RV.Net Open Roads Forum: Tech Issues: Micro-air EasyStart
 > Micro-air EasyStart
MrWizard
Traveling
Posted: 07/03/18 06:25pm Link  |  Quote  |  Print  |  Notify Moderator
autotransformer corrects for low line voltage, raise voltage and prevent damage to the A/C etc..
MicroAir is a special electronic soft start device that allows for starting the A/C with out the huge generator surge normally needed
two different applications
and while the Microair still helps the A/C no matter what the 110v input source is
the autoformer is NO help to a small generator situation
once you reach the power limit of the generator, that is all there is
* This post was edited 07/03/18 09:31pm by MrWizard *
Radiate The Happy
1997 F53 Bounder 36s
diftw
Huntington, IN.
Posted: 07/03/18 09:27pm Link  |  Quote  |  Print  |  Notify Moderator
How do you determine which model you need?
Dave and Anne
2016 Grand Design 337RLS
2015 Ford F350 XLT 6.7l 4x4
Reese Elite 18K Hitch
Rotochocks
Rota Flex by Trail Air Pin Box
Barker 4-wheel 25 gallon tote
Nights Camped in 2009 - 33
2010 - 37
2011 - 31
2012 - 35
2013 - 42
2014 - 45
2015 - 46
2016 - 51
2017 - 43
pianotuna
Regina, SK, Canada
Posted: 07/03/18 09:30pm Link  |  Quote  |  Print  |  Notify Moderator
Hi MrWizard,
I'd disagree and say that an autoformer is ZERO help with a small generator.
MrWizard wrote:
the autoformer is NOT much help to a small generator situation
Regards, Don
MrWizard
Traveling
Posted: 07/03/18 09:32pm Link  |  Quote  |  Print  |  Notify Moderator
pianotuna wrote:
Hi MrWizard,
actually i agreed with that
pianotuna
Regina, SK, Canada
Posted: 07/03/18 09:33pm Link  |  Quote  |  Print  |  Notify Moderator
Hi,
Which inverter? I have the 3012 Magnum hybrid. I could start the roof air even before I acquired the microair.
jharrell wrote:
can start my A/C off my Magnum Inverter if I want.
pianotuna
Regina, SK, Canada
Posted: 07/03/18 09:35pm Link  |  Quote  |  Print  |  Notify Moderator
Hi,
I got their smallest unit. Roof air is a 13500 btu Dometic.
ROBERTSUNRUS
Salem, Oregon
Posted: 07/03/18 11:51pm Link  |  Quote  |  Print  |  Notify Moderator
[emoticon] Hi, I just had Micro-Air install a unit on my trailer. No experience yet. My trailer has an 11,000 BTU air conditioner and I have had no problem running it with my Yamaha 2400 generator. My concerns were high altitude and high ambient temps at the same time. This could make it difficult to start the air conditioner compressor. This is why I had a Micro-Air installed.
"> Bob ">
2005 Airstream Safari 25-B
2000 Lincoln Navigator
2014 F-150 Ecoboost
Equal-i-zer
Yamaha 2400
Paul Clancy
BC Canada
Posted: 07/04/18 02:58am Link  |  Quote  |  Print  |  Notify Moderator
I installed mine. Works as advertised. 15000 btu dometic hp and Honda eu2200.
CJW8
Arizona
Posted: 07/04/18 09:51am Link  |  Quote  |  Print  |  Notify Moderator
Their 3 ton unit is sufficient for both 13.5K and 15K BTU AC's. I have 2 15K AC's and recently installed Microair's on each. Definitely less strain on generator when AC starts.
2015 F450 PSD FX4 LB CC, Anderson Ultimate Hitch
Keystone Raptor 332TS
2015 Polaris 1000 RZR
Rogue 3024 Charge Controller 500 watts Solar
2oldman
Ca
Posted: 07/04/18 09:58am Link  |  Quote  |  Print  |  Notify Moderator
Whenever my a/c starts up on generator, the Sirius boom box shuts off. Perhaps I could use this device.
