print  |  Notify Moderator
My 03 Winnebago would do that if the city fill valve was left in the wrong position. It would continuously circulate water to/from the tank.
2012 Tiffin Phaeton 36QSH
2007 Jeep Wrangler Toad
D.E.Bishop
Eagle Rock, CA
Posted: 06/14/18 03:26pm Link  |  Quote  |  Print  |  Notify Moderator
My pump would cycle on and off, for a quick fix while on thr road, I put a check valve on the discharre side of pump.
It took care of the sympton of a bad check valve in the pump head.
To solve thr problem, I removed the pump and took the head apart and cleaned all parts of the head, sealed with a little silicone. Working fine again.
"I travel not to go anywhere, but to go. I travel for travel's sake. The great affair is to go". R. L. Stevenson
David Bishop
2002 Winnebago Adventurer 32V
95 Suzuki Sidekick 4X4
Stowmaster 5000
 > Water pump
