RV.Net Open Roads Forum: Tech Issues: Micro-air EasyStart
 > Micro-air EasyStart
gmctoyman
Lake Livingston, Texas
Posted: 07/03/18 09:24am Link  |  Quote  |  Print  |  Notify Moderator
Any ACTUAL User Experiences ? Sounds great, but maybe all magic ?
Dave W. AKA "Toyman"
KE5GOH - On 146.52
RV's ? What RV's ???
Apache Pop-up
Classic GMC Motorhome
07 Leisure Travel Sprinter
Do Boats Count ?
SoundGuy
S Ontario
Posted: 07/03/18 09:43am Link  |  Quote  |  Print  |  Notify Moderator
Yep, several with really positive reviews from their own personal experience - do a search. No "magic" at all, just solid engineering.
ktmrfs
Portland, Oregon
Posted: 07/03/18 10:42am Link  |  Quote  |  Print  |  Notify Moderator
do a search. lots of info on the micro air. My experience over the past year.
1) it is very easy to install,
2) at 4000ft my honda 2000 in eco mode easily starts the coleman MachIII 13.5K BTU AC unit. ramps up to near full rpm with the AC running
3) the micro air will NOT reduce running current. So..... by somewhere around 4,000-6000 ft density altitude the my honda 2000 will trip out on overload after about 15 minutes. Now the new 2200 we shall see. 2000 went to our son, I have the 2200 with (a) 200 more running VA and (b) a 20% bigger motor. May solve the high altitude problem.
2011 Keystone Outback 295RE
gmctoyman
Posted: 07/03/18 10:51am Link  |  Quote  |  Print  |  Notify Moderator
Soundguy, do you have ACTUAL experience, or did you just want to say something?
Oh, I did a search and found a lot of "my friend", I was looking for ACTUAL EXPERIENCE by real users, and received one, thanks.
Hearst San Simeon State Park
Posted: 07/03/18 10:55am Link  |  Quote  |  Print  |  Notify Moderator
That's not very nice, gmc.
Winnebago 2101DS TT & 2019 Chevy Silverado 1500 LTZ Z71, 300 watts solar-parallel & MPPT, Trojan T-125s. TALL pole for flags. Prefer USFS, COE, BLM, NPS, TVA, USF&WS, state & county camps. Bicyclist! 14 year Army vet - 11B40 then 11A - (MOS 1542 & 1560)
2oldman
Ca
Posted: 07/03/18 11:14am Link  |  Quote  |  Print  |  Notify Moderator
Looks like some actual users here. Although I personally do not have actual experience, I do have experience in searching for relevant posts.
pianotuna
Regina, SK, Canada
Posted: 07/03/18 11:29am Link  |  Quote  |  Print  |  Notify Moderator
Hi,
I have the microair unit installed. It is much easier on the demands of starting the roof air. I wish the time delay for the initial start of the compressor were a little longer. Other than that, I'm a happy camper.
Before I had the microair, my autoformer would boost the voltage in "mid start". Now, with the same shore power supply the autoformer doesn't boost in mid start.
When running on a Yamaha 2800 sIEB I can run in eco mode (but I could do that before with the hybrid inverter/charger in the mix)
If I had to choose between the autoformer and the microair I'd pick the autoformer every time.
The bottom line is the microair works as advertised. I'm not certain I'd buy one again because I prefer the autoformer.
Regards, Don
SoundGuy
S Ontario
Posted: 07/03/18 11:57am Link  |  Quote  |  Print  |  Notify Moderator
Well E-X-C-U-S-E ME for offering to help. [emoticon]
And if it helps any I did have extensive email dialogue with the chief design engineer of the Micro-Air Easy Start Soft Starter and understand fully the design concept and execution. [emoticon]
Boon Docker
Mountain Foothills of South Western Alberta
Posted: 07/03/18 12:07pm Link  |  Quote  |  Print  |  Notify Moderator
[emoticon]
jharrell
Safety Harbor, FL
Posted: 07/03/18 04:08pm Link  |  Quote  |  Print  |  Notify Moderator
I have one works as advertised, easy install, no issues in the last two years, much lower startup surge, can start my A/C off my Magnum Inverter if I want.
2016 Winnebago Vista 31be - Blue Ox Rear Track Bar - Centramatic Wheel balancers
2016 Jeep Wrangler Unlimited Rubicon Toad - Readybrute Elite Towbar
