RV.Net Open Roads Forum: Tech Issues: System monitor issue 1994 Itasca sunrise
 > System monitor issue 1994 Itasca sunrise
Stella sunrise
Canada
Posted: 06/13/18 09:27pm Link  |  Quote  |  Print  |  Notify Moderator
Water pump doesn’t work, idiot light levels don’t work. Checked fuse, it’s good interior lights all work so I’m assuming batteries are good to go. No power to monitor, range fan or range light. Any thoughts?
Thanks in advance.
rk911
Wheaton IL
Posted: 06/13/18 09:37pm Link  |  Quote  |  Print  |  Notify Moderator
deleted
'73,
rich, n9dko
Every retired man needs three things....a good truck, a good dog and a working wife
2016 Itasca Suncruiser 38Q
'46 Willys CJ2A
'03 Jeep Wrangler TJ
'10 Jeep Liberty KK
MitchF150
Puyallup, WA
Posted: 06/13/18 10:54pm Link  |  Quote  |  Print  |  Notify Moderator
Most 12v electric issues are ground wire related.. If all those devices are run from the same system monitor, they might be all tied into the same ground, so that's the reason those devices aren't working?
Check the ground wire to the panel and go from there. You'll need a basic multi meter, but also need to know how to use it... You could also use a power prob, but you will also need to know how to use that as well..
Good luck!
Mitch
2013 F150 XLT 4x4 SuperCab Max Tow Egoboost 3.73 gears #7700 GVWR #1920 payload. 2003 Prowler Lynx 722F #5000 GVWR and weighs every bit of it! "> Happy Camping!
1995brave
San Antonio, TX
Posted: 06/14/18 06:32am Link  |  Quote  |  Print  |  Notify Moderator
Download the Winnebago wiring diagram and it will show you the wire color, plugs, and grounds which should help you troubleshoot the problem.
