RV.Net Open Roads Forum: Class A Motorhomes: P32 sticking rear caliper
 > P32 sticking rear caliper
jspringator
Versailles, KY 40383
Posted: 07/11/18 04:43pm Link  |  Quote  |  Print  |  Notify Moderator
Ended up getting the fronts from Mill Supply. Precision Sales never emailed me back. With shipping, both were right at $100. I'll save the old hoses in the event I try the stainless experiment.
I plan to get the calipers inspected, rebuilt if necessary, slider pins lubed with Permatex 85188 Ultra Disc Brake Caliper Lube, brake system flushed with Valvoline SynPower brake fluid (3 quarts).
I guess my only question is whether the calipers can be adequately inspected.
Jim & Sherri
02 Winnebago Sightseer 27c Class A;
"Scout" Springer Spaniel, gone but not forgotten;
"Boo" Chocolate Labradoodle.
RLS7201
Posted: 07/11/18 08:53pm Link  |  Quote  |  Print  |  Notify Moderator
Kind of. Pull the dust boot back from the caliper piston and see if there is any dust, dirt, crud, rust if metal pistons, etc built up on the piston. If clean, see if the piston will push back in the bore with ease. If clean and the piston pushes back with ease, I would reuse it. If dirty or sticky, rebuild or replace.
Richard
95 Bounder 32H F53
460/528 stroker
Web Master
MWPSchooners.com
First brake job
1941 Hudson
tropical36
Southwest Florida_USA
Posted: 07/12/18 01:02pm Link  |  Quote  |  Print  |  Notify Moderator
Since I had most of it all apart, anyway, I just replaced the calipers with rebuilt from NAPA and not all that expensive.
Was still working as good as new, when we sold the coach, two years ago.
"We are often so caught up in our destination that we forget to appreciate the journey."
07 Revolution LE 40E_Spartan MM_06 400HP C9 CAT_Allison 3000.
Dinghy_2010 Jeep Wrangler JKU ISLANDER.
1998 36ft. National Tropi-Cal Chevy Model 6350 (Sold)
jspringator
Posted: 07/13/18 12:01pm Link  |  Quote  |  Print  |  Notify Moderator
Almost everything is in. The Permatex 85188 Ultra Disc Brake Caliper Lube has been ordered, as has the Castrol 12614 Dot 4 Synthetic Brake Fluid. Apparently the Valvoline SynPower is no longer available. This stuff is for high temp applications; like racing or a motorhome in the mountains.
tropical36
Posted: 07/14/18 10:39am Link  |  Quote  |  Print  |  Notify Moderator
Valvoline SynPower is motor oil, is it not?
As for a higher temp. compatible brake fluid, try 5.1, although I don't see the need for it.... Click 5.1
jspringator
Posted: 12/14/18 05:24pm Link  |  Quote  |  Print  |  Notify Moderator
Got everything in last summer. Had the mechanic pull all the pins and lube with the Permatex lube. They also had to replace one of the rigid lines too. Brakes are much improved, but they still take some effort.
