RV.Net Open Roads Forum: Tech Issues: Flipping Axle
 > Flipping Axle
Jethroish
Marysville, IN
Posted: 07/07/18 06:13am Link  |  Quote  |  Print  |  Notify Moderator
Looking into having the axles flipped on my 30' gooseneck horse trailer. I need to raise the rear of the trailer 2 to 3 inches
Anyone done an axle flip and how much did it cost?
Don't let your work become your life.
2018 RAM 3500 Dually 4x4 crew cab,
2015 Shadow Select 4 horse LQ w/slide out
azrving
Oatman
Posted: 07/07/18 06:23am Link  |  Quote  |  Print  |  Notify Moderator
The amount of lift will be determined by the diameter/radius of the axle plus the thickness of the spring pack and the perch. If you measure those parts and picture how moving them from above to below you will see how much lift you will get.
Usually it's around 4 to 5 iches. I would pull the trailer on to wood blocks until it is sitting level then measure the thickness of the blocks. That is the amount of lift you need.
j-d
Sunny Florida USA
Posted: 07/07/18 07:08am Link  |  Quote  |  Print  |  Notify Moderator
azrving wrote:
...I would pull the trailer on to wood blocks until it is sitting level then measure the thickness of the blocks. That is the amount of lift you need...
A measuring technique that's Beyond Clever! Load truck and trailer like they'll be for a trip, gather an assortment of boards, find a level area and measure the easy way!
If God's Your Co-Pilot Move Over, jd
2003 Jayco Escapade 31A on 2002 Ford E450 V10 4R100 218" WB
NMDriver2
New Mexico
Posted: 07/07/18 07:13am Link  |  Quote  |  Print  |  Notify Moderator
I did it myself in the driveway on a 30ft 5er. Dexter makes a flip kit for about $55 on Amazon. You do not need to weld the new saddles to the axle but it is better if you do. Just a couple of spot weld will do it once you are sure the saddles are in the right position.
You will also need 4 jack stands or cribbing to hold the trailer up, a rolling floor jack helps but is not necessary, to position the axles, and watch a few youtube videos on the subject. Some of the lift methods are pretty interesting but not something I would try. One guy used cinder blocks on their side with a jack stand standing on the hollow portion of the block [emoticon] I just jacked it up and put the jack stands under the frame close to the spring shackles.
* This post was edited 07/07/18 07:25am by NMDriver2 *
Turret Class traveler
Boomerweps
Hills of PA
Posted: 07/07/18 08:05am Link  |  Quote  |  Print  |  Notify Moderator
Thanks for the info on the Dexter flip kit. Just checked them out on Amazon. Both around $50 per axle kit. Available for 3" and 2&3/8" diameter axles. The smaller is the 3.5K axle and the larger is the 6-8K, per Etrailer. Towing my trailer is often a lot like the mid 1960's song, "Kind of a drag".
* This post was edited 07/07/18 08:12am by Boomerweps *
2019 Wolf Pup 16 BHS Limited
2019 F150 SCrew STX SB 5.0 factory tow package
TakingThe5th
Chicago - Western Suburbs
Posted: 07/07/18 10:35am Link  |  Quote  |  Print  |  Notify Moderator
FYI-do not use cinder blocks on this project. They can crumble. Use boards.
TakingThe5th - Chicago, Western Suburbs
'05 Ford F350 Crew 6.0 DRW Bulletproofed. Pullrite Super 5th 18K 2100 hitch.
'13 Keystone Cougar 333MKS, Maxxfan 7500, Progressive EMS-HW50C, Grey Water System.
Jethroish
Marysville, IN
Posted: 07/07/18 10:38am Link  |  Quote  |  Print  |  Notify Moderator
I found those flip kits too. Looks pretty simple.
After posting this, I found something that may be better for my situation.
Quick story...
Got a new truck and had to adjust the gooseneck. It adjusts by 2.5 inches at a time. Moving one hole only gave me 4.5 to 5 inches of tail gate clearance. Moved it one more and got 7.5 inches of clearance. Problem now the trailer is more nose high than I am willing to have.
Hopeful solution is, found that Reese makes a 1 inch extended collar drop in goose ball. Add that to the 7.5 inches then drop the gooseneck one hole. That "should" bring the nose of the trailer down by 1.5 inch and still leave me 6 inches of tail gate clearance.
Looking at the springs and axles, I think a flip would work but going to try the "easy" fix first.
* This post was edited 07/07/18 10:44am by Jethroish *
Boomerweps
Hills of PA
Posted: 01/12/20 07:05pm Link  |  Quote  |  Print  |  Notify Moderator
Committing. Ordered via Amazon the Dexter flip kit for this spring!
hypoxia
Arizona
Posted: 01/13/20 06:23am Link  |  Quote  |  Print  |  Notify Moderator
If the trailer has shocks the mount will have to be re-positioned and a possibility the shock could be too short. The shock mount piece should be available at any trailer supply house.
Jim
2007 Monaco Signature Noble III ISX 600HP
Optimistic Paranoid
East Nowhere NY
Posted: 01/13/20 07:16am Link  |  Quote  |  Print  |  Notify Moderator
It's amazing how many people are competing for Darwin Awards!
 > Flipping Axle
